Need to bypass my interlock on washer to determin that is the fault
Remove 3 wire connector from the interlock unit. This has 3 wires one black and 2 white. Short out the sockets of the two white leads. Start machine and the door lock light on front panel will be on.
Posted on Aug 19, 2008
WHY IA MY 2005 NISSAN ALTIMA WILL NOT SHIFT FROM PARK?
The most common culprit for this failure is that the interlock release solenoid has failed, either because it is jammed or because your brake light circuit has failed. (Do I need to mention that your foot must be on the brake in order to take the vehicle out of Park?)
First, check your Owner's Manual to determine how to bypass the interlock so that you can move the vehicle (if you need to move it).
Next, verify that your brake lights are working. If they are not, replace the fuse for that circuit. If they are still not working, replace the brake light switch.
Next, remove the cover from the PRNDL and check the condition of the interlock solenoid. Make sure it is receiving voltage when the brake is applied. Replace as necessary.
May 14, 2014 | 2005 Nissan Altima 2.5
Lid lock bypass
Your "lid lock" really is an interlock to prevent machine operation when the lid is open. I use a plastic clothespin to close the interlock because the lid on my washer got bent
May 12, 2013 | Frigidaire Washing Machines
I can't start the car in remote need to bypass clutch interlock switch how do I do that with out removeing plug. Remote is compatible for both automatic and manual transmission.Don not know what t
I do not recommend remote start systems for manual transmissions. You would have to bypass the clutch interlock to enable the starting circuit. If you left the vehicle in gear and used the remote you could do damage to the vehicle or other property (hopefully the parking brake holds the car in place). I have never seen a factory remote system on a manual transmission, to much liability....
Jan 01, 2013 | Cars & Trucks
My maytag pav2300aww will not spin at all yet it agitates and drains well I was told to clean the agitator so I took it off yet the washer still don't spin the switch look wore out to me so I by-passe
Check the water level sensor and the lid safety interlock. Many washers will work fine with the lid open EXCEPT during the spin cycle, so this is the first logical place to look. Try bypassing the lid safety interlock switch.
Dec 12, 2012 | Washing Machines
Washes fine will not spin and drain
One of the main reasons for the washer not to spin or drain is the interlock switch. Top load washers are designed with an interlock switch that stops the machine if the lid is opened during a spin cycle. This switch is operated by a post mounted on the lid that goes into a hole in the rim of the machine and pushes down on the switch, or a bump on the side of the lid right by the hinge that presses against a switch when the lid is closed.
Determine which type you have. If it is the type with a hole and post, get a screwdriver and stick it into the hole with the machine in the spin cycle and the knob pulled out. If the machine starts, then the post is missing or broken.
If you have the other type of door interlock then the switch may not be working, but you will need a service call to fix it.
Would appreciate if you mentioned the model number of the washer.
Thank you for contacting www.Fixya.com
Jul 27, 2009 | Washing Machines
E40 on my washing machine
E40 is an error from the door locking mech (interlock).this is the bit behind the port hole door frame ,where the door striker pin goes through hole.hope this helps you.held on with 2 screws and you need to remove plastic clamp from door gasket to gain access.
E40.door not locking.door interlock faulty or triac faulty on pcb
hope this helps pls do let me know
Feb 20, 2009 | Zanussi ZWF1430W Front Load Washer
Ariston washing machine
Door not shut Check that the door is properly shut.Faulty interlock A faulty interlock might not allow the door to shut properly. Find your door interlock here and replace, or contact a qualified repairer.
No power Check the flex, plug wiring, fuse and mains supply for faults.
Faulty on/off switch Check the power light if fitted. Replace your on/off switch.
Water supply disconnected or off If a washer dryer cannot load water it cannot start a wash cycle. Check water supply.
Nov 17, 2008 | Ariston Technologies AW125NA 13 lbs. Load...
Door interlock switch
the door interlock switches are safety switches so the washers stops when the door is open if bypassed and the door is open could be a mess and damage floor so let your mind be your guide its not recommend by factories who are damage minded hope this helps but it wold work i mean if such a condition existed the washer would run
Jan 10, 2008 | Dishwashers
2000 neptune stack
the micro switch which is part of the door interlock may be at fault, & need replacing. Or a wire may be broken/burned off
 in the interlock. Or it may just be stiff, try spraying it with WD40 (not whilst the power is on!!)
Oct 19, 2007 | Neptune MLG2000A Front Load Stacked Washer...
Washing Machines Logo
112 people viewed this question
Top Washing Machines Experts
