Question about SanDisk Sansa e250 MP3 Player
Power comes on
I turn the power button on but it only shows the screen with sand disc on i cant get in two the main menu
  • 8,596 Answers
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Aug 14, 2008
System settings were lost
System settings were lost:
You need to reset the time and date from the Nintendo GameCube Main Menu. To access the Main Menu, turn the power ON while holding down the A button on the controller. Follow these steps to reset the time and date:
From the Main Menu Screen, go to the Calendar Screen by pushing RIGHT on the Control Stick.
Press the A Button to display Calendar Menu choices of Date or Time.
Use the Control Stick (UP or DOWN) to highlight your menu item and press the A Button to select your choice.
Use the Control Stick (LEFT or RIGHT) to highlight the number you want to change, then (UP or DOWN) to adjust the value.
Press the A Button to accept your choice.
Press the B Button to return to the Calendar Menu or the Main Menu.
Pressing the B Button before accepting your choice with the A Button will return you to the Calendar Menu without changing the settings.
If the same error continues to happen, you will need to have your system repaired as it is likely you have an internal battery malfunction. Please use our convenient repair options.
Wrong Game Disc:
This message happens when a Game Disc has been removed while the system is on, and a different Game Disc is inserted. Re-insert the original Game Disc.
No Game Disc:
This error can occur when the Game Disc has been removed while the system is on and then the Disc Cover is closed. Follow these troubleshooting steps:
Ensure the game is inserted correctly. With the power turned off on the system, replace the Game Disc in the system, printed side up. Press down gently on the Game Disc until it locks on the center hub. Close the Disc Cover and press the power button ON to see if the game comes on the screen.
Determine if this happens with more than one game by inserting a different game into the system.
If the error occurs with all games, follow the Multiple Game Disc troubleshooting.
If the error occurs with only one game, follow the individual game disc troubleshooting.
Nov 17, 2012 | Nintendo Wii Console
I have a Kenwood DNX7120 and the physical buttons on the bottom (att, vol controls, fnc, nav, src, etc) suddenly stopped working. Now, I have the remote control, so this isn't TOO much of a problem,...
My unit has the same issue, started a few weeks ago.
Here is a forum post where someone was able to fix their DXN7120 by replacing the button panel: http://www.kenwoodforums.com/viewtopic.php?f=11&t=1247
Here is a parts diagram showing the buttons (PN: X16-628):
http://www.pacparts.com/reference/880/DNX7120.pdf
Maybe someone could write up how to get the panel apart? Otherwise I will once I get the replacement part.
Nov 27, 2010 | Kenwood DNX7120 Car GPS Receiver
My gamecube will turn on to set the settings, after I set them I put in a disc and then the power shuts off. I have two sets of power cords I tried them both and it does the same thing with each of them.
  • System settings were lost:
    1. From the Main Menu Screen, go to the Calendar Screen by pushing RIGHT on the Control Stick.
    2. Press the A Button to display Calendar Menu choices of Date or Time.
    3. Use the Control Stick (UP or DOWN) to highlight your menu item and press the A Button to select your choice.
    4. Use the Control Stick (LEFT or RIGHT) to highlight the number you want to change, then (UP or DOWN) to adjust the value.
    5. Press the A Button to accept your choice.
    6. Press the B Button to return to the Calendar Menu or the Main Menu.
    7. Pressing the B Button before accepting your choice with the A Button will return you to the Calendar Menu without changing the settings.
  • Feb 24, 2010 | Nintendo GameCube Console
    Nintendo game cube says an error has occurred,said to turn it off and check the instruction booklet
    Is it the game or the game cube that is doing that. If it is the game then it is probably scratched. Try using toothpaste to clean. If it is the game cube that is broken then open it up and see if anything looks broken
    Jul 14, 2009 | Nintendo GameCube Console
    How do i change the picture on the maine
    from the main phone screen, push the menu button --> options --> phone display options--> where is says show dial pad, the other choice on the drop down menu is show wallpaper, then click the picture to the right, and any picture you have in your phone you can use as a wallpaper for the main screen.
