Question about GE 29897GE1 Corded Phone
How do you adjust the ring time for when a call is coming in?
  • 121 Answers
IN THE SIDE OF THE PHONE THERE WILL BE ONE BUTTON WHICH CONTROLS THE RING VOLUME. ADJUST IT SO THAT THE RING TIME INREASES... THANK YOU HAPPY NEW YEAR
Posted on Dec 31, 2010
Elevation adjustments do not seem to hold or the scope moves slowly over time. I'm not certain. Windage works fine. Looked at manual on the web and the scope must have changed design because not...
Most of the time a scope that creeps off its zero, has a loose mount screw and or loose mounting ring. Check the mounts all screws. Some times the opposite is true. The mounts are to tight and in a bind. Then during firing the receiver heats up an tweaks the scope enough to cause creep. If the scope is always on zero when cold and creeps off after a few shots, she is in a bind. Make all adjustments to the scope base and rings with a cold gun. Loosen the front ring screws first then re-tighten then loosen the rear doing the same. Then try and re-zero the gun. If the gun never comes back to zero, you end one day shooting hi to the right and try again the next day shooting in the same spot try to re-tighten all screws. Screws from mount to gun then scope rings to scope body.
Jan 02, 2011 | Nikon 39x40 Matte Nikoplex Buckmaster...
My ae110 corolla abs light staying on it not coming off what might be the problem
If it has rear drum brakes they might just need adjusted but alot of times on the abs sensors on the front brakes which the abs sensor ring is on the cv axles and if the ring or the sensor which has a wire going to it and its right above the sensor gets any debris in there it could trip the light and make it come on so spray like brake clean on both front sensor rings and the bottom side of the sensors.
Apr 08, 2010 | 1999 Toyota Corolla
Won't come up to temperture
The new style2_bing.gif OPD valves have a small brass ring located in the female fitting on the LP tank. Over time this ring can work loose and then it does not allow the male fitting to fully depress the OPD valve thus reducing your gas flow
Using a small flat bladed screw driver tighten the small brass ring This should solve your problem
IF not you might want to remove the cap (white) on your regulator and try slowly adjusting the regulator, make small adjustments and try the BBQ My Weber if I set the front and back burners to MED I get right at 350 degrees in 60 degree outdoor temps. Adjusting the regulator will take some time to get it right but If it is not your tank it is most likely your regulator out of adjustment
Mar 30, 2010 | Kenmore 700 sq. in. Cooking Area Gas Grill...
Grill won't turn on
Mar 29, 2010 | The Great Outdoors TG475N-2 (NG)
How do i adjust length of time phone rings lg kf310
Call in to Customer Service, listen to prompts for tech support standard customer Service will just Fwd you there, ask the tech that you would like to extend the amount of rings before it goes to your voicemail some providers do it by rings, and i know at&t does it by seconds and if it is by secs good rule of thumb is 5 secs = 1 ring!
Jun 28, 2009 | LG KF310 Cellular Phone
Uniden cordless: Adjusting ring tone volume down
If it is like mine....push on one of the volume buttons (up or down,doesn't matter) and the phone will ring. WHILE IT RINGS, push the button again and it should scroll to the next ring option. Keep pushing WHILE it rings to scroll through the ring options.
May 14, 2009 | Uniden Cordless Phone
Need more time to pick up phone(disabled)
The phone does not have this facillity.However,switching the answer machine "OFF" allows me to lengthen the ringtone to 16 rings as on the Users Guide.
Many thanks for your interest,
Dec 21, 2008 | Lands Phones
Number of rings before answering system goes on
You can adjust the Answer Delay time by going to Menu then DTAD. Adjust the Answer Delay under this menu... 6 seconds per one ring.
If you have auto attendant set up to answer for you in a multiline system, set that delay accordingly. That will be the first system to pick up, You should set up one auto attendant for every voice line coming into your phones.
Dec 18, 2007 | Lands Phones
Tasco propoint PDP2 scope
Are you looking set the eye relief or the focus ring?
For eye relief you need to loosen the scope in the rings, mount the rifle to your shoulder with your standard hold and cheek weld. At this point, slide the scope back and forth in the rings until you obtain a full field of view. Tighten one of the rings slightly, dismount and remount the rifle several times to ensure correct adjustment. Level scope and tighten rings a final time.
For focus adjustment (remember that you are using the eyepiece to focus on the cross hair, not your target!) loosen the lock ring and turn the eyepiece until the cross hair is focused. It is best if you check it several times by closing and opening your eye several times. The crosshair should be instantly in focus. If your eye must adjust, then you need to refocus until the focus is instant.
The two dials on the scope are for adjusting the bullet point of impact. They will typically move POI 1/4 inch at 100 yards.
Nov 08, 2007 | Optics
GE 29897GE1 Corded Phone Logo
75 people viewed this question
Top GE Lands Phones Experts
Computer Repairing
Computer Repairing
Dudeman321
Are you a GE Lands Phone Expert? Answer questions, earn points and help others
