Question about Sony Televison & Video
How to open screwless remote control (by Sony) (to clean dirty contacts)
  • Sony Master
  • 6,694 Answers
there are locks in its four side. with out any wear and tear u cant able to open the remote. see the following video. else removing screw do the following
ok
Posted on Dec 31, 2010
Volume goes and comes
replace old batteries and clean and tight the spring contacts batteries from dirty, oxide, corrosion.
2) open the r.control and clean the keypads from dirty, corrosion, oxide, with contacts cleaner and try again.
God bless you
Nov 06, 2013 | Westinghouse Used Original VR5525Z Remote...
I cannot control the volume on my str-de598. The display shows it changing up/down. Pressing mute shows mute on the display but the volume is not muted...
open the remote c. and clean the keypads form dirty, corrosion, oxide, use contacts cleaner and fix it.
God bless you
Jul 31, 2013 | Sony Televison & Video
Sony internet tv remote stuck
open the remote control and clean the keypads from dirty, corrosion, oxide, and bad contacts, with c. cleaner very well. with carefully.
2) replace a new battery with the same type:alkaline
3) clean the contacts batteries with c. cleaner
4) try again.
5) if the problem persist you have 2 options go to repair shop TV for fix it, or REPLACE IT.
God bless you
Oct 12, 2012 | Sony RM-VL1000 LCD Remote Control
How to access symbols on keyboard
open the rem.control and clean the keypads for bad contacts, oxide, corrosion, and dirty.
and try again.
if the problem persist, go to the repair shop TV for fix it.
God bless you
Sep 23, 2012 | Sony Nsgmr1 Remote Control
I have an kv-27exr20 and the remote cut the speakers off how do i get it back on
reset the code and try again download from www.remotecodelist.com
or remotes.com and proceed according with common sense. Try to clean the contacts batteries b) retight the spring contacts batteries with a pliers for better contacts c) resolder the wires contact batteries. d) try open the rem.control from clean to dust, dirty, oxide, bad contacts or open contacts, and repair. Remember they send signal infrared from Syscon transmittter vs Syscon Receiver, the signal can be very clean.
God bless you
Jul 31, 2012 | Sony RM-Y136 Remote Control
Sony bdv-n890w not switching inputs with Harmony One remote
1) change the batteries by new ones
2) clean the contacts batteries with contacs cleaner
30 resolder the wires contacts batteries
4) retight the spring contacts batteries with pliers for better contact
5) open the remote con. and clean the keypads switch from oxide, dirty, dust, open contacts or bad contacts test it with VOM.Remember they send signal from SYScon trans vs Syscon Receive very clean. for good result.
6) Otherwise you must go to the repair shop TV. for fix it.
God bless you
Jul 30, 2012 | Televison & Video
Hi my name is Oscar I have a tv element model FLX-3211B and do not work the remote control codes sony RM-VZ320 and need help please!
Please reset the codes and try again. You must replace the batteries by new ones type alkaline b) clean the contacts batteries c) retight the spring contacts batteries with pliers d) open the remote control for clena the keypad switch from dirty, dust, oxide, bad contacts or open , remember they send infrared signal from Syscon to the microncontroler Receiver. see the blck..d
go to the next web pages, give your model, mark.
www.remotecodelist.com + remotes.com
God bless you
Jul 29, 2012 | Sony RM-VZ320 Remote Control
W-72 remote won't work
1) change by new batteries alkaline
2) clean the contacts batteries with isopropyl alcohol
3) tight the springs contacts for better contacts with pliers
4) open the remote control, and clean the keypads switch from dirty, oxide, corrosion.bad contacts, or open contacts. This will NOT trasmitt the infrared signal to the receiver.
5) Otherwise you must go to the repair shop TV for fix it
see the block diagram
Jul 26, 2012 | Casablanca Fan Versa Touch2 W-72 Remote...
Sony RMT-D187A stopped working!
1= change the batteries by new ones
2= clean the contacts cleaners with contacts cleaner
3= resolder the wires contacts batteries
4= retight the spring contacts batteries with pliers for better contacts
5= open the r.control clean the kepayds switch for dirty, oxide, and test for open, bad contacts.
6= try agan, if doesnot work go to the repair shop TV for fix it.
God bless you
Jul 19, 2012 | Sony Televison & Video
Number button not working
Your remote control have dirty contacts between button and internal circuit board. Cleaning it will resolve the problem. But clean it, you have to open the remote control. Check this site named 'Electro-help' for details. You can get detailed description about how to clean a remote control from there. Pull up older posts. it is very difficult to include all the details here typed. Check this link, and select the site.
Jul 10, 2012 | Televison & Video
Televison & Video Logo
318 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
