Almost all modern electronics will work on almost all power systems. Look at the fine print on the power supply (plugin adapter, brick, etc.) for the Voltage rating, which is usually 110v - 240v. On a desktop CPU, the voltage rating will be near the AC plug on the back. They switch automatically. If your DVDs play on your computer now, they'll play just fine on your computer anywhere on the planet.
SOURCE: How do I remove the -Microsoft Internet Explorer provided by Orange?
hi i think you have to try to make a new connection by the config panel, follow the help to do that, it'a easy
I hope this helps
Please rate accordingly
Thank You
sserpentio
SOURCE: dell latitude d600 purchased in
if its a round 3 pin and it plugs into a power unit 3 spade type plug end, using a plug like the one that goes into an electic kettle, just buy a kettle lead and use that.
If the power unit itself is not 240 volt you can buy a universal charger/power unit from maplins or similair, but check the wattage
http://www.maplin.co.uk/Search.aspx?criteria=laptop%20power&source=15&SD=Y
SOURCE: I brought a computer back
i guess the computer manufacturers would have thought about it during manufacture
and if a setting is given may be
just maybe it can be fixed
why dont u consultt the manufacturers
