Question about DeLonghi BAR 14 Espresso Machine
Filter holder does not align with arrow on top, and is therefore off center, even when pushed very firmly.Shall I take it back to the shop or try and use it?
  • 784 Answers
If you bought it new and it does not line up right -- I would take it back to the shop you bought it from and get a replacement. espresso machines work with very high pressure and HOT water and this COULD cause severe burns and it is not worth taking the chance. ( now there is a chance that things were just milled out wrong and even though it does not look like it is lined up, it might work fine -- but why take the chance ? ) -- when in doubt,, play it safe.
c...
Posted on Dec 31, 2010
Canon Printer i550 Printer will not start, but warning light flashes green/yellow green etc. Flashing does not stop if press right hand button Flashing still goes on after re-installing printer...
this is the service error for this you have to reset ink counter, it's available on your manual.
or you can use utility like ip tools available free on net
Oct 13, 2008 | Canon Office Equipment & Supplies
Don't have a manual, just need to know how to change ink and toner cartridges:)
Step 1
housing beneath. If done correctly, the print cartridge carrier should move into the loading position near the center of the unit.
Step 2
Push down on the colored cartridge lever at the front of the carrier to unlock and pop up the cartridge lid.
Step 3
Pull the spent cartridge from the printer.
Step 4
Pick up your new cartridge. Pull the sticker and tape gently from the back and bottom to reveal the gold metal electrical contacts.
Step 5
Insert the new cartridge into the print cartridge carrier with the electrical contacts facing down. Press the cartridge gently but firmly into the carrier so that the contacts on the cartridge touch the contacts in the carrier.
Step 6
Close the cartridge lid over the new cartridge until it clicks into place.
Step 7
Lift the scanner unit up slightly so that the scanner support arm unlocks. While holding the unit up with one hand, push the support back into its storage slot with your other hand and carefully lower the unit back into its original position on your printer.
Step 8
Press the third button down from the top on your control panel---marked by an arrow pointing from a scanner icon to a computer icon---for three seconds to print out a print alignment page. When finished, follow the on-screen instructions.
  • Step 2 Push down on the colored cartridge lever at the front of the carrier to unlock and pop up the cartridge lid.
  • Step 3 Pull the spent cartridge from the printer.
  • Step 4 Pick up your new cartridge. Pull the sticker and tape gently from the back and bottom to reveal the gold metal electrical contacts.
  • Step 5 Insert the new cartridge into the print cartridge carrier with the electrical contacts facing down. Press the cartridge gently but firmly into the carrier so that the contacts on the cartridge touch the contacts in the carrier.
  • Step 6 Close the cartridge lid over the new cartridge until it clicks into place.
  • Step 7 Lift the scanner unit up slightly so that the scanner support arm unlocks. While holding the unit up with one hand, push the support back into its storage slot with your other hand and carefully lower the unit back into its original position on your printer.
  • Step 8 Press the third button down from the top on your control panel---marked by an arrow pointing from a scanner icon to a computer icon---for three seconds to print out a print alignment page. When finished, follow the on-screen instructions.
  • Read more: How To Change the Ink Cartridge in a Lexmark X2470 | eHow.com http://www.ehow.com/how_6646584_change-ink-cartridge-lexmark-x2470.html#ixzz0wg8UCkTs
    Aug 15, 2010 | Lexmark X2470 All-In-One InkJet Printer
    Keurig B60
    Check the needle inside the k-cup holder to ensure it is not clogged. You can completely remove the k-cup holder by pushing up from the bottom (where it dispenses into your coffee cup). Then rinse it out with hot water using your kitchen sink sprayer. The manufacturer also recommends inserting the tip of a small paper clip into the needle to push out any debris if needed. Then replace the k-cup holder by aligning the arrows and snapping it back into place. Next try to brew your regular cup of coffee and see if that fixed the problem. Hope that worked for you...Best of luck!
    Aug 29, 2009 | Keurig B60 Coffee Maker
    My mother decided to make a cup of coffee. She
    Make sure the k-cup holder is snapped completely back into place. If the arrows aren't aligned and you don't snap the arrow-side in first, it won't work. If that doesn't do it, check your water reservoir to ensure it is properly seated in it's base. Hope that helps...best of luck!
    Jul 14, 2009 | Keurig B60 Coffee Maker
    How do I take out the water filter?
    Found at Kitchen Aid website, Good luck
    Changing the Water Filter
    1.
    Press the eject button to release the filter from the base grille.
    2. Pull the filter straight out.
    3. Turn the cap counterclockwise to remove it from the filter.
    IMPORTANT: Do not discard the cap. It is part of your
    refrigerator. Keep the cap to use with the replacement filter.
