Question about Whirlpool 24 in. ADP5966 Free-standing Dishwasher
The start light is flashing on and off and the programmer wont change to another programme it stays on the normal programme and the dishwasher will not start
  • 3,267 Answers
Seems to be relatively common. Ma doing one now with that exact problem. If you hold button in for about 10 seconds, it should reset.(switch off then on again to push start.). If same action continues, the electronic module needs to be replaced.
Posted on Dec 31, 2010
Zanussi dishwasher ZDF601M 1 in 3 red light comes on and programme doesn't work through
26269906-aipk5px1bmfkdpsmrgevaqwn-3-0.jpg "3 in 1" function
This appliance is equipped with the "3 in 1" function, that
allows the use of the "3 in 1" combi detergent tablets.
This function can be selected with all washing programmes.
With the selection of this function the inflow of rinse aid and
salt from each respective supply container is automatically
deactivated and also the indicator lights for salt and rinse aid
are deactivated.
Select the "3 in 1" function before the set of a washing
programme.
Once this option is selected (indicator light illuminated) it will
remain active also for the following washing programmes.
With the use of the "3 in 1" function, the cycle durations may
change. In this case, in the digital display, the indication of the
running time of the programme is automatically updated.
NOTE: Once the programme is running, the "3 in 1" function
can NO longer be changed. If you want to exclude the "3 in 1"
function you have to cancel the programme setting (see
chapter "Starting a washing programme" - "Cancel a washing
programme in progress") and then deactivate the "3 in 1"
function.
In this case you have to set a washing programme (and
options) again.
Activation/deactivation of the "3 in 1" function
(The dishwasher must be switched off)
1. Press the On/Off button. The On/Off indicator light
illuminates (setting mode).If a programme button indicator light is on, this means that a washing programme is set. The programme must be cancelled: press simultaneously function buttons 2 and 3
for about 2 seconds. All the indicator lights will turn off (except for the On/Off indicator light and eventually salt and rinse aid indicator lights) indicating that the set programme has been cancelled and the machine is now in setting mode.
2. Press simultaneously function buttons 2 and 3, until the
indicator lights of function buttons 1, 2, 3 and 4 start
flashing.
3. Press function button 4, the indicator lights of function
buttons 1, 2 and 3 turn off while the indicator light of function
button 4 goes on flashing.
4. Press function button 4 again, the "3 in 1" indicator light
illuminates, indicating that the "3 in 1" function is active.
To deactivate the function press function button 4 again, the
indicator light turns off.
5. To memorise the operation, switch off the dishwasher by
pressing the On/Off button or wait about 60 seconds after
which the dishwasher will automatically return to setting
mode.
Dado
Aug 29, 2016 | Zanussi Dishwashers
When I start the normal 50 button, the top and middle lights blink three times. Then after few seconds the normal 50 and bottom lights start to blink
Start the wash programme
1. Check that when the dishes and cutlery are loaded in the dishwasher
the spray arms are free to rotate.
2. Open the water tap fully.
3. Shut the door.
4. Press the ON/OFF button. ON/OFF button indicator comes on.
5. Press the button for the programme required (see "Programme Table"). The programme indicator lights up. One or two lights will flash in the multi-display. During this time it is possible to reselect the programme. The selected washing programme begins after approx. 6 seconds. The current wash programme stage will always be shown in the multi-display.
3 If the top light and/or the middle light in the multi-display flash after
the programme has started please read the section "What to do, if...".
Dado
Jun 13, 2014 | AEG 24 in. Favorit 40630 Free-Standing...
All lights up flashing lights but will not start
all lights flashing on programme washing machine wont start
Aug 29, 2013 | Smeg Dishwashers
Beko dw 600 dishwasher, all programme lights stay on and it wont run or clear
I had this problem and followed the advice from Gallagher to no avail.
I sorted it as follows andd bear to mind I have never seen inside a dishwasher. I found the float valve and removed the connection to open circuit the switch, still the same, I then did the same to the sensor in the water container still the same. I concluded that the only thing left was the control module in the door.
I got the pcb on line for 22-00 and fitted it. job sorted
It says the changing of the module requires an expert, dont know why its a piece of cake.
Jul 08, 2012 | Beko Dishwashers
On my whirlpool ADP962 dishwasher the start light is flashing but nothing is working. I can change the programme type (ie rinse, wash etc) but the programme will not start. I can't select either half load...
check the thermal cutoff located inside the door for continuity and check the heater to assure this is working as well you can also do continutity test on the heater if the heater is not functioning properly then unit will go no further into washing the same with the thermal cutoff if you have any further questions message me back and please remember to rank how this opinion has helped it allows me to help others in similar situations in the future Thanks again Rick
Apr 26, 2011 | Dishwashers
Starts ok then skips programmes lights flash then stops without finishin wont complete any programme
starts ok then skips programmes lights flash then stops without finishing wont complete any programme
Jul 02, 2010 | Miele Washing Machines
Indesit dishwasher DI 450 stops after 10 mins
my disher washer dls 535 starts programme then lights 2 and 3 start flashing and does not work
Nov 19, 2008 | Indesit 18 in. D41 Slim-Line Free-standing...
Hotpoint aquarius fdw60
My Hotpoint FDW60 dishwasher - I select new programme (normal 55 degree wash) and it defaults to 45 degree wash green light flashing and just making a whirring sound but nothing else happens. I have tried pressing the restart button, holding it in until I get the continuous sound and then restarting the programme but the same thing happens
Sep 17, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Whirlpool ADG 957. Light for rinse programme on but start light flashing intermittently. Cannot change programme, cannot start machine.
Mine was doing exactly the same. I turned off power, held down the 2 black buttons on right, switched back on and the start button flashes intermittently. It then allowed me to change programs, just testing it now!! It started, this was more then it was doing!! lol
Aug 17, 2008 | Dishwashers
HELP WITH NON FUNCTIONING DISHWASHER
similar problems here, repair man says its fine but the salt light was on so i added salt and works ok now. Some dishwashers don't function properly without the salt and rinse aid, even though you're pills may have then included, you still have to add them seperately, dumb but necessary at times.
Feb 27, 2008 | Dishwashers
Whirlpool 24 in. ADP5966 Free-standing Dishwasher Logo
413 people viewed this question
Top Whirlpool Dishwashers Experts
Mike
Owen Barnes
Are you a Whirlpool Dishwasher Expert? Answer questions, earn points and help others
