Question about Danby DPAC12031 Air Conditioner
My Split system Centrex CTAR60GW turns off about 10 minutes of cooling, the actual unit flashes on the timer button, have cleaned it replaced batteries and had 4 technicians out to have a look all of which says their appears nothing wrong with it. I am over paying call out fees for someone to tell me nothing is wrong when clearly there is as we are roasting in my house. I can turn the system on during the evening from about 10.00pm and it works fine throughout the night until morning when the outside temperature heats up
  • 2,133 Answers
Dear friend. the timer problem is very common. Remove battery from remote and also remove power to unit. Again plug power on unit and start with remote and try to cancel the timer on and off. Press set.
And also cool setting must be minimum 3 degree less than room temperature. Helpful advise?
Posted on Dec 31, 2010
I have centrex Air Cond. Model CTAR60GW.Does it meet the EER Rating above 2.9?
Centrex should be able to confirm the EER if you inquire.
Dec 04, 2014 | Heating & Cooling
Centrex CTAR60GW not working
maybe you don-t respect the polarity(+ - )on the remote control or a imperfect contact on battery
Dec 04, 2013 | Haier hwr10xc6 Air Conditioner
The operation and timer lights on my Fujitsu split system are flashing on and off several times when the unit is switched off I noticed this after the system had stopped blowing air & I knew the room...
I have same problem like yours to my newly installed Fujitsu multi-split system (the first time use since system installed 1 week ago). I rang the electrician who did the installation; he said it must be the units themselves nothing to do with electricity.
Okay, then I rang Fujitsu and their local service agent. They suggested me to switch off C/B for an hour to reset the units. I followed the instruction but the indoor units still did not respond to remote control...
It simply looks like no power supply to indoor units (they are hard-wired to the outdoor unit). So I used a multi-meter to test the power terminals of indoor units (Danger! If you have no idea about this, don't even try! ): it seemed no power supply even C/B is on. I turned to the isolator which next to the outdoor unit. The isolator was making arcing noise when I switched it on and off. The indoor units suddenly turned on for few minutes then died again.
So I figured out the problem is that crooked isolator. I called the unhappy electrician to replace the isolator. End story....
I hope my experience will help you a little bit.
Jul 11, 2010 | Fujitsu 24C1 Air Conditioner
I have a Centrex air keeps tripping breaker
The first thing I would check is the outdoor unit coil and see if it is restricted(dirty). If that is the case then you can wash it off with water(make sure you shut the power off to the unit first). If the outdoor coil is restricted and has little air flow thru it ,it can't get rid of the heat from the space and the compressor will draw over amperage and trip the breaker.
The next thing to check is if the outdoor fan is running. If the fan doesn't run it is the same as the restricted coil, it can't get rid of the heat from the coil. Check these things first then we can go from there! Thanks!!
Nov 22, 2009 | Heating & Cooling
Centrex a/c keeps shutting off every 15 minutes ( split system)
To start, check your condencer fan and make sure the condenser is clean.After that you will need a technician with instruments. If the switching off is constant, after approx. every 15 min.it could be switching off on high pressure.
Feb 02, 2009 | Heating & Cooling
Panasonic large screen Model # PT-61LCX65
Here is the proceedure to replace the lamp and reset the lamp hours.
Lamp Replacement Procedure:
1. Press the POWER button to turn off the power.
2. Wait for about 1 minute until the cooling fan stops.
Note:
The lamp cooling fan will continue to operate for about 1
minute after the power is turned off. Do not unplug the AC
Cord from the outlet until the fan has stopped. Avoid
interrupting the power by using circuit breakers or switchable
power strips.
3. After the cooling fan has stopped, unplug the AC Cord from
the outlet.
Note:
Please wait more than one hour before replacing the lamp.
[ Forced cooling function ]
If you need to replace the lamp more urgently:
- The Projection display has a forced cooling feature.
After the POWER button is turned OFF, and during the
first minute of the normal cooling fan operation, press
the VOLUME UP button on the unit and CH UP key on
the remote at the same time for more than 5 seconds.
The cooling fan operates for about 10 minutes. (LAMP
LED will flash 5 times every 5 second and POWER LED
will flash red for 10 minutes.)
4. Remove the Front Cover Unit from the latches.
5. Turn the Knob to the left.
6. Pull the Lamp Cover out.
7. Loosen the Screw on the Lamp. Then, pull the Lamp.
Note:
Because the Lamp may still be hot, use caution when
handling.
8. Install the new Lamp, and tighten the Screw.
9. Install the Lamp Cover, and turn the Knob to the right.
10. Install the Front Cover Unit.
Lamp Time Reset Procedure:
Be sure to reset the Lamp time to "0" after replacing the new
Lamp.
1. Plug in the AC Cord, and turn on the power by pressing the
POWER button.
2. Press and hold the VOLUME DOWN button on the unit and
the SPLIT key on the remote together for over 5 seconds
in power on condition.
When the reset is finished, the display will indicate that the lamp hrs have been reset to 0 and the LAMP LED goes out.
Jul 26, 2008 | Panasonic PT-61LCX65 61" Rear Projection...
Centrex split system air conditioner
I have a centrex split system which the inside unit is working but the outside one the motor is not working does anyone know why and where can i get parts from sice centrex no longer exists..
Nov 18, 2007 | Heating & Cooling
Danby DPAC12031 Air Conditioner Logo
332 people viewed this question
Top Danby Heating & Cooling Experts
coolfelix
Level 1 Expert
Dan Webster
Dan Webster
Dennis Boxerman
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
