Question about JCPenney Gyropter RC Helicopter
Hello, i have problem with flying back and forvard, becouse rear propeller does not work. What is wrong and can i fix it? Thanks :)
  • 17,130 Answers
Yes if the rear propeller does not work the helicopter cannot be made to turn around. So it is important that the rear rotor works.
Now make sure that the drive is working to let the motor work , if controlled by the remote make sure the remote command works or is a fault in the remote.
Check the mechanics of the rotor movement. reset.
Posted on Dec 31, 2010
I did check all the propellers and they were ok I would like to contact the seller but I don't have any address to do so I am hopeing it is still under warenty
What is the issue with the quadcopter?
All propellers spin but it flips over when trying to fly?
This would be clockwise and/or counter clockwise propellers on the wrong motor(s). For copters with an even number of propellers, each propeller turns the opposite direction from the ones on either side of it. The reason for this is so the combined engine torque is in equilibrium. Unbalancing this equilibrium is what allows the craft to turn left or right without a rudder or tail rotor.
Regardless of spin direction all propellers must blow air downwards.
Aug 11, 2014 | HUBSAN X4 H107c 2.4g 4ch Rc Quadcopter...
Hi my syma quadcopter x1 is stuck in the eversion how can i fix this ?? Thanks
Jun 22, 2014 | Syma rc x1 aerobatic bee quadcopter 2.4ghz...
I recently got a DH-1 AeroQuest Mini Helicopter. It was working fine until I crashed it against the wall. So now the top Propeller spins but the bottom propeller does not and the helicopter just spins...
I had the same problem. Bottom blade would not spin. There are 2 shafts that spin 2 gears. The outer shaft that spins the bottom blade has 2 set screws and my set screws got sheered off. I replaced both set screws and everything works now....
Sep 04, 2011 | Toys
I have a 6 hp self propelled Craftsman mower with
Ok this may be a simple fix. it has a high chance that the fly wheel key has sheared, this will cuse the timing to advance and bite your hand with the rope.
remove the pull starter and the cup ontop of the fly wheel, if you look straight down at the fly wheel nut you can see a cut out in the crank and fly wheel they should be aligned up if not it has sheared. use a lever under the fly wheel and put some pressure on to to lever it up then hit the fly wheel oposite side of the lever AWAY from the the magnet. and the fly wheel should pop up. replace the key and of you go..Make sure you use the OEM brigbs and strat key it is made out of alloy. The cause of this is the blade hitting a kerb or somthing hard,
Jul 02, 2010 | Garden
I have a toro self propelled lawnmower. Ireplaced
the spider gears are in on the wrong side more less like you put the rear end in backwards
Nov 09, 2009 | Toro Lawn Mower With Toro Power Tools
How do we replace propeller on super cub?
The spinner is simply pressed on. Pull the spinner directly forward while firmly holding the plane at the firewall. Once removed hold the prop by hand and use a wrench to loosen the prop nut. The propeller should slid off but may need to be unscrewed.
To re-install, just reverse procedure. The prop needs to be firm or snug only. Do not over tighten. Be sure to press the spinner back on lined up with the prop blades. Then go fly
Jun 14, 2009 | Hobby Zone Hobbyzone Super Cub Propeller...
ACCELERATOR HAS STOPPED WORKING ON BRIGGS & STATTON PETROL MOWER
when the lawn mower suddenly stop working,first you should check the fuel. i think the Self-propelled device was broken. You can take the Self-propelled device off and try again with it.
May 03, 2009 | Briggs & Stratton Lawn-Boy Insight Series...
Hoover wind tunnel u5755-900. smoke, smell. self-propel
Can you verify the model number? However, based on your posted description, it sounds like the flat belt is either broken or fell off. to access the belts turn it over and remove the bottom plate (4 screws). the Flat belt will connect to the motor shaft in the back and the large black pulley.
Mar 13, 2009 | Hoover Self-Propelled WindTunnel Bagless...
Toshiba blinking power light...nothing on screen
HELLO.!!! IT SOUND LIKE YOU HAVE A BAD HORIZANTAL OUTPUT TRANSISTER & FLY BAD FLY BACK TRANFORMER. TRY CHANGING THEY'S .!!! THEN YOU SHOULD HAVE A WORKING SET"GOOD LUCK"
Sep 01, 2008 | Toshiba 43HX70 43" Rear Projection...
JCPenney Gyropter RC Helicopter Logo
664 people viewed this question
Top JCPenney Toys Experts
Andrew Taylor
Andrew Taylor
Are you a JCPenney Toy Expert? Answer questions, earn points and help others
