Question about Home
I'm trying to connect brasscraft multi-straight valve ocr14c1 to cpvc but i turn the water on and the hose that cames down from the faucet came out of the cpvc so i don't know what to do
huuum
  • 750 Answers
SOURCE: the connection from the dishwasher
Hello raymun30,
Welcome
You said,the connection from the dishwasher hose at the faucet leaks and sprays water. I tried changing the rubber seal in the hose, but that didn't help. any other suggestions?
What is the Make and model number of your portable dishwasher?
And how old is it?
If I have the number can look into the repair manual and at the diagrams and tell you what part you may need.
Find the complete model number. Waiting your response.
Huuum
That connector attachment can be replaced!!!!!!
Posted on Oct 20, 2008
  • 659 Answers
SOURCE: Replace valve in grohe kitchen faucet
If you could take a closeup picture of the valve and faucet, I can guide you step by step. Just email me at newairac@sbcglobal.net. Without seeing what you are looking at and working on, it would be hard because there are so many different styles and brands and each are unique.
Posted on Mar 23, 2009
  • 11 Answers
SOURCE: faucet issue
Sounds like it was installed upside down or the cartridge is installed improperly
Posted on May 07, 2009
  • 323 Answers
SOURCE: 2003 Town & Country 3.3 L PCV valve location
It is on the rear valve cover. The hose that runs to it from the intake usually gets hard and brittle so be careful not to break it.
Posted on May 31, 2009
  • 19 Answers
SOURCE: New faucet, sprayer hooked up right, no water going into hose?
check the sprayer handle by disconnecting and blowing into it and pressing sprayer handle and/or for possible kink at main body or hose by disconnected sprayer point hose into sink and turn on water. If no water the the diverter in main body is not working properly and needs to be reassembled or replaced
Posted on Jul 07, 2009
HOT AND COLD WATER STOPPED COMING OUT OF OUR KITCHEN FAUCET
Do you get water when you disconnect hose from the faucet? If so, perhaps plastic backflow preventor in the faucet is stuck?
May 29, 2012 | Pegasus Technologies Plumbing
Washing machine flashes and beeps E70
Hi
Error code E70 means Cold water hose is connected to wrong faucet or Cold water faucet is not turned on. If this is not the case then check the cold water hose, whether it is kinked or plugged. If the hose is fine then the fill valve assembly has turned bad and you would need to replace the valve. Connect hose to cold water faucet and cold water inlet on washer. Be sure cold water faucet is fully opened.
Hope this helps... Please post back if you need more information.
Daniel
Jan 01, 2011 | Frigidaire Washing Machines
Error code #E70
Hi
Error code E70 means Cold water hose is connected to wrong faucet or Cold water faucet is not turned on. If this is not the case then check the cold water hose, whether it is kinked or plugged. If the hose is fine then the fill valve assembly has turned bad and you would need to replace the valve. Connect hose to cold water faucet and cold water inlet on washer. Be sure cold water faucet is fully opened.Hope this helps... Please post back for more information.
Daniel
Nov 16, 2010 | Kenmore 43142 Front Load Washer
E70 flashing at end of wash cycle
Hi
Error code E70 means Cold water hose is connected to wrong faucet or Cold water faucet is not turned on. If this is not the case then check the cold water hose, whether it is kinked or plugged. If the hose is fine then the fill valve assembly has turned bad and you would need to replace the valve. Connect hose to cold water faucet and cold water inlet on washer. Be sure cold water faucet is fully opened. Hope this helps...
Daniel
Sep 01, 2010 | Frigidaire Washing Machines
The hot water side has low water pressure. The
start by making sure the valve that supplies hot water to the sink and dish washer is fully open. If there is low hot water pressure in any of the other kitchen/bathrooms, then trace the line to see where the pressure drops. If it is only in the kitchen, it should be an old valve, (causes restriction)Good Luck.
Oct 10, 2009 | Whitehaus Kitchen Single Handle Faucet...
We have pressure on the cold water side but not on the hot. The faucet in the bathroom sink has hot water pressure.
make sure your water valve is working properly undo line and open valve if its working than take apart faucet and check for debri
Jul 17, 2009 | Moen 7310 Legend Single-Handle Kitchen...
Low water flow from kitchen faucet
Their is likely rust build up behind the valve connections to the hot and possibly cold water supply lines. Turn the water off to the house relieve the pressure and remove both valves. Once removed use a screwdriver to break up the rust. With a small bucket under both lines turn the water main back on slightly to clear rust. Replace both valves with new ones.
Jan 04, 2009 | Kenmore 24 in. 17482 / 17484 / 17489...
Low pressure and flow on hot water side of single handle faucet
It could be one of two problems, one simple, one serious.
  • Easy fix
  1. Turn off hot water angle stop under sink to faucet.
  2. Remove supply line from hot angle stop.
  3. Place end of supply line in a small bucket to catch some water.
  4. Turn on cold water for a couple of seconds and backflush debris from faucet.
  5. Reconnect supply line.
  6. Turn on angle stop and test
  • Complex fix
If you have steel pipes you may be experiencing reduced flow due to corrosion in your pipes. Reduced hot water pressure in the kitchen faucet is usually the first sign since this is the faucet that is most used in the home.
Repiping is a job for a professional. Another symptom you may need a repipe is orange colored or rusty water.
Nov 14, 2008 | Delta Faucet Plumbing
Home Logo
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
