Question about Ovens
How do i change the bulb in the main oven - Ovens
    Problem Solver:
  • 13 Answers
Most lamps simply spin counter clockwise to remove. Some have a glass lens over the bulb, and it also likely just spins off. You may have to "finesse" them back and forth a bit, repeated heating and cooling may bind them up a bit. Good luck, Rob.
Posted on Jan 01, 2011
How do I replace a blown buld in the main oven
In most ovens, move the metal bracket to one side. the glass dome cover should fall out. Unscrew the old bulb. Screw in the new bulb. Place the glass dome cover back over the bulb. Move the metal bracket to hold on the glass dome cover. Easy job to do.
Aug 23, 2015 | Stoves Premier 720EMa Electric Double Oven
Where is the light bulb in the main oven as I need to replace it
On my older Jenair, it is on the upper surface of the oven. It has a glass cover that would need to be removed to access the bulb.
Could be the switch or connections at the switch that is preventing the bulb from operating. Depending on age of oven and frequency of use of the light, oven bulbs last a long time. Mine is still good after 26 years!
May 07, 2015 | Ovens
Main oven bulb changed now new one will not go out.
There is probably a problem with the oven switch. If you are careful, you can, after switching off the mains, remove the oven light switch, pull off the live terminal and insulate it. The turn on the oven mains again and see if the light still comes on. If it does, there is wiring problem. If it does not, the switch is faulty and needs to be replaced.
Feb 05, 2011 | AEG D5701-4 Electric Double Oven
Bulb blown and now fan is not working
When you changed the bulb did you turn the power off at the mains if so then you need to reset the clock on the front panel the fan will not work but all other functions will look in book it will tell you clock reset.Hope I helped.
Good Luck.
May 07, 2010 | Bosch HBN 730520B / 730560B Electric...
Oven will not get hot
you will need to replace main oven element it will have burnt out and gone open circuit just like a light bulb, they are easy to change and not expensive.
hope this helps
May 01, 2009 | Neff B1421 Electric Single Oven
How do I change the light bulb in the oven
You can replace the light bulb(s) in your range/oven, though you may need to remove a glass covering or dome to reach it. Most interior oven lights use a universal 40 watt appliance bulb.
Apr 24, 2009 | Philips Ovens
Replacement bulb
there are more than one type of bulb for these ovens, the most important thing is that you get one that is rated to withstand temperature of 300oC, or they will shatter with the heat.
Plz rate my solution.
Thanks.
Dec 08, 2008 | Neff U1421 Double circotherm Electric Oven
Trying to replace main oven bulb: cover jammed
Try heating it up with a hair dryer or similar if that does not work then you will probably have to break the glass cover.
Nov 17, 2008 | Neff U1461 Double circotherm plus Electric...
Change oven thermostat
Not familiar with the brand - but there are two types of temperature sensors - i am assuming here that the person meant temperature sensor rather that a thermostat.
1 bulb type sensor
2 rtd type sensor (metal looking tube usually installed at back)
If its the bulb sensor - then there is a long tube from the bulb to the main dial on the front panel. All of this must be removed to change it. (power turned off) The knob on the dial removed and the front panel removed and the screws removed and the bulb threaded through - reverse to installed.
If its the rtd - then they are usually secured with two screws inside the oven (look inside to see) loosen those then pull the unit towards you the connecting wires should come through there should be a quick connector - (if under counter type) remove the old sensor and connect new one. Thread the wires back through the hole and secure the new sensor with screws - if the screws were damaged replace with only stainless screws
Aug 22, 2008 | Zanussi ZDQ895 Electric Double Oven
Ovens Logo
56 people viewed this question
Top Ovens Experts
Dan Webster
Dan Webster
ashburton
Are you an Oven Expert? Answer questions, earn points and help others
