Question about Dell Computers & Internet
When i go to turn on my dell laptop it makes a ticking noise like a clock and then it goes black does not load up and tells me it cant find the internal hard drive.
    Genius:
  • 1,288 Answers
Assuming there is no CD in the drive, the ticking sound you describe sounds like hard drive activity, or at least a hard drive that is trying to actuate. Did you or someone else drop the laptop? This is normally a result of the reading heads being out of alignment with the disc platters, a damaged bearing, or a power isssue to the drive that is preventing the reading heads reading the disc platters.
Either way, it is normally a harbinger of death as far at the hard drive is concerned, you will most likely need to replace the drive.
SOMETIMES, you can get the hard drive working one last time to pull any data off you need, this can be done by (assuming it is a SATA drive) connecting it to a spare SATA port on another computer and getting the data copied off. One extreme measure is to place the drive in a sealed bag to prevent condensation and stick it in the freezer for a day, before connecting it to the computer.. I used to laugh at this but it does work.. causes the disc platters to contract and gives enough time to recover data before it warms up again
Posted on Dec 31, 2010
My laptop does not work, when I turn it on, it just makes a clicking sound.
MOST LIKELY HARD DRIVE FAILURE. HAVE IT TESTED BY A LOCAL SHOP. WHEN YOU DO JUST GET AN ESTIMATED ONLY AND THEN MAKE A DESION IF IT IS WORTH THE COST. IF YOU ARE TECH SAVY JUST DISCONNECT THE HARD DRIVE AND SEE IF THE NOISE GOES AWAY. GOOD LUCK.
Oct 25, 2014 | Computers & Internet
Tick tick tick noise
Make sure there is no disc in the cd/dvd drive. make sure that fan vents are clear. Does this start when you turn it on, or when it warms up after about 5-15 minutes? The only stuff that moves in a laptop is a dvd drive, a fan or the hard drive (unless you have an SSD installed). The ticking noise may be one of these. The dvd drive is not an immediate problem unless you need it, NOW. The other two options are definitely important and I would not putoff getting this looked at, as they are internal and difficult to get to. If you are comfortable opening and working in a laptop that you are ahead of the game, but I can go no further, with so little information.
Nov 02, 2013 | Dell Inspiron Computers & Internet
Turn on...makes clicking noise, nothing happens. Minutes tick down and then goes to pause. door is not locking. Cleaned filter, only found one cent.
The door lock mechanism is easy to replace. The fact that there are a hundred for sale on eBay tells you how often they break. If the door doesn't lock, it wont fill or do anything else.
Sep 13, 2011 | General Electric WCVH6800J Front Load...
Ticking when cruising and not under load or going down hill
Not a lot of information to go on. I really need more. Is the sound coming from the engine, transmission, rear wheel, front wheel, or you just can't tell? Does it tick when going down the road with the clutch lever pulled in? While you have the clutch lever pulled in, turn the engine off and see if it goes away. Try different things in order to get a "change" in the noise. Once you find something that makes the noise change, then figure out why.
Now, you're ticking could be an exhaust leak somewhere. Look for black soot around the exhaust pipe joints. I could also be rock hung in your drive belt. Roll the bike and look on the inside of the belt for a small rock or something hung in it.
Ride Safe
Steve
Jan 01, 2011 | Harley Davidson FLHT Electra Glide...
When i turn on my laptop it makes a beeping noise for about 15 seconds.the screen also goes black after this for about the same time.then the laptop works fine just wondering what may be the cause of this.
Hi there, I am also facing same problem with my Dell Inspiron mini 1012, when i turn on my laptop it makes a beeping noise for about 15 seconds.the screen also goes black after this for about the same time.then the laptop works fine just wondering what may be the cause of this. S Bhat, India
Nov 01, 2010 | Computers & Internet
My laptop says Time -of -day clock stopped when i turn it on
It sounds like the battery on your computer is dying, and the battery cannot keep the clock running. If Dell's warranty is still valid, contact Dell, to get your computer fixed/replaced.
Dec 08, 2009 | Dell Computers & Internet
Timer is making ticking noise cant turn it off.
My same oven makes a ticking sound when you tell it to start pre-heating the oven. The oven continues to make this ticking sound until you stop the oven and it completely cools down. This ticking sounds to be coming from the oven control panel. I have no solution, but I'm glad I wasn't the only one who had a problem with this ticking sound!
Jul 15, 2009 | Ovens
Computer seems to locked up.
The Bios battery is probably dead. It is installed on the motherboard, replace the battery.
May 12, 2009 | Dell Inspiron 1525 Laptop
Inspiron B130 won't boot
plz try to boot through safe mode, if you can then log in normally.
if you cant boot from safe mode then you have to reload or repair your os.
Dec 23, 2008 | Dell Inspiron B130 Notebook
Computers & Internet Logo
66 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
