Question about Cameras
Pentax PZ1 The mirror and shutter are locked on my PZ1 film camera, I am told that it would cost more to repair than it is worth so I would like to try myself. Another expert thinks that the internal gears may be jammed or seized so I would like to know how to get at the gears. Do I remove the bottom plate and work inwards from there or the top plate?
SOURCE: Pentax Optio A10 lcd replacement
Re PENTAX OPTIO A10 LCD Replacement
I wish Mike Brunner would advise us where we can get a replacement LCD for $40, was it from a used camera?. A new one  from PENTAX   Part Number 76650-0500 Tel 1 800 877 0155  Is just under $60 plus $8 shipping in the USA but is currently out of stock. There is also a San Diego company with limited stock (5) that wants about $70.
 Removal of the LCD is relatively straight forward.  First remove the battery and the card. Then unscrew some very minute philips screws and carfully remove the back cover. Separate the two halves of the cover with a thumbnail to unhook a snap connection after the screws have been removed.
It's best not to remove the front cover so as to avoid damage or contamination of unrelated areas.
To remove the LCD look for the retaining snaps and gently pry the left side ( camera facing forward and upright) back and lift the
left side of LCD up and unhook the right side.
The LCD will now still be attached by the multi wire strap and a minute two wire connector. Using tweezers on the plug and not the wires gently disconnect the two wire connector. The multi wire strap with about 25 miniscule gold connectors is held down on the mating contacts with a clear sticky tape. I was able to pull mine loose before I saw the sticky tape.
To reinstall the replacement LCD a very good magnification of the 25 or so contacts may be required to correctly line up all the mating contacts on the back of the camera as there is no apparent mechanical means to correctly align this.
There is no soldering required or practical at his connection.
Use some clear sticky tape to hold it in position.After reconnecting the 2 wire plug the right way up and when the LCD is folded over back into position and snapped down into to the retension snaps,this should also apply gentle presure to the 25 pin connector. Adding a very thin layer of non conductive material over the 25 pin connector before snapping the LCD back might be helpfull in the longterm retension but too much compression will may fail the new LCD. ( Well that is what I'm going to do when I get my LCD) ( I may also put the battery and card back in and switch it on before replacing the rear cover taking care not to get an electrical shock through some accidental discharge, so don't do as I say unless you know what you are doing)
 Re assembling the rest should be straight forward. Then test the result.
 Note: The camera buff who encouraged me to do my own repair has added an extra layer of clear plastic over the exterior cover of the LCD to better protect it. It is also advisable to have a hard case or reinforce a small soft case with a used credit card to protect the LCD, so as not to have to repeat this again.
Good Luck. From Santa Cruzer
Posted on Oct 16, 2007
  • 667 Answers
SOURCE: Stuck shutter D100 Nikon
The R06 is the buffer indication, not part of the error. It would appear more work is required. Other components may have failed, or the shutter itself may be bad.
I'm afraid this one is not a DIY. Nikon is pricey on repairs, you may fair better checking the repair service search here on Fixya.
Posted on Mar 31, 2008
SOURCE: will not power on, lens stuck, poor warranty
my camra lens wont open what do i do emial me at
Posted on Apr 06, 2008
SOURCE: Nikon Coolpix L16
i recently bought my cool pix l16 camera and when i took a pic my flash lamp kept blinking red and when i pressed the flash button my camera wouldnt flash
Posted on Jul 07, 2008
  • 1257 Answers
Solution of lens struck :
There is a very very easy way to fix this problem..
This can happen if...
1.) If the battery dies when the camera lens is open (and you close it manually, or sometimes, even if you dont.)
2.) If you used a AC adapter with too much voltage or not enough. (this can happen even if you used the correct voltage, refrain from using AC adapters at all)
... all together its ethier a voltage or camera lens problem...
Do as i say..
1.) Remove battery
2.) Remove front plate (screw driver may be needed)
3.) Check all gears, make sure they are correctly fitted in place)
4.) Move the gear manually to make the lens come out.
5.) keep it out, put the front plate back together.
6.) reinsert the battery, turn it on.
1.) Remove the battery.
2.) Wait about 6-8 hours.
3.) Reinsert the battery.
2.) Try hooking it up through AC adapter, put correct voltage.
3.) Try turning it on.
4.) Remove AC adapter, reinsert battery.
5.) Turn it on.
Hopefully all this information helped,
Posted on Jul 10, 2008
The mirror motor on most KX, MZ, and other late model Pentax film cameras has a small plastic gear on the shaft that cracks, so that it will not drive the mirror up or down. Pentax originally replaced it with a larger gear made with better plastic, but they had problems with those also, so the eventually went with a brass gear
I don't believe the part is available any longer, or so I was told last time I tried to order one. Which is fine with me, as they are a real pain to work on and I do not recommend you try and fix it yourself.
Jul 06, 2012 | Pentax MZ-7 Film Camera
Mirror is locked open
Unless you have experience repairing cameras, this is not a DIY fix. Take your camera to a reputable camera shop and have a trained professional look at it.
