Question about Hotpoint Ultima WF860 Front Load Washer
My partner's Hotpoint WT960 makes very loud grinding sound when spinning. I suspect the drum bearings are gazacked. Do I need to change the drum support and bearings & seal or just the bearings? Is it a difficult job? Can I get better quality bearings from somehwere like Wyko or similar? Fuinny thing is - I have an identical macjine and so does my daughter and they are great. May be problems ahead for all three. Your help would be much appreciated. Joe.
  • Hotpoint Master
  • 3,463 Answers
Hi Joe.
A lot depends on construction of drum.
Remove the top cover and look at the plastic outer container, if it is a one piece consonstruction, then unfortunately you cannot fit new bearings, as it it comes supplied as a complete unit.
However, if you can see the 2 drum halves held together with screws, then you can fit new bearings.
You will not know if the spider or drum shaft needs to be replaced until the it is stipped down, a fifty- fifty chance
It is an involved repair as it entails removing the whole container from the cabinet, and do not fit any other bearings than the genuine ones.
It comes as a bearing and seal kit from Hotpoint.
WWW.HOTPOINTSERVICE.CO.UK
Good luck
Posted on Dec 31, 2010
Testimonial: "Many thanks for the quick response and the advice, mate. Better get my tools out.... Joe."
    President:
  • 3,433 Answers
Easy fix. Pick up new rollers, and replace old. Sounds like you already have it apart
Posted on Jan 01, 2011
Hi, My Hotpoint TVM570 Aquarius is making a loud screeching noise occasionally. It isn't doing it every time my partner just used it for an hour with no issues. However I used it for 5 minutes this...
wonder if you are overloading the machine and the noise is the drive belt screeching. if it sounds similar to a loose fanbelt on a car, it could be drum bearings that are seizing up (check by manaually rotating the drum. if it spins freely its ok) or the drive belt is getting worn and needs replacing
May 09, 2014 | Washing Machines
LG direct drive washer makes loud grinding noise
Check presence a stranger subject in drum. Shine the torch and swing the drum.
If rubbish no that necessary to change the bearings.
Nov 12, 2013 | LG Washing Machines
Hotpoint WT965 is making a loud noise when spinnig
Suspect bearings. With door open wiggle the top of the silver drum If it moves up and down inside the tub, replace the bearings
May 15, 2012 | Washing Machines
Spin cycle
Most likely your drum bearings are worn out. This is a major repair.
You may be better off replacing the machine.
Ash
Oct 22, 2009 | Hotpoint Aquarius WF220 Front Load Washer
Loud grinding noise when dryer is on aslo blew fuse last night
sounds like bearings in your ctd40
We have made a few videos on these dryers and there are some very good repair guides on these.
if you need parts please feel free to see site or contact me with the full model number of the ID plate How-to-Repair
How replace the bearing kit
And if you have the type with a fixed Riveted Drum shaft then you will need this video
In our repair guides you will find help on all the tumble dryer problems
How to Repair Need help fixing your appliances Need help fixing your appliances
Dec 09, 2008 | Hotpoint TDC32 Electric Dryer
Loud noise when it spins
Sounds like main drum bearing noise, try turning the drum by hand, if it feels rough or you can hear it grinding or rumbling, then it is the the main bearings that have failed..
You will probably need to call an engineer.
Dec 03, 2008 | Washing Machines
How to replace drum bearing for hotpoint aquarius+ wf740
My machine is just over 3 years old and although there is no play in the rear drum bearing it is very noisey on spin.
It gets progessively loud the faster the spin speed.
Jun 18, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint ultima wt960 washing machine noisy on spin
Bearings faulty or another fault this model suffers from is the concrete balance weight retaining bolts shake loose, if it is the bolts tighten up as soo as possible. Regards Advisor
Aug 21, 2007 | Hotpoint Ultima WF860 Front Load Washer
Noisy spin loose drum
drum bearing need need bearing kit and drum support £60 plus labour at similar price. Appliance Doctor
Feb 02, 2007 | Hotpoint Ultima WF860 Front Load Washer
Hotpoint Aquarius 1100 - Grinding Noise From Drum
This sounds like the min bearings have gone, open the door and see if there is any play up and down on the drum. if so its the bearing if not it could be something that has fallen from a pocket and got stuck between the metal clothes drum and the oute drum casing. a take apart job i am afraid for both issues.
Oct 29, 2006 | Hotpoint Aquarius WD63 Front Load...
Hotpoint Ultima WF860 Front Load Washer Logo
822 people viewed this question
Top Hotpoint Washing Machines Experts
puggy666
Level 1 Expert
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
