OE displays and washer will not drain
We've checked and found no obstruction to the out flow but the washer does not drain. Any ideas? I have a LG Intellowasher WD-1021 WF. No obstructions in outlet but water will not drain
  • Anonymous Mar 13, 2014
    WATER STOCK NOT DRAIN
    Scholar:
  • 148 Answers
You have to check the pump,remove the hoses from the pump first and check for any blockage could be lint or a sock,if there is no blockage and the pump spins its the propellar for the pump is worn and you have to replace the pump
Posted on Jul 08, 2008
OE error please
There may be a few different reasons why the OE error code can display on your washing machine. Is it the LG washer getting the OE error code? The OE error code on the LG washing machine display is an indication of a NO DRAIN issue. The 3 issues that may cause this fault code is a bent drain hose, the drain pump filter is blocked, or the drain pump may have foreign objects lodged in it making it unable to drain. All these issues can cause your LG washer to display the error code OE. With all these different reasons, checking all 3 components will clear the error and fix your LG washing machine.
Oct 29, 2017 | Washing Machines
Tip
Appliance Repair Kuna - LG Washer OE Error
OE errors. An OE error on a LG washers suggests a pump problem. Check the drain filter on front bottom of washer for any obstructions. If this is clear, call for service. The pump impeller may be damaged, pump windings shorted, or a obstruction in line.
Rich
Western Appliance Repair Kuna
on Oct 12, 2010 | Washing Machines
How to fix drain hose on LG WM2487H M
The following are a number of things to check for the OE (drain error) indication.
If the washer does not drain then the drain pump may be clogged, damaged, or defective.
Sometimes, socks and other small articles of clothing can get into the drain system and clog the pump hose or the pump itself. Open the drain pump filter tray at the lower left of the machine and check whether it is clean, check also that the pump impeller spins freely. Remove the hoses from the pump and check for any obstructions.
First, check the drain hose to determine if it is kinked, twisted, or bent. If the drain hose is bent, straighten it out. In addition, remove the drain hose and check it for obstructions. If the drain hose has any obstructions, try to remove them. If necessary, replace the drain hose.
Check the machine's water level frequency by pressing the WASH/RINSE + DELAY WASH buttons simultaneously. Check the reading on the display, if it is below 260 (26 Khz) then have someone measure the resistance of the pump motor coil.
It should be between 10-20 Ohms resistance, if too high or too low, replace the pump assembly as it cannot be repaired.
Mar 08, 2016 | LG Washing Machines
The washer stops at 39 minutes on a regular wash cycle and the code OE is displayed
This fault code can mean that the pump is faulty as well as blocked, first of all check for a blockage and, if none is found then the likelihood is that the drain pump is faulty. Should you need it, the most common drain pump used on LG washers and washer dryers is this one.
On non-display panel models this fault code is denoted by the lights for 800, 500 and No Spin being lit or flashing.
  • Check pump filter is clear and there are no obstructions
  • Check the drain hose for obstruction
  • Check the drain hose is not kinked
  • Check the drain pump filter and clean if required
  • Check the air chamber and pressure sensor hose
  • Check drain pump, normal resistance is 152-175?
  • Check drain pump rotor
  • Check connections to water drain pump
Oct 09, 2015 | LG WM2701HV Washer
Error code 0E on LG WM1290 FHB ?
The error code 0E stands for obstruction error, meaning that the drain line is obstructed. This is why the spin fails as all the water is not being drained. Check the drain hose for kinks and clean the drain filter. If they are not the problem, there could still be an obstruction in the drain hose in or about the drain pump.
Dec 28, 2014 | LG Washing Machines
Filter clean drain hose straight and only 12" high still get OE code
Check for an obstruction in the pump itself. Post back the results.
Jan 21, 2013 | LG WM2277H Front Load Washer
Keeps stopping and showing OE
Hi tpearsgolf,
The "OE" error code you are seeing, means "Outlet Error"
The drain pump is either clogged, or the outlet hose has been kinked.
- Inspect the Drainage hose at the back for kinks. - If any, straighten the hose
- Open the unit, and at the bottom sump check the small drain pump area for any foreign object that may be obstructing it. You can remove the filter, as well as the metalish sieve underneath it, check the sump underneath near the drainage holes, make sure nothing is obstructing the flow out of the machine from there.
If not successful, you will need to replace the Drain Pump.
Kind Regards :-)
If you found this solution helpful, please rate it.
Jun 30, 2011 | LG LDS4821 24 in. Built-in Dishwasher
What does oe mean on my washing machine display
"OE" code in your washer indicates a Drain error. This is because the washer is not fully drained within 10 minutes. You have to check whether there is a kink in your drain hose, ensure the filter is clean, the drain hose can become clogged with sludge, sometimes a hot wash with 1/2 a cup of vinegar will remove this sludge.
Thank you !!
May 23, 2010 | LG WM2487H Front Load Washer
there might be something stuck in the pump or the wire to the pump is lose.
HERE is service manual for your machine
Jun 26, 2008 | LG WM-2277HW Front Load Washer
Washing Machines Logo
409 people viewed this question
Top Washing Machines Experts
