Optima xm house alarm keeps going off even when not set when reset attack light on control panel
dididsaythat
  • 291 Answers
SOURCE: temp alarm going off
What is the temp in the freezer, sounds like temp is to low..no water should be coming out of freezer, sounds like may be defrosting Need to check the temp to make sure its cold enough.. thats what that alarm is for
Posted on Sep 09, 2007
SOURCE: optima house alarm
after a power cut alarm goes back to factory setting 0123. you need to use this code to re program alarm
Posted on Sep 11, 2008
  • 7 Answers
SOURCE: Steering wheel lamps do not work (radio controls, temp, cruise)
The lights on the steering wheel are in the switches. To fix the lights, the whole switch needs to be replaced. Same thing goes for the Tempature Controls and radio. Overall, I think it would be very expensive to replace all of the switches to get the lights working. I have the same vehicle, and almost all of the lights are out.
I think the lights behind the gage controls are replaceable, although you still have to rip out most of the dash to get to them.
I have the auto-sense wipers, so I was leaving the wipers on all the time, and the would only work when needed. The bad part I finally found out about this was that while the wiper switch is on (even though they were not wiping), it caused all of the dash lights, switch lights and rear parking light to be on. I think this alone significantly cut down on the life of the bulb.
For now, I am just living without the lights. The temperature control is very expensive (just the part alone).
You can usually find the best price for these things at http://www.rockauto.com
Posted on Feb 22, 2009
  • 37 Answers
SOURCE: How can i get the tamper light to go out, so i can
Find out where the tamper fault is. This panel has tamper monitoring for external bell remote keypad zones and cover. Check all devices for loose covers ,wiring for breaks (especially if new carpets fitted) and bell box.You can check for continuety with a multimeter inside the panel you should have a short between A/T terminals and between 0v and TR if not check the wiring.
HTH
Posted on Nov 08, 2009
  • 14 Answers
SOURCE: How to reset house alarm after power cut
alarm may be in battery back up mode when power is lost it will automaticly start running off these batteries that are usually located in the panel. diffrent devices have diffrent ways or restoring regular mode. i would contact the maker.
Posted on Mar 14, 2010
Hi we have just moved into a house with an Optima xi6 alarm panel, the previous owner can not remember the 4 digit code number. Is there an easy way to reset the panel to the factory settings.
See if you find a removable IC chip on a carrier mounted on the circuit board in the alarm. Use a nylon spatula to remove the chip and after 10 mins carefully reinsert the chip into the base and try it. Ask the owner to try his last four digits of his social security number , driver's license, birthday. lol
May 22, 2017 | Cars & Trucks
E240B Fridge Freezer door open alarm goes even when door closed.
Fridge keeps beeping or buzzing: The following is for Frigidaire models but others can be addressed similarly.
Several Frigidaire refrigerator models have an electronic control panel on the freezer door the owner can use to adjust the internal temperature, dispense ice and water and receive notification about issues such as the need to replace a water filter. The refrigerators also emit a beep for various actions and as an occasional alarm. Determining what causes the beeps necessitates some troubleshooting.
Temperature Controls ·A Frigidaire refrigerator's display panel blinks when the control panel is touched to set temperature controls. After pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, press the arrow buttons within five seconds to increase or decrease the desired temperature. If you do not press the arrow buttons within five seconds after pressing "Freezer Temp" or "Refrigerator Temp" on the keypad, the refrigerator beeps to indicate the current setting will stay in place.
Door Open ·When you leave the refrigerator or freezer door open, the refrigerator beeps. Also, the "Door Ajar" indicator illuminates on the appliance's display panel. Shutting the door and pressing "Alarm Reset" stops the beeping and turns off the "Door Ajar" indicator light.
·The Frigidaire refrigerator has a control lock feature that prevents use of its control panel or dispensers when the unit is locked. When the control lock is active, a beep sounds when a keypad or dispenser is pressed. Release the control lock by pressing the "Control Lock" icon for three seconds. A beep will sound, and the icon's light will go out.
Power Reset ·A power reset is occasionally necessary if the Frigidaire refrigerator's control panel does not work normally or a reset function on the keypad does not work. A power reset involves disconnecting power to the refrigerator by unplugging its power cord from the electrical outlet, waiting 30 seconds and plugging the power cord back into the electrical outlet. When the control panel resets, a beep sounds. If the refrigerator beeps even after a power reset and the beeps' source is not known, contact Frigidaire.
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.
Cause of Beeping Noise in Frigidaire Refrigerator eHow
Dec 22, 2016 | Fisher Refrigerators
Why dose it keep beeping ?
Jun 20, 2015 | Refrigerators
Model E402b. Why is the alarm going off?
Read more :http://www.ehow.com/info_12148688_cause-beeping-noise-frigidaire-refrigerator.html
Cause of Beeping Noise in Frigidaire Refrigerator eHow Cause of Beeping Noise in Frigidaire Refrigerator eHow
Jun 02, 2015 | Fisher and Paykel Refrigerators
Alarm keeps sounding every 2.5 minutes, it works fine on electric, gas and battery and is 12 months old.
Fridge keeps beeping: The following is for Frigidaire models but others can be addressed similarly.
May 03, 2015 | Refrigerators
Got fridge freezer but no instructions. Alarm keeps going off. Front panel contriols
Apr 10, 2015 | Refrigerators
Why does my Hotpoint ff187e frost free fridge freezer lights flash and the alarm sound even after reseting them as per manual. rest them ok for a while but then restart what's the problem?
Jul 27, 2014 | Hotpoint Refrigerators
How to reset a optima xm home alarm
Usually those boards are locked out by the alarm survailance company that installed it. If you dont want to go through the company you can usually find a company that will sell you a replacement board that is open.
Jul 26, 2010 | Home Security
How do I get a signal back after I have a dead battery? The XM screen says "not ready". Xm said I have to go back to the auto dealer to get a signal back. This doesn't seem right.
With all the anti-theft deterrents placed in cars now if you disconnect the battery so as to bypass the alarm (even though all your doing is replacing the battery) in allot of cases the factory radio disables itself to render it useless to someone stealing it. The reset code should have come in your owners manual and if you don't have it then you will have to go to the dealer and prove ownership. They should provide you with the needed code but then may charge you to reset it. In the future if you replace the battery and the previous one isn't completely dead a set of small jumper wires to keep 12vdc on your electrical system will prevent this in the future.
Dec 25, 2009 | XM Radio (XMP6000)
Optima house alarm
Jul 31, 2008 | Computers & Internet
Computers & Internet Logo
101 people viewed this question
David Payne
David Payne
