Question about Nokia 5130 Cellular Phone
My in belet memory his low what could i do for this problem
  • Nokia Master
  • 3,267 Answers
Delete messages, images, video, songs,etc or add a micro SD card of 2 GB
Posted on Dec 31, 2010
HOW DO I DELETE TOOL BAR EXTENSIONS FROM MANAGE ADD-ON'S"
Tool bars are usually in your browser. For Firefox, go to Tools and then Add Ons to add or delete. IE is similar.
Oct 17, 2014 | Computers & Internet
How to resolve the memory low system
Hi Anon, this is Microsoft's answer to low memory messages, and I would only add the suggestion that you check for viruses and other unwanted programs hogging your computer's memory. How to prevent low memory problems Running fewer programs at one time can help prevent low memory problems and information loss. It's a good idea to observe which programs show signs of low memory conditions and try not to run them at the same time.
However, it's not always convenient or practical to run a limited number of programs. Signs of low memory can indicate that the computer needs more RAM to support the programs you use. Here are the recommended ways to solve or prevent low memory problems:
  • Increase the paging file (virtual memory) sizeWindows automatically attempts to increase the paging file size the first time your computer becomes low on memory, but you can also manually increase it up to a maximum size that is determined by the amount of RAM installed. Although increasing the paging file size can help prevent low memory problems, it can also make your programs run more slowly. Because your computer reads information from RAM much faster than from a hard disk (where the paging file is), making too much virtual memory available to programs will slow them down.
    For more information, see Change the size of virtual memory.
  • Install more RAM
    If you see signs of low memory, or if Windows warns you about a low memory problem, check the information that came with your computer or contact the computer manufacturer to determine which type of RAM is compatible with your computer, and then install more RAM. To install RAM, check the information provided by the manufacturer.
    For more information, see Find out how much RAM your computer has.
  • Determine if a program overuses memory
    If the computer becomes low on memory whenever you run certain programs, one or more of those programs might have a memory leak. To stop a memory leak, you need to close the program. To repair a memory leak, you need to check for updates for the program or contact the publisher of the software.
    To determine which program is using the most memory, follow these steps:
    1. Open Task Manager by right-clicking the taskbar, and then clicking Start Task Manager.
    2. Click the Processes tab.
    3. To sort programs by memory usage, click Memory (Private Working Set).
    You can also check for program errors and troubleshooting information using Event Viewer.
    1. Open Event Viewer by clicking the Start button 4f6cbd09-148c-4dd8-b1f2-48f232a2fd33_818.jpg, clicking Control Panel, clicking System and Security, clickingAdministrative Tools, and then double-clicking Event Viewer. 18abb370-ac1e-4b6b-b663-e028a75bf05b_48.jpg If you're prompted for an administrator password or confirmation, type the password or provide confirmation.
    2. In the left pane, click Applications and Services Logs to view error events. To see a description of the problem, double-click the event. To see if troubleshooting information is available, look for a link to online Help.
    For more information, see What information appears in event logs (Event Viewer)?
Top of page
Aug 10, 2014 | Acer Aspire E1-472G-6648 Misty Silver 14"...
How do I change the drive belet
To remove a 2007 Touring drive belt FIRST remove the rear wheel and the rear swingarm, remove the primary chaincase assembly,remove the old belt from the transmission sprocket.
To install a 2007 touring drive belt FIRST install the new belt on the transmission sprocket, then install the primary chaincase assembly, then install the rear swingarm and the rear wheel and adjust the belt deflection to specifications.
Belt Deflection
Vehicle Orientation Model Inches Millimeters
Motorcycle Upright
With Rear Wheel in Air
or On Jiffy Stand
Without Rider or Luggage
FLHR/C,
FLHT/C/U, 3/8-7/16 9.5-11.1
FLTR
FLHRS,
FLHX1/4-5/16 6.4-7.9
Apr 27, 2014 | 2007 Harley Davidson FLHRC Road King...
Memory problems
  • Install more RAM
Mar 08, 2013 | Dell VOSTRO 3350
My belet went out
What is the model number?
Oct 16, 2012 | Amana Washing Machines
What's your problem? i need timing belet marks for a 2000 toyota rav4 with 2.0 eng.
Bottom pulley lines up with zero mark top has a marker...
Hope helps.
Sep 27, 2011 | 2000 Toyota RAV4
Replace serpentine belet on 2002 santa fa
Below is the diagram you will need to replace the belt. The diagram is for a 6cyl. 2.7 engine (most common for that year). Once the tensioner pulley is loose, route the new belt as diagrammed and while applying pressure, tighten the tensioner pulley.
2002 Hyundai Santa Fe 2.7L with A/C
Mar 02, 2011 | 2001 Hyundai Santa Fe
HP Laserjet M1522nf memory error how do i clear it up
Mem. low 1 copy. Press OK The product completed making one copy. The remaining copies have been canceled because of low memory. Press Cancel to clear the error. Break the job into smaller jobs that contain fewer pages. Memory is low Try again later The product does not have enough memory to start a new job. Wait until the current job is finished before starting a new job. Memory is low. Press OK The product memory has been almost completely filled. Allow the product to finish the job, or press Setup to cancel the job. Memory low Only 1 copy made The product does not have enough memory to complete the collated copy job. Break the job into smaller jobs that contain fewer pages.
GO TO THIS LINK FOR MORE INFORMATION
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=ca&taskId=110&prodSeriesId=3442750&prodTypeId=18972&prodSeriesId=3442750&objectID=c01312064
PLEASE ARTE MY SERVICE
Nov 19, 2010 | HP LaserJet M1522nf Multifunction Printer...
Low message memory
my massage memory is low how i increase my phone momery
Nov 27, 2008 | Sony Ericsson K750i Cellular Phone
Nokia 5130 Cellular Phone Logo
13 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
