Question about Dell Precision T3500 Computer Workstation (Intel Xeon W3503 80GB2GB) (BW1S13603) PC Desktop
Dell precision 1 and 3 amber light glowing and the machines goes off
  • Dell Master
  • 998 Answers
Memory configuration error. Remove the memory and install memory modules one at a time.
Posted on Jan 09, 2011
Dell Precision T3500 wont boot 1-3 lights blinking
An amber light means your computer isn't reading the hard drive or CD right, Take it to a professional to get this corrected
Dec 16, 2013 | Dell Precision Computers & Internet
Dell precision workstation t7500 won't boot. Showing solid amber.
You may have to reinstall operating system by buying a Dell cd(from amazon) that reinstalls the operating system you had on the workstation.
Dec 07, 2011 | Dell Precision T7500 Computer Workstation ...
Dell opitiplex 280 is not giving display. first of all his fan speed to much high and then after 4 or 5 day its display disappeared. its just picking now power and fan also start with high noise and...
OK, I use GX280s as home servers and ran into a similar problem with one of them...
The problem may be serious and not worth fixing (motherboard).
Turn power on
Fan(s) come on full power, sounds like a jet engine, or eventually gets that loud.
See if you power light has gone amber.
You get nothing on the screen, no Dell splash screen/post, nothing.
This is what I posted a while back concerning the above. Obviously I cannot bee 100% certain as I do not have your box in front of me. This a known issue.
See if the power light goes amber after power up. I had (have - still siting in my basement) one that did same. Power up, fans go full blast . Power light goes and stays amber. This is USUALLY caused by bad capacitors on the mother board. Known GX280 problem going back. If you look on the motherboard, the capacitors should have flat tops and not leaking. If the are rounded or leaking, the MB has probably gone bad. Bottom line this is usually a defective motherboard. Mine was a bad caps issue, you issue could be different, but it does sound like the motherboard.
You can google "gx280 solid amber light loud fan" and see the issues. Here is one link.
http://community.spiceworks.com/topic/111476-gx280-solid-amber-light-and-loud-fan
I just replaced one of my old 280s with a dual core Dell Precision 390 workstation for about $118, and that included shipping, off of ebay.
Sep 25, 2011 | Dell OptiPlex GX280 PC Desktop
I have a Dell Precision 490, the Light at 1,3 and the power button blinks and i cannot star tmy computer!
I normally post this link:
http://www.fixya.com/support/r4282412-find_no_post_diagnostic_information_dell
but I think I can get better info for you here:
http://support.dell.com/support/edocs/systems/ws490/en/ug/tools.htm#wp1057769
2 things.
The power led flashing amber can mean a failure of one rail in the power supply, or a bad connection (The cables are removable from the power supply) so you may try reseating power connections internally.
1 & 3 LEDs can mean a RAM failure
Aug 22, 2011 | Dell Precision Workstation 490 - MT -...
Dell Prec470 with a flickering amber light in front when i switch it on.
See my published guide entitled My Computer is not turning on!!! Is it dead!!! No POST!!!
Whats happening is that the computer system is not passing the Power On Self Test or POST. Therefore the computer monitor does not receive a signal and goes into standby mode.
Take care
damnor01
Apr 18, 2011 | Dell Precision 470 PC Desktop
I have a Dell Precision 620 and the problem with running a PC. When I press the button, only yellow light is present and nothing happens. Control LEDs (4 pieces) on the rear side of motherboard does not...
Having worked with Dell computers before I have found that the amber light usually means bad power supply.
Get a replacement power supply from a know working Dell machine as their power supplies are different from standard ATX power supplies.
Regards.
Jan 13, 2011 | Dell Precision 620 PC Desktop
Dell precision 490 led 1 & 4 on
As description of Manual of the pc ,
led 4 is means The computer is in a normal
off condition; the computer is
connected to an electrical
outlet
https://www.manualslib.com/manual/36893/Dell-Precision-Dcd0.html?page=35#manual
1 and 3 illuminate for Memory modules are detected, but a
memory configuration or compatibility
error exists.
solutions
• Ensure that no special memory
module/memory connector placement
requirements exist.
• Verify that the memory modules that
you are installing are compatible with
your computer.
• Reinstall the memory modules and
restart the computer.
• If the problem persists, contact Dell. (if have warranty)
But you can install and check one module at a time.
if not compatible each other may not display.
https://www.manualslib.com/manual/36893/Dell-Precision-Dcd0.html?page=40#manual
May 15, 2010 | Dell Precision Workstation 490 - MT -...
If you are getting no video at all, then we can use the diagnostic LEDs and the power LED to help determine the failure.
Mar 29, 2010 | Dell Precision Workstation 490 - MT -...
Take a 2-CPU Precision 670 down to 1-CPU
You probably removed the "primary" CPU,
and the computer cannot operate only with the "secondary" CPU installed.
Move the CPU from the "secondary" slot to the "primary" slot.
Jan 13, 2010 | Dell Precision Workstation 670 PC Desktop
Dell Precision T3500 Computer Workstation (Intel Xeon W3503 80GB2GB) (BW1S13603) PC Desktop Logo
1,961 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
