Question about Maytag Washing Machines
My washer last nite kept filling up w water. & never would stop (until i stopped it myself)- its like the Sensot-or full indicatrer? stopped working- & needless to say it fllooded my laundry room, bathroom,hall,etc. is there a sensor of some kind??
  • 784 Answers
There is a water height sensor -- this sensor works via a small tube that is connected to the outside drum and runs down to the pressure sensor,, when water reaches a certain height the pressure sensor stops the fill cycle.
c...
Posted on Dec 31, 2010
  • Maytag Master
  • 17,130 Answers
Yes there is a water level sensor which is incident a pressure switch . As the water loads on the drum there is a small port through which the water goes into this switch which is a diaphragm operated. The pressure of the rising water will build up the pressure on the diaphragm which will click the switch.
If this has failed there wont be any action and the water will build up to overflow.
How can you get a washer smelling good?
First of all this mainly happens when you use cold water washing, the plastic bowl(s) become slightly porous over time & the dirt from clothes adhere to the area between the inner & outer bowls.
To clean & remove smell.
1. Put washer on hot wash, high level & let it fill with HOT water.
2. Stop washer, put in an old towel.
3. Add a bucket of hot water (This allows the water level to be above the scum mark inside machine.
4. Add washing soda to the bowl (double the amount it says on the packet).
5. Start washer & allow to run to the end of the first wash cycle.
6. Stop washer & allow to sit for a few hours.
7. After the few hours, start washer & allow it to run the rest of the full cycle.
you can do the same procedure with Vinegar.
you may have to repeat procedure a few times.
TO PREVENT THIS FROM HAPPENING AGAIN YOU NEED TO DO THIS PROCEDURE ONCE EVERY 3 MONTHS.
The worst case scenario, you will have get a technician to remove the inner bowl & manually clean these areas.
Apr 27, 2014 | Haier HLP21E Top Load Washer
Washer will not fill up!
The water is siphoning out as it fills. Your drain hose is too low or has a air block. Remove the drain hose from the drain. Set the washer to fill. Hold the drain hose up higher than the washer. If it fills correctly and starts agitating,correct the drain hose problem.
Sep 23, 2009 | Admiral AW22 Top Load Washer
Washer filled up for the rinse cycle then stopped won't do anything now. checked the outlet and have power there. Washer still full of water.
first of all you need to empty this washer by pulling the drainage pipe out of the waste pipe at the back then place a bowl on the floor and place the pipe into the bowl until all the water stops,when bowl gets to full then lift pipe higher than the washer to stop water coming out,once empty renew the carbon bushes on the motor as this will be the problem.
Jul 06, 2009 | Washing Machines
Water does not stop running when the washer is full.
turn the water on for a minute,then turn it off,if it stops it's not the water valve,if it does not stop then it's the water level hose or switch that's bad-mike
Jun 04, 2009 | Kenmore 22622 Top Load Washer
GE top load Washer won't stop filling or spinning
Remove the plastic hose from the water level switch and blow through it until it flows freely.
If it does not clear this way. Remove the front panel.putty knife needed.
Remove the water level tube from the tub and clean out the gunk.
Reconnect it to the water level switch.
Set the machine to spin and run it.
Reset water level control and try your machine.
Feb 04, 2009 | GE WBSE2090A Top Load Washer
Tank starts to fill then just stops
if you changed the hoses to no leak hoses change them back
Dec 23, 2008 | KitchenAid Washing Machines
Estate washer, new, water will not stop, overflowing
you need to replace the inlet valve something is stuck in the valve not allowing it to shut.
Dec 23, 2008 | Whirlpool Estate TAWS750PQ 27-Inch Washer
Washer continues to fill after full, then spills all over floor until manual shut off
This is an indication of a pressure switch malfunction. Post back with your washer brand name and model number and I can tell you how to check it.
Feb 23, 2008 | Washing Machines
Estate washer stopped after filling with water
will any of the lights come on when you try to turn on a cycle?
Nov 21, 2007 | Frigidaire ATF6000ES Front Load Washer
Washing Machines Logo
111 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
John Tripp
John Tripp
Dan Webster
Dan Webster
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
