Question about Nokia 5300 Grey Cellular Phone
I want blacklisted key
I was switching my phone and it told me that is blacklisted
    Brigadier General:
  • 7,752 Answers
You would have to do a master reset on the phone
Posted on Aug 18, 2008
Can you block a phone number on a Doro 6520 cellphone
Yes you can
How to block a phone number on Doro 6520 - Phone-Info
https://phones.brain-start.tech/block-phone-number/how-to-block-a-phone-number-o...
Aug 12, 2017 - Because you have an Doro 6520, you can also block text messages from a phone number. First, open the application "Messages" and then press the menu button located at the top left of your Doro 6520. Then you will see a list and you will need to press "Settings". Then click "More". You will have access to ... People also ask How do you block a number from your phone?
How do you block a number on a consumer cellular phone?
How do you block a phone number on an LG flip phone?
How do you block a number on a ZTE phone?
Feedback
How to put or remove a blacklist contact on yo ur Doro 6520 - Phone-Info
https://phones.brain-start.tech/.../how-to-put-or-remove-a-blacklist-contact-on-yo-ur-d... Jul 17, 2017 - To actually add the number to the blacklist on your Doro 6520, simply go to the contact containing the number in question, click on the 'menu' key of your Doro 6520, and select the 'block this contact' option or 'add it to the blacklist'. That's it, your contact is now added to the blacklist of your Doro 6520.
Doro 6520 - Turn call barring on or off
https://userguide.vodafone.co.nz/doro/6520...os/calls.../turn-call-barring-on-or-off/ Turn call barring on or off. You can block certain types of calls such as incoming calls when you're abroad. Key in your barring password and press the Navigation key. The default barring password is 0000.
Feb 20, 2018 | Cell Phones
How do I blacklist this cell phone?
The United States and Canada now have blacklists for stolen phones. Contact your service provider to get your phone put on the blacklist. Once on the blacklist, the theory is no service provider will activate it.
Good luck,
Paul
May 10, 2016 | Cell Phones
How do I remove Samsung Galaxy S5 Active imei number from blacklist?
You will need to ask your cellphone provider. Normally blacklisted because it is stolen, or has been moved to another carrier when the previous carrier still owns the phone under an unexpired contract. This is the official line on this
You can check your IMEI number is Blacklisted in AT&T, Verizon, T-Mobile, Telus, Sprint...Blacklist IMEI is lost, stolen or ineligible (Bad, Barred, Blocked, Financed, Under Contract) mobile phone. Always check blacklist before buy, sell or get phone.
http://www.protectyourdata.ca/check-the-status-of-your-device-in-canada/
http://imei-number.com/imei-blacklist/
https://imeidata.net/blacklist/check
Unlock Bad IMEI Phone that Blacklisted Blocked or Stolen
Mar 04, 2016 | Samsung Cell Phones
Remove blacklist off my phone
Go to androidrooter.com. he can fix blacklisted phones
Jul 31, 2014 | HTC One X Android Smartphone Glamour Gray
Blacklisted huawei p6
a blacklisted phone is a stolen phone,and the owner reports it to the service provider to block it after confirming the requesting client is the owner they verify and block so it may work in onother country other than where it was stolen from,but its against the law to aid things of that sort,but if you change the imei #,serial # it can work in your country
Jan 18, 2014 | Huawei Cell Phones
Ihave had a mobile for a while now and it stopped working someone told me it had been blacklisted can u tell me how to make it work again
if it's a cdma phone, you need to check with your operator if it's a gsm phone try inserting another sim card and see what happens.
Oct 08, 2009 | Cell Phones
Blacklisted
need to phone your service provider mtn or vodacom or cell c or take it to some one to flash the phone
Sep 15, 2008 | Nokia 5200 Cellular Phone
Thanks
I recommend you contact your service provider.
Blacklisted or Barred Handsets
What is it all about???
A phone may be blacklisted (or barred) for many different reasons, but the most common reason is that it has been reported either lost or stolen! It is only the networks (Orange, T-Mobile, O2, Vodafone etc) that have the facility to blacklist a handset.
If you are unfortunate enough to either lose or even worse have your phone stolen you should report it to your service provider (your network) immediately!
Your service provider can then blacklist the handset so that it can no longer be used to make or receive any calls. The networks do this by adding your phones serial number onto a national blacklist database (Central Equipment Identity Register). Effectively the handset becomes absolutely useless and the thief is in possession of a pretty paper weight! :-))
So How Does Blacklisting Work?
Every mobile phone has a unique serial number. This serial number is called the IMEI number (International Mobile Equipment Identity). It can normally be found underneath the phones battery and it is 15 digits long.
Now each time you switch your phone on or attempt to make a call the network systems check the IMEI number of the handset you are using. At this point the IMEI number of your handset is cross referenced with the Central Equipment Identity Register. If the IMEI number of your handset is on the CEIR then the network will either:
1) Refuse to send a signal to your phone (No signal strength at all)
2) OR WILL supply a signal but will not allow any outgoing or
incoming calls.
If your IMEI number is on the CEIR your handset is blacklisted and therefore useless.
Apr 27, 2008 | Samsung SGH-E370 Cellular Phone
Nokia 5300 Grey Cellular Phone Logo
41 people viewed this question
Top Nokia Cell Phones Experts
Computer Repairing
Computer Repairing
