Question about Asko Dishwashers
I have a problem with my Asko D3350 Dishwasher, can you help? On startup the diswasher does its normal cycle and pumps excess water out and then fills the dishwasher with water to the correct level of water, after this the machine has no dishwashing action at all for the duration of the program setting. The dishwaher then pumps all excess water out and switches off as normal but no washing action has taken place, there are no error codes during the entire operation. Is there any way to resett the main prosessor board or any firmware available to update this. the unit says PC Upgradable.
Hi Tony,
I have the same machine (D3350) and almost the same problem.
Mine starts each cycle fine - pumps out - fills - rinses - pumps out tht first load and then does not fill again. If I manually fill with a bottle (about 2 litres) for each subsequent cycle then it washes as well as it ever did.
Seeing it fills once it cannot be the water supply, nor the solenoid that operate the water supply. So, my guess is the control panel.
Like you I would love to simply take advantage of the PC Upgradeable featurewshich seemed so attractive at the time of pruchase.
Jason
Posted on Jan 10, 2011
  • Hamish Curtis
    Hamish Curtis Dec 18, 2012
    Hi Tony it's the PCB control unit inside the door worth $485.00 mine has done the same thing. I'm buying a new dishwasher cause by the time the guys puts it in again we will be up to 600-700 bucks.
Asko d3350 has the f2 flasing and pump just runs
sounds like you have a water leak. The machine is fitted with a leak detection device that runs the drain pump constantly as a safety mechanism. If you want to look your self you will need to pull the machine out and tilt it back and if possible remove the bottom panel, should be 4 screws, this gives you access to the components. If it doesn't come off then you will need to remove either 1 or both of the side panel, its just a number of screws holding them. Then see if you can see where the leak is coming from, you may need to order a new part. Hope this helps.
Mar 03, 2011 | Asko 24 in. D3350 Dishwasher
Asko D3350 code F7
you seem rushed
ok
the problem might not be in your senser or timer but in the pump its self
Sep 14, 2008 | Asko 24 in. D3350 Dishwasher
I have an Asco D3350 dishwasher. When the cycle starts the machine fills with water and when there appears to be the right amount of water in the machine an error code F4 shows on the panel. 3 clicks can...
There could be a variety of problems most common clean filter sensor water level faulty replace or pump not working how old and how often do you use it?
Aug 29, 2017 | Asko 24 in. D3350 Dishwasher
F7 code
yes remove filter and water from under filter theres a small chamber at the back of the sump,it may be full of fat clean it with your finger then try running some heavy wash cycles to clean it.
May 02, 2010 | Asko 24 in. D3350 Dishwasher
Asko 3350 F2 fault meassage keeps flashing
you have a blockage try the drain spigot under the sink or the pump may be blocked.
Apr 23, 2010 | Asko 24 in. D3350 Dishwasher
No water circulation
i had a call on this the other day and the problem was the water valve under the sink was not open all the way. so even though the water valve was energized properly the customer never got the volume the circulation pump needed to wash correctly
Nov 23, 2008 | Asko 24 in. D3350 Dishwasher
Help for my asko diswasher
Unplug the washer for ten minutes, see if this clears the problem.
Aug 28, 2008 | Asko 24 in. D3350 Dishwasher
Asko D3350 code F7
Service manual says:
LED L1+L2/Fault code F7, Pumping out fault
(machines with pressure sensor)
Water not evacuated after 120 seconds’ pumping
out. Programme interrupted.
Check: Drain pump, hoses, installation of drain
hose, control unit and wiring.
Jan 19, 2008 | Asko 24 in. D3350 Dishwasher
D3350 - Code F9
Asko D3330 F2
there is water in the pan below the unit. You will need to take apart the lower section of the dishwasher behind the toe kick and suck out the water, or just wait for it to evaporate (few days) Good Luck!
Oct 28, 2007 | Asko 24 in. D3350 Dishwasher
Dishwashers Logo
586 people viewed this question
Top Asko Dishwashers Experts
John Tripp
John Tripp
Are you an Asko Dishwasher Expert? Answer questions, earn points and help others