Feb 03, 2012 | Pentax ME Super 35mm SLR Camera
Pentax me super mirror in up position
If the batteries are flat or missing you wont get LED's to light up and it will set itself to 125 naturally. I know as I have tried it. It could be that the shutter has got stuck on its way down and it is preventing the mirror from coming down as a result this is a mechanical issue, not battery related. The best way I found to release the mirror was to gently, really gently stroke the shutter nearest to the film down towards the groove it goes home in. Recommend a cotton budd so you don't damage the shutter leaves or get grease from your fingers on the movement. This should release the mirror. The next thing to do is try preventing the shutter getting stuck again by removing the bottom plate which will allow you access to the cogs for the shutter. it is tight in there and it is recommended by some that you remove some of the movement to see and clean them up. I did this but it is tricky and it involves winding on the camera and rocking parts out with itself. Not easy to do. The shutter cogs are brass (or look like it) and they may have old oil stuck inbetween the teeth which needs cleaning out with a tooth pick and then lubricate but not with WD40 which gets sticky with age. Use a cotton budd again with the lubricant on so you don't affect other sensitive parts around this section. Alternatively send the camera for a good service. I just had mine done, got it sorted with a warranty for 12 months to and cost me just £45. They cleaned everything up, new light seals and sorted issues common to this model of camera. The photos are instantly back to their best. Compare a good service to a series of wasted film with an inconsistent camera. Peace of mind too, it is worth it and so is the camera!
Mar 25, 2010 | Pentax ME Super 35mm SLR Camera
The mirror on my pentax pz1 (film) camera is stuck
Mirror lockup often occurs if the batteries are flat.
Try new batteries first and if the problem remains please report back for further options.
Feb 13, 2010 | Pentax PZ-70 QD 35mm SLR Camera
Pentax ME Super
Does the film advance lever lock in place when the lever is returned ? if not, the lock spring broke. This is a common weak point in the ME Super. the camera must be partially disassembled to be repaired. get a cost estimate first. there are no new parts for this model Pentax.
Jan 04, 2010 | Pentax ME Super 35mm SLR Camera
Is my ME Super toast?
It doesn't need batteries to shoot. You can use it on manual without batteries, but the exposure meter won't work (if you know what you're doing you can go by). But the stuck mirror should be fixed. It could be just plain dirty/rusty/bent etc.
The advance lever might be gone since it won't 'click'. A professional shop can fix it, but the one you tried doesn't sound very professional...
Jun 09, 2009 | Pentax ME Super 35mm SLR Camera
Pentax K2 Shutter and mirror problem
Without a stripdown it's not possible to give a definitive answer. Clearly the mechnical interlock which prevents the shutter from firing until the mirror is out of the way is not functioning correctly, but pressing the dof button overcomes this.
It's possible that something has broken or worn internally, but far more likely that old dried camera grease coupled with decomposing gooey foam bumpers and light seals has gummed up the workings.
Now that film SLR's are ten a penny and often free on FreeCycle it's certainly makes no economical sense to repair this camera. But it's a real classic and a delight to use so it's worth sending to a professional repair shop for a thorough service just as you would with a classic car or motorbike.
Jun 03, 2009 | Pentax K2 Film Camera
Pentax ME Super Shutter and Rapid Wind Button...
it could be the rubber bumper next to the fresnel lens has become sticky. very gently ( after removing lens ) try to bring mirror down without forcing it. it should release easily.
if not, rotate the select knob off auto. open film door and check that the shutter is fully deployed, shutters should not be overlapping.
remove screws from bottom cover and remove cover, keep camera up side down so that re-wind button stays put. there is a locking lever under the take up spool ( gray ) . with a pin move lever toward film door and bring advance lever fully to the right , then let it go so it returns quickly.
the shutter should have fired. if not the camera will need to be repaired. get an estimate first as there are no new parts available.
Dec 24, 2008 | Pentax ME Super 35mm SLR Camera
Sticking shutter/unable to advance film
Probably. That camera has several rubber bumpers and gaskets in the mirror mechanism that have a tendency to turn into sticky gooey sludge causing the levers in the shutter and mirror mechanisms to get sluggish. The only real solution is to completely disassemble the camera to clean out the old goop and replace them with newer neoprene fittings. My suggestion would be to find a replacement body since the repair is probably going to cost between $80 to $90 and you can probebly find a good used body for less than that.
Aug 05, 2008 | Pentax ME Super 35mm SLR Camera
Film advance lever
Yes this is fairly common with K 1000 and the Spotmatics : although the shutter is cocked and hence you cannot advance film you cannot release shutter because mirror box is not cocked. Remedy : remove bottom cover and locate mirror box lever which protrudes slightely and is movable up and down and is spring loaded. Move upwards until it licks in position ( moving up against spring tension ). Now release the shutter and camera should let you advance the film .
Sep 17, 2007 | Pentax K1000 35mm SLR Camera
Cameras Logo
35 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
