Question about Ovens
No sign of life in the oven. No light, no fan, no heat. Worked two days ago. Checked main house fuse box - no problem there.
  • 784 Answers
If the main fuse box breaker looks good then there is a chance that the outlet that the oven is plugged into is bad and there is no power there. also that outlet could be inline with a GFCI outlet in the kitchen and that outlet could have failed. check to see if you have power at the outlet and if you don't -- trace back from there.
( also -- sometimes the breaker looks ok and it in fact is not -- flick it off and back on and then see if you now have power to that outlet / oven ).
c...
Posted on Dec 31, 2010
Oven has stopped heating, and automatic interior light has also stopped working. Fan still works though - any ideas?
Stove possibly has a fuse panel which is usually in the inside area of the switches and there is usually one for each burner as well as the oven. Make sure you replace with the right size fuse or you could have trouble.
May 18, 2015 | Ovens
MAIN HOUSE FUSES TRIPPED, RESET, OVEN AND GRILL WILL NOT HEAT UP
It would appear that the tripping of the switch has caused some kind of short within the cooker. I would look for the continuity of the heating element.
Most likely the wires leading to the heating element have burnt and will need replacement. If you are comfortable with attempting a DIY, well and good. You will have to open the back panel to access the said wires. It should be easy enough to identify..it will be the wire leadingto the heating coil.
If , however, you are not familiar with these kind of things, I would recommend getting a repair guy to do it for you.
Cheers and good luck with the repair!
IrishDruid.
May 26, 2008 | Belling XOU252 Electric Single Oven
Lower oven loss of power
I'd check the control switch first, and the wireing and connections.
Sep 05, 2012 | Ovens
Switched bottom oven on, then noticed it had tripped fuse for cooker in main fuse box. Swithed it back on and it wouldn't heat up. The fan and light were ok! Top ove? grill works ok still.
sounds like you have a heating element burned out. Look real close at the heating elements and you may see a hole burned in the metal tube. This is a sure sign of a bad element. Some elements are easy to unplug. Others a real pain. Always unplug and or turnoff breaker prior to unscrewing anything. If you fine the bad element just unplug and other element may work OK. Best to get your model number and search net for new element.
May 30, 2011 | Ovens
Frigidaire Caprice Oven won't work
i have a double caprice oven and the top oven wont go - something to do with timers
can u help
May 12, 2009 | Frigidaire FEB27S5A Electric Single Oven
Oven not heating, and tripping .Aeg Electrolux
check your heating ellement
Mar 24, 2009 | Ovens
Oven not working
for darnos
have you reset the clock? this needs doing after you lost power. i suspect you have it on auto
for jez-cath and wilana
in both cases, probably the fan element at fault.
Feb 12, 2008 | Smeg SE250XUK Stainless Steel Electric...
Fan Oven blows Fuse over 175 Celcius -Baumatic BT2760SS
Hi, I was cooking and my oven jut went off, looked in fuse mains box and had tripped. So put back on and now the fan works but no heat...Can you give me some idea what it mite be.
Sep 18, 2007 | Ovens
Ovens Logo
47 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
