I have lost the instructions for Superser F250 and can'ty remeber which way the settings work for low medium or high.
2 Suggested Answers
SOURCE: fan works on all speed, and low cool is working but does not change to medium or High
i need a wiring diagraham for a duo-therm mod# 54812-136
Posted on Jun 22, 2009
My 1999 f250 blower motor only works on high
You probably need a blower motor resistor , it work's through a relay for high speed an resistors lower the speed for low , medium etc... Videos on youtube on how to test ! How to Install Replace Heater AC Fan Speed Resistor 99 07 Ford F250 F350...
Mar 16, 2017 | Ford F-250 Cars & Trucks
My 2010 Dodge Avenger the blower was only working on the to low and medium prop mob up with penny work for a while to penny fell out won't work now
2009 dodge avenger blower motor works on low, medium ...
www.fixya.com/.../t21143783-2009_dodge_avenger_blower_motor_wo...
Nov 2, 2013 - 2009 dodge avenger blower motor works on low, medium low,medium high but not high. Resister has ... SOURCE: Dodge 2001 Stratus - A/C fanonly blows on High ... working. Jan 04, 2010 ' 2003 Dodge Durango · 1 Answer ...
Oct 29, 2015 | Dodge Cars & Trucks
LG Dryer low heat doesn't work
It may be as simple as checking your lint filter.
If you use fabric softeners sheets, they tend to clog the lint filter holes. Washing it with soap and water will restore it back to normal and will allow the circulation that the dryer needs to properly dry your clothes.
May 04, 2014 | LG DLEX7177 Dryer
1992 chevy C1500: Heat works on low speed, no medium, and high only works intermittantly.
On any other vehicle it sounds like the blower fan switch.
The fan switch provides power or ground to the resistor and there would be a high speed blower relay to bypass the resistor.
But in your case the fan switch is part of the controller.
I don't have a diagram for a 92 but the 94 model shows relays for low medium and high speeds. Each relay gets power from a fuseable link. The high relay gets power thru the low relay if the low relay is not engaged.
If you have the model with 3 relays you may need to check them.
Feb 01, 2013 | 1992 Chevrolet C1500
Hampton Bay Windward II Purchased 2002 The fan has lost high speed. Low speed and medium speed work fine. When the fan is turned on to high speed it runs at medium speed. When switched from high to medium...
Most fans have a small rectangular multi-tap capacitor connected to the speed control in the fan. It is likely that this has gone partially bad. The capacitance values are printed on it. Lighting stores and big box hardware stores generally carry replacements.
Feb 23, 2010 | Dryers
Low does not work, medium and high do
You probably cant fix it, this sounds like a multispeed blower with hi/medium/lo settings. You
can either replace the motor or connect one of the
working speeds to low/med or low/hi. or bump med to low and high to medium.
Jan 12, 2010 | Desa International Blower Glow Warm Wall...
Hunter fan with remote control was 3 speed, now only 2 speed
It sounds like fan motor is okay. There are two motor windings -- one low speed, one medium speed. Low winding gives you low speed, medium winding gives you medium speed, both windings give you high speed -- so I would say if you get high speed, both windings are good.
The remote (the hand held transmitter) controls the speed by raising and lowering the frequency of the current which is 60 cycle coming to the fan ceiling box. If the fan speed -selector switch (usually a pull switch) is set to high, when the remote (transmitter) signals the receiver to change speeds, the frequency of the current is changed by the receiver (the receiver is usually in the fan housing).
Sounds like you'll need to replace the remote system -- these come in sets, both transmitter and receiver, and cost about $30. If you're not experienced with wiring fans, you should get an electrician to do the job.
Apr 21, 2009 | Hampton Bay 24002 Ceiling Fan
Whirlpool commercial gas dryer - heating problem
Check the voltage to the switch when turned to high and the power button pushed on. If you are not getting any power there then the setting switch is bad replace it at repairclinic.com
Feb 14, 2009 | Whirlpool CSP2761 Gas Commercial Dryer
Heating & Cooling Logo
153 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
