Question about Zebex Z-3080 Handheld
Hi, i need driver for z-3080 barcode reader..can you tell me an address to download it?
My finger print sensor in hp compaq6910p is not detected in device manager. plz help me to enable it.
Hi
You finger print reader driver is not install in you laptop, for the driver click hear and select the finger print driver and download, after downloading the driver follow the mention below instruction.
1) Select the download file, and start to setup.
2) The setup file is extracting in C:\.
3) Go to the C:\ and start to setup after complete the setup, reboot your system, and check now you finger print reader show in device manager.
Thanks
Aug 19, 2011 | Computers & Internet
How to know the drivers to install on a cpu
Dear sir...
you dont worry about the cpu.you just consider the OS only(Operating sytem).search the barcode driver in google with barcoder brand name with model no.(model no specified in the lable of barcode reader)
Example: free download barcode reader for sanion AG1020 driver for vista
here,
sanion is a brand name,
AG1020 is model printed on barcode reader body,
Vista is Operating system instaled in the computer.
ALL THE BEST SIR...
Dec 04, 2010 | Computers & Internet
Installing the Zebex z-3010
Normally, these scanners need no software, as they simply send a series of digits to the active text box. Try opening notepad or word and scanning any barcode. It should type the number itself.
Apr 14, 2010 | Zebex Z-3080 Handheld
WHERE CAN I DOWNLOAD ZEBEX Z-3080 SCANNER SOFTWARE?
This device needs no software. You first need to set it up with the configuration card (http://www.zebex.com/old_website/documents/quick_program_card/z-3000.3001.3010/Programming%20Card_U_090202.pdf). Then it should scan the barcode number in to the selected text area.
Mar 24, 2010 | Zebex Z-3080 Handheld
Barcode scanner
please get programing manual for Z-3080 then
scan start of configuration barcode then USB emulation barcode then end of configuration barcode
probably your problem wiil be solved.
Nov 01, 2008 | Zebex Z-3080 Handheld
Handheld Symbol LS4000-I100 barcode reader
you need to use the code book (the programmers book) to configure the reader, you need to tell it how to communicate with the PC (bit rate, stop bits etc....)
this code book should have come with the reader...
this book has barcodes on many pages and also configures the types of barcodes that the scanner can read....
if you do not have the code book you can download it from the maufacturers website
Jul 08, 2008 | Symbol PN: LS4000-I100 Laser Scanner...
Analys of how to connect java application to bar code reader
You will most likely need a java-bridge to connect to the drivers installed to run the scanner. Maybe google more on Java POS to find out more on connecting Java with POS Devices.
Apr 04, 2008 | Computers & Internet
Zebex Z-3080 - prefix ? software ?
Please download the Programming Guide from the link http://www.zebex.com/documents/Users'%20Manual/A.Handheld/Programming%20Guide%20(MUL-53221-07).pdf.
Attached please find the samples for programmings.
Aug 15, 2006 | Zebex Z-3080 Handheld
Zebex Z-3080 Handheld Logo
98 people viewed this question
Top Zebex Computers & Internet Experts
David Payne
David Payne
Are you a Zebex Computer and Internet Expert? Answer questions, earn points and help others
