My wireless mouse and keyboard have stopped working. I have replaced batteries, re-seated the receiver into the usb port, rebooted my laptop, etc... From the instructions that came with them, I think the code needs to be reset. Any idea how to do that??
  • 11,800 Answers
On the receiver for the set is a small button. To make a pairing of your set you will have to press it (a led will blink/light up) and then, immediately, type something on the keyboard and move the mouse, in this order. Wait a few seconds and try again, the pairing process should have been done.
If it hasn't then most likely the receiver has failed, you will have to buy a new set.
Posted on Dec 31, 2010
Wireless mouse won't work, have replace battery, rebooted laptop removed and replaced mouse connection etc. Was working fine until yesterday
Is it not working at all or is it moving erratically across the screen? If it doesn't seem to be working at all, turn off your mouse then unplug the receiver's USB cable from the laptop for about 5-10 seconds then plug it in to another USB port. It may detect a new device, just let it do the automatic installation if it asks. You should here a 'tada' or ding sound when it is plugged in. When installation is completed or about 10 seconds after you hear the sound, turn your mouse back on.
If it still doesn't work, try shutting down your laptop completely instead of just rebooting it.
If it still doesn't work after that, make sure you have a spare USB mouse available then uninstall the software for your wireless mouse or mouse/keyboard combo then reinstall it.
Mar 23, 2011 | HP Wireless Optical Mouse
Cannot get mouse to work
1.
If the underside of the mouse has an on/off switch, make sure to set the switch to the "On" position.
2.
Restart the computer. This can resolve the problem, at least temporarily, so that other troubleshooting steps can be applied.
3.
Move the mouse or keyboard closer to the receiver
The receiver is the hardware that receives the wireless signals from the keyboard and mouse and communicates the data to the computer. Most receivers connect to a USB port, either directly or by a cable, but a few types of receivers connect to the PS/2 ports.
. Make sure that the keyboard and the mouse are within 100 centimeters (39 inches) of the receiver. If the receiver is attached to a cord, position it so that it is on the same level surface, close to the mouse and keyboard.
4. Replace the batteries with a fresh set of alkaline batteries and make sure they are correctly installed. If the mouse or keyboard is not working, then replace the batteries, even if the mouse/keyboard software indicate the batteries still have a charge.
Remove the battery cover to access the batteries. For keyboards, the battery access cover is found on the underside of the keyboard. When replacing the batteries look for the positive symbol (a plus sign +) imprinted near the battery compartment or battery cover. Make sure the positive end of the battery is oriented to the positive side of the compartment.
5.
If you have a USB receiver, unplug the USB receiver, wait 10 seconds, and then insert it into another USB port - preferably into a USB port that is closer to the mouse and keyboard. For example, if the USB receiver was plugged into a USB port on the back of the computer, unplug it and plug it into a front USB port.
6.
Resync the wireless keyboard and mouse connections.
Resync the keyboard and mouse connections for receivers with a connect button .
Resynchronizing the keyboard and/or mouse causes the devices to reconnect to the receiver using new identification numbers.
NOTE: The following connection sequence must be completed within 60 seconds. If the sequence is not done in 60 seconds, start over.
Sep 10, 2010 | HP Wireless Optical Mouse
My Kensington wireless keyboard (Ci70) just stopped working. I have no idea why. The mouse works just fine. XP Pro SP 3. Have rebooted. Unplugged the USB interface device. Plugged back in. Rebooted....
Replace batteries in keyboard and re-sync the devices
>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>- --> Synching Mouse or Keyboard with Wireless Optical Desktop trnsp.gif Question My mouse or keyboard doesn't work with my Wireless Optical Desktop (Model Number: 64373). What's wrong and how do I fix this problem? trnsp.gif Answer Your mouse or keyboard has lost its sychronization with the Wireless Optical Desktop, which can occur after changing the batteries, for example.
To synchronize your wireless device with its receiver:
  1. Move the device within three (3) feet of the receiver.
  2. Press the button on the receiver.
    If the receiver has an LED, the light blinks.
  3. Within ten (10) seconds, press the button on the underside of your wireless device.
    If the receiver has an LED, the light glows solidly when synchronization is successful.
Early production units of some wireless devices may require repeating the above instructions two or three times.
Timing, distance, and objects impeding the wireless signal may influence your success. While usually unnecessary, some customers have reported better results by:
  • Holding the wireless device very close, within three (3) inches of the receiver.
  • Entirely ignoring the receiver's light.
  • Simultaneously holding the buttons on both the receiver and the device for from ten (10) to twenty (20) seconds.
Dec 12, 2009 | Kensington Computers & Internet
Asus CS5111 keyboard stopped working
Try taking the batteries out of the mouse and let the receiver find the keyboard first, then once the keyboard is found put batteries back in mouse and let the receiver find the mouse.
Nov 21, 2009 | ASUS Computers & Internet
Wireless keyboard and mouse not working, battery in receiver?
The receiver should not have a battery. It gets its power from the USB port. Try uninstalling both keyboard and mouse via (Control Panel...Device Manager) and reinstalling them. Sometimes the drivers get corrupted and reinstalling them will fix that. Also there are on/off switches on the mouse and maybe the keyboard. Check that someone hasn't turned them off to save batteries when not in use.
Sep 17, 2009 | Dell Wireless Keyboard Optical Mouse w0147
Technika optical wireless mouse not working
Make sure the mouse is linking to the wireless receiver on you have plugged into the computer (there should be a reset button on the mouse to establish a new link).
May 13, 2009 | Casio Parts Cash Register PC Desktop
Wireless mouse not picking up
Normal 0 Try disconnecting the Mouse Receiver from the USB port and reinstall the CD software program. When the program asks you to connect the Mouse Receiver to the USB port, do so and it should work.
Hope this helps. Bud
Feb 25, 2008 | Fellowes Manufacturing 99666...
Wireless keyboard stopped connecting to receiver
Im sorry but you are going to have to phone and tell the device manager the problem again otherwise get a refund and go with the wired keyboards!
Hope this helps - JoshHoward
Feb 02, 2008 | Logitech Deluxe Access Keyboard
Re: wireless mouse doesn't work
my wireless mouse has packed up the light is on ive tried new batteries what else can i try
May 25, 2007 | Impression Products Impression M1 Wireless...
Computers & Internet Logo
54 people viewed this question
David Payne
David Payne
