Question about Brother DCP 165C Compact Color Inkjet Multifunction Printer
Multi-functions suite cc3-001-00001907 - Brother DCP 165C Compact Color Inkjet Multifunction Printer
5 Suggested Answers
  • 2692 Answers
SOURCE: Printer Drive Problem
Download updated software and drivers.
The Brothers support site for your printer below.
http://www.brother-usa.com/downloads/default.aspx?ProductGroupID=1&WT.cg_n=Support&WT.cg_s=Downloads
Posted on Jan 06, 2009
SOURCE: Hey there, I was trying to
I guess I found a solution for the problem.
I also got this error message after installing ControlCenter3. Failed to start ControlCentre3 - re-install software, with the error No CC3-001-00001907. The numbers at the end can change, but that's not important.
I have two laptops running vista. I got this error with the 1st laptop. Then I tried it with the second laptop, it worked fine. That made me think: On the first laptop I had tried to install the ControlCenter3 from the CD, but it turned out that the CD did not support Vista. Then I got the vista driver/ControlCenter3 package from the Brother website. This is the one that did not work on laptop one. What I then guessed was, that I had some ugly remains from the installation of the old driver (not for vista). I started cleaning the registry. First of all I run the driver uninstall program from Brother (free from their website) then I cleaned the registry with CCleaner (freeware). Still that was not enough. I started the regedit program and started searching for the term Brother. It was still there in about 10 or more places. I deleted all records that were connected with my brother printer (a DCP-130C). Then I run CCleaner once more. Then I installed the vista driver package (from brother website). Restarted and voila: it worked. ControlCenter3 workes fine now. I started the ControlCenter3 update (also on brother website) and finally with the scanner utility put the scanner resolution limit up higher. That's it.
Before working with the registry make a backup, please.
This procedure should also work for other brother printers using the controlcenter3. It should also work for other systems than vista.
Cheers, hope this was helpful.
Edi
Posted on Jun 11, 2010
Kaiji
  • 66 Answers
SOURCE: Using Windows 7, Trying to
After doing a bit of reading, it seems the Brother MFC-240C model is discontinued. I didn't see any support for windows 7, so what we can try is changing the compatibility.
1) Uninstal the suite/drivers, then restart your computer.
2) Reinstall the suite/drivers and restart your computer once again.
3)Look for BrCtrCen.exe in the directory of where ever the suite is installed.
Should be either
C:\Program Files (x86)\Brother\ControlCenter3\BrCtrCen.exe (for 65 bit windows)
C:\Program Files\Brother\ControlCenter3\BrCtrCen.exe (For 32 bit windows)
4) Right click BrCtrCen.exe, go to compatibility options and set the compatibility to vista.
Information source:
http://www.sevenforums.com/drivers/6086-brother-mfc-240c.html
Posted on Mar 28, 2011
  • 826 Answers
SOURCE: there is no multi function suite in windows 8
I don't have proper idea..but you can try these steps:
1. Click the Start button Picture of the Start button, click All Programs, and then click Windows Fax and Scan.
2. On the toolbar, click New Fax. If it's the first time you're sending a fax, you'll be prompted to complete the Fax Setup wizard.
3.When you're finished creating your fax, click Send.
If need any help on windows 8(fix windows 8 solution) then you can get technical help from here:http://www.vtechsquad.com/
Posted on Nov 16, 2012
Brother printer doesn't print
Go to the manufacturer's web site and download the suite again. Also good to check if Apple has a driver, go to Systems Preferences, Printers and try installing it and see it a printer driver exists.
Feb 26, 2014 | Apple iTunes
There is no multi function suite in windows 8
Nov 15, 2012 | Brother MFC-6890CDW Printer
Lost cd rom 5860 brother which to use
Go to the BROTHER Solutions Center and download the software Suite for your printer. The OCR software (PaperPort) will have to be replaced by some other one. You may also contact Brother to have a copy of the original disk mailed to you (it is not free).
Aug 16, 2011 | Brother Multi-Function Center MFC-5860CN...
Using Windows 7, Trying to install printer, Brother MFC-240C. When computer starts or restarts Small window reads: Failed to start the ControlCenter. The required registry information is missing. Please...
Should be either
Information source:
Mar 28, 2011 | Office Equipment & Supplies
I need a sight to download the mukti function suite
i believe you want the brother website to download their drivers. it is:
this for windows xp
http://welcome.solutions.brother.com/bsc/public/us/us/en/dlf/download_index.html?reg=us&c=us&lang=en&prod=mfc240c_all&type2=-1&os=7&flang=English&dlid=
May 07, 2009 | Brother Multi-Function Center MFC-240C...
Brother MFC-665CW
download the uninstall drivers from brother homepage of your country. Run the uninstall routine, reboot pc and uninstall the rest of the mfl-pro suite. After rebooting pc install the suite again. (hope you didnt connect the printers first, when installing the suite! Printer has to be connected when software demands the printer!)
BTW there is an update avaiable for the CC3 version (see brother homepage).
Dec 27, 2007 | Brother Multi-Function Center MFC-240C...
Printer won't install
Unistall delete old drivers from system before installing the full driver and software package (which includes MFC suite), brother have a unistall driver program on web site
MFC suite will enable scanning etc, drivers don't do that
Oct 19, 2007 | Brother MFC 8820D All-In-One Laser Printer
Brother DCP 165C Compact Color Inkjet Multifunction Printer Logo
461 people viewed this question
CheckitRight
CheckitRight
Ron Dufek
Ron Dufek
James Cagle
James Cagle
