Question about Ovens
I have just replaced a fan oven element on my Tecnik TKC1285 range cooker. However, the fan now turns off when the oven reaches temperature, and the element continues to operate
  • Ovens Master
  • 3,463 Answers
Sounds to me like it is wired incorrectly, the fan should continue to run even thnough the element turns off at the correct temperature setting.
You could try reversing the connections to fan and element, this in theory should solve the problem.
Posted on Dec 31, 2010
  • Alun Stewart
    Alun Stewart Oct 22, 2013
    Sorry, I did not make it clear. Its the element in the basic oven not the fan oven.
I have a New World Double oven, dual fuel range cooker - NW 90DFD0 The main oven isn't heating up.
Hello Ally;
My name is Peter. I am a retired field service appliance technician.
You may not have a problem. Normally your oven will rise about 40 degrees F. above the set temperature and then shut down, until the oven temperature falls 40 degrees F. below the set temperature, then the oven turns back on.
Your oven temperature is controlled by you oven thermocouple.
You also have a high temperature limit switch, which turns the fan on when you go too far above the set temperature to vent the oven. This may be bad.
Mar 10, 2016 | Ovens
Oven temperature will not cycle
How To Fix Oven With Little or No Heat When Baking ...
www.partselect.com/Repair/Range-Stove-Oven/No-Heat-When-Baking/
Repairing a range, oven, or stove can seem like a big task, but our ... Most electric ovens use both the bake element and the broil element in a bake cycle, with the bake... If the bake element isn't working, the oven may not reach the set temperature or ...If the element appears to look normal, then turn the oven on to a bake ...
Electric Stove Repair ' Electric Oven Repair Manual ...
www.appliancerepair.net/oven-repair-4.html
Inside the oven, the heating element is called a "bake" or "broil" element. ... To maintain a set temperature in an electric cooktop, the element is cycled on ... Do not put any cleaning agents or solvents directly on heater elements or surface units. ... A switch will show no continuity when off and good continuity when turned on.
Electric Oven Will Not Heat ' RemoveandReplace.com
removeandreplace.com/2015/.../oven-not-heating-how-to-fix-range-repa...
Aug 24, 2015 - The issue is most likely a bad internal fuse, oven temp sensor, ... oven replacement parts ... Bake and Broil Element Test - Electric Oven Repair ... Dryer Spins But No Heat - How To Troubleshoot Dryer is turning the drum but ... If your dishwasher is completing the wash cycle but will not dry your dishes, we ...
Oven Temperature Not Accurate - Repair Parts ...
Jan 28, 2016 | Frigidaire Ovens
The oven is not reaching its correct temperature.
This type of problem normally can be ascribed to a defective thermostat. Unfortunately there is no test for a thermostat, it has to be replaced to see if the problem has been sorted out.
One thing you can do is remove the thermostat bulb from the oven and place place it in a position where it will not heat up. Place an oven thermometer in the oven. Switch on and see of the temperature climbs above what you wee seeing before. This is a very much hands on test as you have no control over the temperature that the elements can get to. As soon as you see the temperature reach a point above that seen before, shut down immediately.
Apr 12, 2011 | Tecnik Ovens
There is a loud buzzing from our Tecnik 1285 range cooker. The buzzing starts about 5 minutes after turning either of the ovens on, and only stops 10 minutes after turning it off. The front of the oven /...
its the cooling fan to keep the control and metal and top of cooker cool. mine is also extremely loud. I think it basically turns unecessarily quickly and could be slowed with a resistor in line
Jan 20, 2011 | Tecnik Ovens
Do you know the power rating of a TECNIK TKC 1255/SS cooker
i believe this is a range oven so has gas hob top one large oven a one small oven main oven draws around 2.5 kw on fan and 1.8 on conventional elements.
May 17, 2010 | Ovens
I have a tecnik tkc 1255/ss range oven serial no 0704020076 COD. 0.41019xst0sq i need a replacement main oven door handle
You dont happen to have the LPG jets that were supplied with the cooker do you? I'm having trouble getting hold of any?
Thanks,
Apr 19, 2010 | Tecnik Ovens
After effects of blown fan oven element on U1721
I think there is an inline fuse for each oven/element.
May 04, 2017 | Neff U1721 Double circotherm Electric Oven
Duco4ss main oven not heating on fan setting
put test bulb on the two wires going to fan heating element,that will tell all,if bulb lights,its the fan element that needs to be replaced!good luck!!
Dec 17, 2007 | Ovens
Ovens Logo
107 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