    Jun 29, 2009 | Palm Treo 500 Centro
    JVC LCD TV LT-42X688-powers on, blank screen. no picture,no sound
    You most definately have bad capacitors in the power supply. try and get it repaired as soon as possible, not an expensive repair that iv'e seen.
    Feb 04, 2009 | JVC LT-32P679 32 in. LCD TV
    My son did something when he was playing the xbox and now its not in english and he cant play it.can you help me put it back in english please
    1. Start your Xbox console with no disc in the disc tray. The Xbox Dashboard appears.
    2. On the Main Menu screen, press the directional pad (D-pad) down two times to select Settings, and then press the A button.
    3. On the Settings screen, press the D-pad down one time to select Language, and then press the A button.
    4. On the Language screen, press the D-pad up or down to select the language you want, and then press the A button.
    5. Press the B button to return to the Main Menu screen.
    Jan 31, 2009 | Microsoft Xbox Console
    Cant see ps3 main menu
    when in standby hold down the power button for over 4 seconds, it runs the optimal screen settings menu, hope this helps.
    Feb 26, 2008 | Sony Playstation 3 (PS3) Console
    Ps2
    you say it wont turn back on but it has power.
    is the light red ( stand by )
    or do you have green and blue lights
    Did it fall????
    try cleaning the disk and the lens
    you can also run the auto diagnosis..
    HERE'S HOW
    Auto-Diagnosis (PlayStation 2 system) 1. Turn on the system without a disc inside. 2. Once at the Main Menu, press the triangle button to enter the Version Information Screen. 3. Highlight the "Console" option, and then press the triangle button again. 4. Next, press the X button, highlight "On", and then press the X button once more. 5. Now press the circle button twice to return to the Main Menu. 6. Press the eject button on the front of the console, and insert a disc. 7. Now close the disc tray, but DO NOT reset the system. 8. Highlight the Browser option from the Main Menu, and then press the X button. 9. In the Browser, an icon of the disc should appear on the screen. Highlight this icon, and then press the X button to read the disc. 10. If the auto-diagnosis is successful, the disc should load properly at this point. NOTE: The auto-diagnosis feature will return to "Off" the next time a disc is inserted.
    the above is a copyright of the PS2 user guide
    Dec 29, 2007 | Sony PlayStation 2 (PS2) Console
    Disk format
    1) Turn on machine
    2) Open Tray
    3) With tray still open hold the reset until the tray closes.
    4) Tap the reset once.
    if there is a format disc error, it says "Please insert a Playstation or Playstation 2 format disc." It is accompanied by a sound similar to the browser, but with a more tense noise. This is caused by a disc being so badly scratched that it completely fails to recognise the format, or if there is a problem with the laser. Auto-Diagnosis (PlayStation 2 system) 1. Turn on the system without a disc inside. 2. Once at the Main Menu, press the triangle button to enter the Version Information Screen. 3. Highlight the "Console" option, and then press the triangle button again. 4. Next, press the X button, highlight "On", and then press the X button once more. 5. Now press the circle button twice to return to the Main Menu. 6. Press the eject button on the front of the console, and insert a disc. 7. Now close the disc tray, but DO NOT reset the system. 8. Highlight the Browser option from the Main Menu, and then press the X button. 9. In the Browser, an icon of the disc should appear on the screen. Highlight this icon, and then press the X button to read the disc. 10. If the auto-diagnosis is successful, the disc should load properly at this point.NOTE: The auto-diagnosis feature will return to "Off" the next time a disc is inserted.
    Dec 15, 2007 | Sony PlayStation 2 (PS2) Console
    SanDisk Sansa e250 MP3 Player Logo
    14 people viewed this question
    Top SanDisk Audio Players & Recorders Experts
    Gyula Lacz
    Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
