Question about Ibico 1230 Calculator
I have an Ativa AT-714 desktop calculator. Instructions say one can do square roots, but there's no button for this
How do i find the square root of a number on the casio scientific calculator
If, for example, you're getting the square root of 3 as the square root of 3, press the S-D button (just above the DEL) button to convert the symbolic result to a decimal result.
If you want all results to come up in decimal, press SHIFT SETUP 2 to select the LineIO mode.
Feb 03, 2015 | Casio fx-115ES Plus Scientific Calculator
Square root in answer
Press SHIFT [SETUP] 1 to set the MthIO mode.
Try calculating the square root of 8 (press sqrt 8 =). Do you get 2sqrt2?
Mar 03, 2014 | Casio FX-115ES Scientific Calculator
Square root button on FX-570ES plus. trying to find out how, when using the square root button - to stop it from square rooting the entire equation... eg if i want to work out
Press right-arrow when you're done with the argument of the square root. For example, from page E-15 of the manual, to calculate 1 + square_root(2) + 3, press 1 + square_root 2 right-arrow + 3 =
Jul 21, 2012 | Casio FX570ES Scientific Calculator
How do I simplify a cubed root of a number on the fx-300ES?
It can handle square root but if result requires too much display space it will be displayed as a decimal.As to higher order roots such as cube , 4th and higher they are displayed as decimal. Sorry, there is nothing you can do about it.
Apr 18, 2012 | Casio fx-300ES Calculator
Which button do I use for the square root button? I have to perform math problems on... geometric mean population standard deviation sample standard deviation
The square root button is two up from the 9 key, just to the left of the divide key. To calculate the square root of 2, for example, press 2 square-root =
Jun 10, 2011 | Texas Instruments TI-30XA Calculator
How do you calculate the square root?
First of all, here is a direct link to the ONLINE USER'S MANUAL for that model:
http://education.ti.com/guidebooks/scientific/30xii/30xiiqrg-eng.pdf
To view the Owner's Manual with Operating Instructions just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information at the website indicated or the contents of the Owner's Manual.
You may need ADOBE READER installed on your computer to read PDF documents. You can download this free at WWW.ADOBE.COM if necessary. Click on the DOWNLOAD ADOBE READER button on right side of the ADOBE home page when you get there, and then just follow the onscreen instructions to install it.
See page 3 of the ONLINE USER'S MANUAL for detailed instructions on how to calculate the square root of a number.
Basically you just do the following:
Press the SECOND FUNCTION button (2nd),
Then press the SQUARE ROOT button (looks like a checkmark),
Then type in the number you want the square root of (say 25),
Then hit ENTER.
The answer should be 5.
Thank you very much and good luck.
Apr 17, 2011 | Texas Instruments TI-30 XIIS Calculator
How do i find the square root using TI30XA?
The square root button is the button to the left of the division button and to the right of the square button. So enter the number first, then press the square root to find your answer.
Mar 03, 2011 | Texas Instruments TI-30XA Calculator
Were is the square root button on the TI-30XIIS and how do I solve, what is the square root of 62
Square root is the 2nd function of the square key, to the left of the 7 key. To compute the square root of 62, press 2nd [square-root] 6 2 ) =
Nov 15, 2010 | Texas Instruments TI-30 XIIS Calculator
How to calculate a square root number after pressing the 2nd button? For example, one of the problems i was asked was, 105625 all in square root by pressing 2nd, x^2 105625) and enter. But I cannot find...
Are we discussing squares or square roots?
The square root is the 2nd function of the multiply key.
There is no square function on the keyboard. Instead, simply raise the number to the second power using the ^ key just above the divide.
Sep 04, 2010 | Texas Instruments TI-89 Calculator
Need to know how to do squre roots step-by-step
type 2nd then the square root sign and type in the number u need. the close off the parenthesis and hit enter
Sep 25, 2009 | Casio FX-300MS Calculator
Ibico 1230 Calculator Logo
260 people viewed this question
Top Ibico Office Equipment & Supplies Experts
jasbo
jasbo
Are you an Ibico Office Equipment and Supply Expert? Answer questions, earn points and help others
