Question about Cell Phones
Why my nexian nx-c701 appear data abort hold # key to enter download mode? and can i have driver for that? many thanks before.
4 Suggested Answers
kdigby
  • 37 Answers
SOURCE: Can't find USB Driver for Nexian NX c900
these should work...
http://www.nexian.co.id/index.php/component/filecabinet/?view=files&id=10
hope this helps!
Posted on Dec 01, 2010
  • 5 Answers
SOURCE: bagaimana cara copy/transfer phonebook dari nexian nx-g922 ke hape nokia?
huh?
Posted on May 06, 2012
bronk50
  • 27725 Answers
SOURCE: Driver nexian g381i
Rather doing a driver hunt which can take hours http://download.cnet.com/slimdrivers-free/3000-18513_4-75279940.html Windows XP/Vista/7/8
it might take some time being a freeware driver solution note: it will find all of your outdated drivers This is a free driver solutions.
This will automatically search for and find the correct driver you will have to update every driver individually once you update you might be asked whether you want to restart or make a system restore point.
Click no to both of these then continue updating each driver free then restart once all of the drivers have been updated.
Hope this helps
Posted on Dec 10, 2012
Micromax master resetting code all
Hard Reset Micromax Canvas HD A116
  • Switch Off your phone.
  • Press and hold Power button together with 'volume +' and 'volume -' buttons on the side of phone until you get two options.
  • Now, press the 'volume +' button to enter into the recovery mode.
  • This will make a Android icon appears on screen, press power button.
  • This will get you the menu options, use the volume up and down button to choose the option.
  • To select the option, you needs to simultaneously press two touch sensitive buttons on the bottom of your device, left button which is for the Menu and right button which is for going into previous stage. You have to do this for about 3 seconds.
  • Choose the wipe data/factory reset then press the enter button (left button which is for the Menu and right button which is for going into previous stage). Now, phone will get switch off and brings to its initial stage.
Done! with this default way to factory reset you have successfully done with hard reset of your Micromax Canvas HD A116. The hard reset procedure is same for Micromax Canvas A110 also. If you have any questions regarding the procedure to hard reset Micromax Canvas HD A116.
OR
The Instructions
  • Turn Off your device
  • Press and hold the Volume up (+), volume down (-) and power keys at the same time until the screen show the two options
  • You will get the option Recovery mode and Factory mode , to select the Recovery mode press the volume up (+), for the Factory mode press the volume down (-).
  • If you want to hard reset your smartphone, you should select the recovery mode.
  • To navigate it, you can use volume up and down.
  • To select an option, you must press the Menu button.
  • After you hard reset the device, your smartphone will return to factory setting automatically.
OR
Hard Reset:
  • Press and Hold Volume Down + Power Key for 20-30 Seconds.
  • Now you See Warning Logo on screen.
  • Now Download Android Multi Tool
  • Download fastboot driver and install Drivers
  • now open tool and press "8" and enter to wipe data / factory reset.
  • after format remove battery and reinsert battery.
  • power on the handset.
  • Download Driver from Here
  • Download Android Multi Tool from Here
Nov 07, 2013 | Cell Phones
Screen is black cursor moves , but nothing appears. just changed fan
  1. Have you made any changes to the computer prior to this issue?
The issue you're facing could be related to drivers and could be resolved by updating the display drivers.
2. To confirm this run your system low resolution mode.
  • Press and hold the F8 key as your computer starts.
  • On the Advanced Boot Options screen, use the arrow keys to highlight Enable low-resolution video, and then press Enter.
If the problem doesn't reappear in low-resolution mode, then the issue is driver related. Then you download display driver from your graphics card vendor site.
Thank You For Using FIXYA
Feb 20, 2011 | HP Compaq Presario SR5050NX PC Desktop
C6400
C6400 is a fixing unit error. You may need a new fixing unit but most of the time it can be reset in maintenance mode.
Use the following steps to enter the maintence mode, once there follow the steps for maintence mode 163 (reset fuser error). Do not do anything else in the maintenance mode area because you could damage your machine.
Press the system menu/counter key.
Select Service setting using the up/down cursor keys.
While pressing the start key and the # key, press the enter key.
Select Maintenance mode using the up/down cursor keys.
Press the enter key.
Enter the maintenance item number (163) using the up/down keys.
1. Press the enter key. A selection item appears.
2. Select Execute using the up/down cursor keys.
3. Press the enter key. The fusing problem data is initialized. (Four service calls, namely C6000, C6020, C6050, and C6400 are reset.)
Completion
Press the back key. The indication for selecting a maintenance item No. appears.
Turning power switch off and back on
Resetting the fusing problem data
Description
Resets the detection of a service call code indicating a problem in the fusing section.
When a service call concerning the fusing section occurs, turn the power switch off and open the front cover.
Then, turn the power switch on and press the system menu/counter key to enter the maintenance mode.
Purpose
To prevent accidents due to an abnormally high fusing temperature.
Method
Completion
Turning power switch off and back on.
I hope this is helpful,
Shawn
Feb 15, 2011 | Kyocera Copystar CS-1820 Black and White...
NEXIAN PROBLEM: DATA ABOR # key to enter dload mode ...
this problem will be solved but you have to contact your carrier
or service provider
May 20, 2017 | Cell Phones
Display the Call service C6400 code
Completion
Description
Purpose
Method
Completion
Shawn
Dec 22, 2010 | Kyocera Copystar CS-1820 Black and White...
Buka kunci telepon nexian G501
ada yg tau g cara buka sandi telepon nexian G501
Sep 13, 2010 | Health & Beauty
BAGIMANA CARA MERESET HP NEXIAN?
kenapa ya hp nexian saya ga bisa suport sama ebuddy.merk NX-G911
Jul 15, 2010 | Nexian Handy GPS Pro GPS Receiver
Installing a kyocera fs 3830n printer on applemac
See if this is set to pcl6, make take care of it.
(from manual)
Changing the Emulation
To change the emulation mode, proceed as follows:
1 Press the MENU key.
2 Press the or key repeatedly until Emulation appears. One of
the emulation modes shown below appears, indicating the current
emulation.
PCL 6 (default)
KPDL
KPDL (AUTO)
Line Printer
IBM Proprinter
DIABLO 630
EPSON LQ-850
KPDL is the Kyocera’s implementation of the PostScript page
description language.
3 Press the ENTER key. A blinking question mark (?) appears.
4 Press the or key repeatedly until the desired emulation mode
appears.
5 Press the ENTER key.
6 Press the MENU key. The message display returns to Ready.
Apr 12, 2008 | Kyocera Mita FS 3800 Laser Printer
Cell Phones Logo
451 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
