Question about Toshiba Satellite Pro L300 Notebook
Screen is dark. However laptop indicates that it is on
  • 3 Answers
This has happend to me its usally a memory board problem its cheap to fix and should be done by an expert.
Posted on Dec 31, 2010
My screen is dark
You could have a defective LCD screen, If the laptop appears to be running and the hard disk is spinning but the screen is dark then, to determine if you have a LCD screen or video card problem, read this and follow these instructions.
Defective CCFL backlight, it may have the following symptom: Screen flashs on red/pink and off. Picture stays on in red and slowly be come normal. Picture flickering with dim display or appear black. Picture flickering on and off. All these symptoms indicate that the LCD backlight lamp (CCFL Lamp) has reached the end of the life and all you need to do is replacing the CCFL lamp.
Connect an external monitor to your laptop and power the monitor up first then the laptop, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight. Dim image and/or dark display on the laptop's LCD screen indicates a faulty LCD backlight and it could be the inverter that supplies high voltage to the CCFL lamp or it is the CCLF lamp is nearly burnt out or burnt out, most likely this is the case.
The inverter can be replaced easily but the CCLF lamp is more time consuming and requires soldering skills.
Check out
www.lcdparts.net
for parts, repair service and DIY info.
Jun 21, 2009 | MSI M670 Notebook
Friend's Laptop Screen has become too dark to work with
You could have a defective screen - a defective inverter or a CCFL lamp.
To determine if you have a LCD screen or video card problem, read this and follow the instructions.
  • Screen flashs on red/pink and off.
  • Picture stays on in red and slowly be come normal.
  • Picture flickering with dim display.
  • Picture flickering on and off.
Connect an external monitor to your laptop and power it up, if you see the normal Windows images then the video card and laptop is OK and the problem is definitely the backlight.
Check out www.lcdparts.net for parts, repair service and DIY info.
Apr 24, 2009 | Toshiba Satellite U205-S5002 Notebook
Acer screen looks dark?
Apr 23, 2009 | Acer Aspire 5315 Notebook
Dark monitor screen with hidden display in the dark.
You most likely have a defective CCFL backlight, it may have the following symptom:
Apr 07, 2009 | Acer Aspire 5040 Notebook
Acer Laptop Dark Screen
Defective CCFL backlight may has the following symptom:
Mar 31, 2009 | Acer Aspire 3680 Laptop
Laptop screen illumination
The fault could be a faulty CCFL lamp or inverter.
To determine if you have a LCD screen, inverter or video card problem, read this and follow these instructions.
Check out
www.lcdparts.net
Nov 03, 2008 | Gateway SL9550-30165318 Notebook
SCREEN PROBLEM
backlight is probly out.. wich I would rec new laptop
I know if sometimes laptops can be switch between vga out and laptop screen.. if its switched to output vga a lot of them will kill the laptop screen and you might just have to switch back or the contrast might be all the way down..
if backlight is out you will see the pic on screen but it is very very dark mostly you have to use a flashlight to see the screen
if its a desktop check to make sure that vga cable is not unplugged or loose.
ether way I would rec you take it in to a shop to see if its the screen or laptop/ desktop(vga port)
Aug 05, 2008 | Acer Aspire 5100 Notebook
My toshiba screen
Shine a torch light onto the screen. If you can see a faint outline of the images, it could indicate a back light failure. Unfortunately, you cannot fix this by yourself. You will need to take it for servicing.
Jun 11, 2008 | Toshiba Satelite A10 Notebook
Compaq Presario 700 laptop problem
Most of the time blue screens like that indicate hardware issues. You may try replacing the memory. I wouldn't put too much money into something of that age, though.
May 23, 2008 | Compaq Presario 700 470024-192 Notebook
Acer Aspire 3000 pc screen problem
Have u tried re-installing the video drivers?
Nov 27, 2007 | Acer Aspire 3000 Notebook
Toshiba Satellite Pro L300 Notebook Logo
23 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