    4. Align the ridge on the cap with the arrow on the new filter and
    turn the cap until it snaps into place.
    NOTE: You can run the dispenser without a filter. Your water
    will not be filtered. Simply insert the cap all of the way into the
    base grille and rotate the cap until it is firmly in place.
    5. Remove the protective covers from the O-rings.
    6. Push the filter into the base grille. The eject button will pop
    back out when the filter is fully engaged.
    7. Flush the water system. See “Water and Ice Dispensers.”
    Jun 30, 2009 | KitchenAid Superba KSCS23IN Side by Side...
    Installation cabin filter 2006 Acura TL
    need to remove glove box(mounted withscrews from bottom edge)once glove box removed you will see basically in dead center of glove box opening a approx.1" wide plastic black strap going from top of heater box straight down and wraps towards ft of car. remove bolt from top this strap,it will then pull downnwards and unhook from heater box.this opens up slot in heater box that you see a white holder assy slid into slot .grab ahold of tab and pull outwards removing from heater box. this holder for filter.replace filter(pay attention to directionof flow arrows on filter)slide back into heater unit(has guides it slides into)and reinstall glovebox etc....good luck! Joel
    Mar 21, 2009 | 2006 Acura TL
    Change battery
    Normal 0 If the mouse doesn't have a little door to open on the bottom, then try this. Just behind the Left and Right keys where your hand rests, apply firm pressure down on the cover and slide to the rear. Some mouse manufactures have used this type of access to replace the batteries.
    Hope this helps. Bud
    Jan 12, 2009 | GE Optical Mini Mouse ho98094
    I have a hpdeskjet f2180 and need to change the ink cartridges. How do I get to the cartridges to change them !
    Installing print cartridges
    1. Make sure the HP All-in-One is on. CAUTION: If the HP All-in-One is off when you open the print cartridge door to access the print cartridges, the HP All-in-One will not release the cartridges for changing. You might damage the HP All-in-One if the print cartridges are not docked safely when you try to remove them.
    2. Open the print cartridge door. Figure 1: Opening the print cartridge door c00906461.jpg Make sure the print carriage moves to the center. If it does not move to the center, turn the device off and then turn it back on again.
    3. Remove the tape from both cartridges. Figure 2: Removing the tape from a cartridge c00651128.gif CAUTION: Do not touch the copper-colored contacts or re-tape the cartridges. Figure 3: Copper-colored contacts c00651129.gif
    4. Hold the cartridges with the HP logo on top.
    5. Insert the tri-color cartridge in the left cartridge slot and the black cartridge in the right cartridge slot. Figure 4: Carriage slots c00853116.jpg Figure 5: Inserting the tri-color cartridge in the left slot c00853117.jpg
    6. Make sure you push the cartridges in firmly until they snap into place. Figure 6: Pushing the cartridge in firmly c00853118.jpg Figure 7: Tri-color cartridge and black cartridge correctly installed c00853119.jpg
    7. Close the print cartridge door. Figure 8: Closing the print cartridge door c00906462.jpg
    Aligning print cartridges The HP All-in-One prompts you to align cartridges every time you install or replace a print cartridge. You can also align the print cartridges at any time from the control panel or by using the software you installed with the HP All-in-One. Aligning the print cartridges ensures high-quality output. NOTE: If you remove and reinstall the same print cartridge, the HP All-in-One will not prompt you to align the print cartridges. The HP All-in-One remembers the alignment values for that print cartridge, so you do not need to realign the print cartridges. To align newly installed print cartridges
    1. Make sure you have letter or A4 unused plain white paper loaded in the input tray. The HP All-in-One prints a print cartridge alignment sheet. NOTE: If you have colored paper loaded in the input tray when you align the print cartridges, the alignment will fail. Load unused plain white paper into the input tray, and then try the alignment again.
    2. Load the print cartridge alignment sheet print side down on the left front corner of the glass with the top of the page to the left. Figure 9: Loading the alignment sheet c00906464.jpg
    3. Press the Scan (c00906465.jpg ) button. The HP All-in-One aligns the print cartridges. Recycle or discard the print cartridge alignment sheet.
    Jul 29, 2008 | HP Office Equipment & Supplies
    DeLonghi BAR 14 Espresso Machine Logo
    61 people viewed this question
    Top DeLonghi Coffee Makers & Espresso Machines Experts
    Henry  Thomas
    Henry Thomas
    Shehu Pro
    Shehu Pro
    Are you a DeLonghi Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
