Question about Fortec Star Lifetime ULTRA
Passion+HD they advised upgraded to p_av144.2 to recieve hd channels since doing so have lost usb copying facitily no usb menu defaults vcr only
Do you know where I can find the firmware update (1.18) for a Bauhn 1Tb PVR?
http://tempoaustralia.com/sw/as-pvr1000r/AS-PVR1000R_IM.pdf
DG-DABVPR1TB
down load and put on a usb drive,
DGTEC firmware 2011 updates available
New updates available for service issues such as freezing and start up/ recording issues (firmware 2011) are also available from the DGTEC website.
Please update software first before replacing hardware...
From DGTEC Website Software Upgrades page: -
Click on the relevant link below to download the latest software update for your DGTEC product. For further help and assistance, please access the DGTEC Call Centre via the Support page.
Obsolete Products
* DG-FV500PVR Upgrade (zip file 4.3Mb)
* DG-HD6760 Upgrade (rar file 2.3Mb) Upgrade instructions DG-HD6760 (25Kb)
New Products
DG-HDMP1080
DG-HDMP1080P
DG-HDMP1080TT
DG-HDMP500TT
DG-DABVPR1TB
DG-DABPVR500GB
DG-HD2104AND
Models
DG-FV500PVR - 500GB HD PVR WITH TWIN TUNER (FREEVIEW)
DG-HD6760 - HD SET TOP BOX WITH USB RECORDING
DG-HDMP1080 - HD MEDIA PLAYER
DG-HDMP1080P - WIRELESS HD MULTI MEDIA PLAYER / STB
DG-HDMP1080TT - HD MEDIA PLAYER WITH TWIN TUNER
DG-HDMP500TT - (NEW MODEL RELEASE)
DG-DABVPR1TB - 1TB HD PVR WITH TWIN TUNER WITH INTEGRAT
DG-DABPVR500GB / DG-DAB+500PVR- 500GB HD PVR / TWIN TUNER WITH INTEGRATED
TV-6600 BAUHN UNIT- 500GB HD TWIN TUNER PVR
GG-HD1200PVR- BAUHN UNIT WITH TWIN TUNER
Note: - Master Override Password 1973
Instructions:
Read instructions carefully before commencing. Software needs to be carried out while the PVR is cold. Go to "Telefix" website and select "Service Guide" or "Download Service Manuals" and download software to a location on the PC Hard Drive.
Unzip file and copy "usb.upg" software onto a blank USB Memory Stick.
Plug USB Stick to USB port of PVR
Connect Power to PVR and switch on so that that the booting process commences.
Press 'Menu' button and scroll left or right by using the arrow buttons to find 'Installation' then press OK to select.
Note: PVR may freeze and not allow selection. Several attempts will be required to enable selection. If problem persists, switch OFF PVR to allow it to cool down then try again or use the alternative method.
Alternative Method
1a. Disconnect mains power.
2a. Plug USB Memory Stick to USB port.
3a. Press and hold the CH down arrow button on the unit and then connect mains power.
4a. When the display starts counting down release channel button and the upgrade interface will appear on screen.
7. Scroll down to 'USB Menu' by using the arrow down button then press 'OK' to select.
8. Scroll down to 'USB Upgrade' by using the arrow down button then press 'OK' to commence software update.
ยท Note: - Please do not shutdown PVR or remove USB Stick during the update process. When the update is complete the PVR will power down and reboot again as normal.
Once the update has completed, reset the PVR by restoring back to Factory Default.
Press Menu ? Installation ? Factory Default ? enter password 0 0 0 0 ? Select 'Yes' ? press OK to rescan channels.
Check Software Version, Press Menu ? Installation ? Version Info ? OK
download and put on usb drive
Software Updates
Apr 11, 2015 | Televison & Video
Can't switch on menu or the timer
clean the display and change battery in remote.
Jul 06, 2010 | Samsung SV3000W VHS VCR
Problem recording of hd tv with cable box from
Here are a few items to check and how you need to set your recording.
1. Your HD box should have a coax out (or to TV) connection on the back of the box.
2. Connect a coax cable from the back of the HD box to the "RF IN (FROM ANT.)" in the back of the VCR.
3. When you set your VCR to record you need to set it to copy channel 3 and tune the HD box to the channel you want to record.
This should fix your problem...
Good Luck...
Jan 07, 2010 | Toshiba W522 VHS VCR
I ripped Bluray movies using "ANY DVD HD" to my hardrive then playing them through "WD TV Live HD Media Player" (using HDMI cable to Sony Bravia HD L.C.D.TV) some movies work good but others play the video...
Either check around in Any DVD HD or the BluRay menu to set audio output to PCM, which doesn't require any decoding to play back properly or you will have to convert them separately.
Nov 30, 2009 | Western Digital TV HD Media Player USB...
My 47" LG has an internal HD reciever but it isn't picking up any HD channels.
Is it connected to an antenna? Did you do a channel scan for digital channels? See www.dtvanswers.com or http://dtv.gov/iguide.htm for more information.
Sep 03, 2009 | LG 47LC7DF 47 in. LCD HDTV
Screen is blank after (accidently) setting HD Res from 480 to 720
Followed the manual to return to the Default settings, using the remote "in the blind" pressing the arrow and Enter buttons, hoping I hit the right menu button. I did. Case solved. Thanks
Mar 18, 2009 | Televison & Video
I purchased a SANYO-DP46848 42"HDTV. I have a Cable box and my cable provider (Time Warner Cable) provides free HD Channels. However.... I CANNOT PICKUP ANY HD CHANNELS ON THE NEW TV. WHY???...
I just got the same exact one, when it searches automatically the first time it doesn't look for digital channels. go to Menu>manual channel search>cable. it will look for all possible signals and will take forever probably. the free digital channels will take several seconds to switch channel to channel, but they're there! They will show up on your screen as "DC 91-2" or similar. you can switch back to regular cable channels with the input button, you just cycle through all the inputs. hope that helps.
May 18, 2008 | Televison & Video
1080 VS 480
Trash can it and buy a new T.V.
Jan 06, 2008 | Mitsubishi VS-50111 50" Rear Projection...
Picture not HD quality while watching HD channels
Make sure you are using an HDMI video cable for optimal picture quality. Also, you must be using an HD reciever.
Jun 12, 2007 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
Hd ready?
On any High Def TV, the reciever you need for this set, which does not have a HD receiver in it, is half the equation. Most HD channels have some HD content mixed with SD content on the same channel. SD content on HD signal from cable or satellite tends to be slightly blocky due to the native signal resolution and the resolution of HD (1080i/p or 720i/p).
Apr 30, 2007 | Akai PTH5498 54" Rear Projection...
Televison & Video Logo
24 people viewed this question
Top Fortec Star Televison & Video Experts
Jaime Hernandez
Grantec 2000
Level 1 Expert
Jerry Kramer
Jerry Kramer
Are you a Fortec Star Televison and Video Expert? Answer questions, earn points and help others
