Question about LG LMVM2075 Microwave Oven
My 2055 went completely powerless - LG LMVM2075 Microwave Oven
  • LG Master
  • 17,130 Answers
If there is no heating please do not switch on unless you have confirmed the fault. It is possible that the Magnetron is faulty, the temperature cut off is faulty or the main capacitor is short. It is also quite possible that insect can get into the oven and create soft spots. When you switch on these will create a short and make the voltage jump and in the long run damage the magnetron.
So Remove cover after disconnecting , check for dirt/moisture in the cabin, if so wipe clean and dry, check the magnetron and area clean and use an jet air to clean off.
Make sure that the program controller is working if not check power - step down supply, the pads are responding- if not faulty pads- or the door switches, if contact is not through the microwave will not work.
Now keeping clear of the microwave, switch on, use a cup of water inside to test.
If you notice any sparks shut off as the magnetron or the main HT capacitor can be faulty. replace with same type.
If there is heating without any issues, you can use the microwave safely
Posted on Dec 31, 2010
Display blank, power source OK.
A thermal switch probably sensed the temp as too high and opened. If it did not reset when cooled down then the thermal switch is of the type that required replacement. Take it to a repair shop unless you are capable of making electrical checks and doing this safely.
Jan 02, 2014 | Maytag MMV5207 Microwave Oven
No electrical power. power to microwave ok. microwave completely powerless
going to have to look inside for the ac line fuse it has. good or bad?
Dec 22, 2012 | GE JVM1850DMBB 1.8 Cu. Ft. Over the...
We installed a GE Spacemaker Microwave. I put some potatoes in and the microwave was working, suddenly it went off. No light nothing, it just went completely dead. Came back ON after 15 mins,started...
The main fuse may be intermittent, causing complete power failure, the other possibility is a defective door switch not operating properly, or loose plug in the power feed, I suggest a technician to take closer look at the system because this could prove tricky to find the culprit.
Jan 26, 2011 | GE Spacemaker JVM1640SJ Microwave Oven
LG LMVM2055ST Microwave. went completely dead, completely
I replaced outer door with key panel on my LG MICRO MODEL LMVM2055ST which solved my problem but when I went to put the handle back on it did not fit. The tophole in new panel for the handle is round and the old one is rectangle. LG says I have right part can not help me.A new handle comes rectangle shape. What now?
Mar 15, 2010 | LG LMVM1935 Convection/Microwave Oven
Same Problem - Suddenly Died ~2yrs old, very light use.
Probably a fuse inside the unit. Can be caused by overheating or by door switches not working properly.
Sep 10, 2009 | Panasonic NN-P794SF Microwave Oven
Frigidere PLMV169
the internal fuse has blown, if your capable undo the screws on the casing and the check all the fuses
Jan 31, 2009 | Frigidaire PLMV169DC Microwave Oven
Frigidere PLMV169DCD
You most likely had a power surge and blew a fuse. First unplug the unit,then remove the top grill. There will either be one screw on top of the control pad or 2 on the left side. open the control panel and look for a fuse that has a ceramic center and replace it with a 20 amp one. You can find these at the hardware store
No Power
A microwave can be dead for many reasons.
It may be the fuse, which is usually located behind the grille or on the floor of the oven behind the control panel or between the door switches.
If the fuse is good, it may be an open thermostat or thermal cutout (TCO) / thermal fuse on or near the magnetron or on top of the cavity / body of the oven.
If it goes dead for a while during or after cooking then comes back on, the magnetron is probably overheating and causing the magnetron thermostat to open.
Then when it cools, it closes the circuit and allows power through again.
When checking thermostats, if it has a hood fan thermostat, that should read open, as opposed to the others, which should read closed.
If it went dead almost immediately after pressing the Start pad, that's usually a shorted high-voltage capacitor.
If it went dead a few seconds after pressing the Start pad, that's usually a failing high-voltage transformer.
If it goes dead or blows the breaker (or GFI) when you plug it in or open or close the door, then there's a problem with a door switch or door switch mount.
If it's intermittent or random, it may be a bad connection, usually on the control board or a loose fuse holder, or even an intermittent fuse.
You should do a continuity test on the fuse while it's in the holder (with the microwave unplugged, of course) then turn the fuse by hand or take it out and put it back in, then test it again.
If you remove the fuse, then press the meter leads against the ends, it can allow internal contact to be made and make a bad fuse appear to be good.
If you or someone you know decide to look into it, we have critical safety information and disassembly information at our site, and our link is at our listing here on FixYa.
There should also be a "mini-manual" hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting & testing.
You can usually find helpful exploded view diagrams and order parts by entering your full model number here.
Aug 12, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Powerless microwave
The HV capacitor or the HV diode may be in short, check these parts, discharge the capacitor before touching anything.
Maybe something is shorted to ground.
Feb 16, 2008 | Sharp R-1490 Microwave Oven
LG LMVM2075 Microwave Oven Logo
Top LG Microwave Ovens Experts
William Miller
William Miller
Chuck
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
