Question about D-Link DES-1008D 8-Port Ethernet Switch (790069217708)
Internet is very slow when running through the 8port d-link switch, but runs perfectly without it. What may be the problem
    Scholar:
  • 124 Answers
Please follow the below steps
1. Power OFF the switch for 2 minutes and power ON.
2.Change the cable connecting the switch to the router and if possible try with another port on the switch.
It looks to me either a bad cable or a bad switch port.
Posted on Jan 01, 2011
Computer is very slow and every time i open wepsite it get stack
turn on the computer and keep on pressing the F8 key> select safe mode> login to desktop> go to run and type "temp" (without quotes) then hit enter and delete all the files> go to run and type "%temp%" (without quotes) then hit enter and delete all the files> > go to run and type "msconfig" (without quotes) then hit enter then goto the startup tab and uncheck all the unnecessary items hit ok and do not restart the computer> go to run and type "inetcpl.cpl" (without quotes) then hit enter then goto the advanced tab and click on reset to reset the internet explorer.
Then restart the computer it should work fine now.
Sep 06, 2010 | Computers & Internet
My windows xp run very slow
Remove temp files from computer. Press windows key + R then you can see type in run "%tmp%" without "" then press enter then remove all temp files.Type in run "prefetch" without "' then press enter remove all prefetch files. Type in run "chkdsk /r" then press enter then press "y" then restart computer then it fix errors on harddrive. Scan computer updated antivirus it is best antivirus. Download it's free version from below link. Click here Download and install then update it from internet. Then scan computer in boot time avast scanner. Then check. Let me know if you need further assistance. Thanks for using FixYa.
Jul 19, 2010 | Acer Computers & Internet
D-link in not to be used 8port systems des-1008d to not join to the another lane
Please check if the power is connected. Lights in the D-Link should be ON.
Thanks,
Dexter
Jul 04, 2010 | D-Link DES-1008D 8-Port Ethernet Switch...
Computer slow , have high speed dsl, but very slow
Click here
Then check.
Jul 16, 2010 | Gateway GT5692 Desktop Computer
Internet extremely slow on one network, fine on the other
Not knowing if this relates directly as i am not from Australia but have you checked with the ISP.
The phone line providing the internet access may be damaged in some way or require calibration to reduce line noise (which can cause slow speeds).
Alternatively, have you got a usage limit that you may have reached. ISPs have the ability to throttle back your connection speed.
Thanks
Dec 22, 2009 | D-Link DSL-G604T Wireless Router
Slow internet connection to my x-box. Problem
Try to open the ports of the XBox to the EBR-2310 router.
Ports of the XBox: TCP 80, 3074 and 53
UDP 88, 3074 and 53
You'll needing to access the configuration page of the router (192.168.0.1) and open the ports under port forwarding.
Mar 09, 2009 | D-Link 4-Port Ethernet Broadband Router...
I can't remove the real player from my mobile htc -
hey lucky man... u r lucky to find me.. hehe
well i call u lucky man, because my fren use tytn too
here's the problem he has (which i think it occurs to you too)
when you do multitasking (open a lot of application together), it consume the memory of your PDA , so much that it cause low memory, therefore, it became slow, slow, and slower, until it finally get 'hang' condition.
what you must do with this memory consumtion is, check everytime u open and close application, did you close perfectly, or it just closed to background (it is still running, you just don't see it on the display) - u can see if it's still on the list of running application (menu)
second, if there's still low free memory, then i suggest you to erase not useful application or just format, remember to backup ur datas.
thrd, if ur internet (which u said is slow is the problem) still run slow,try it on other pda or device.don't tell me that the internet connection is sucks on all phone but all this time you blame your PDA, hha..
if it only run slow on ur phone, then format it, if still slow, try another browser like opera mini, or any browser which compatible to yours.
Good luck..
Nov 13, 2008 | HTC TyTN Smartphone
Internet runs slow or freezes on my wired desktop when I use the internet on my wireless laptop.
Hi tech_newbie.... Need a little more info... how is your wireless connected.. ethernet /Usb... or true wireless... and vice versa for desktop. where is your wireless router situated... what times are you experiencing the slow connection!
In addition.. first try running a good Spyware/ adaware programme such as Spybot.. and alongside side another programme called... a-square.. and with AVG.. all of which are free... see links below..
http://www.safer-networking.org/en/download/index.html
http://free.grisoft.com/doc/2/
http://www.emsisoft.com/en/software/free/
Try this first.. they are all pretty good programmes when used in conjunction with each other, you;ll be surorised at what you find.... Get back to me if this does not eliminate your problem
Regards Faggly
Mar 19, 2008 | Computers & Internet
D-Link DES-1008D 8-Port Ethernet Switch (790069217708) Logo
163 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
