Question about Eclipse 5440
When i unhooked then reconnected the battery in my truck my eclipse 54400 started flashing UP 7910 and Dn 1646 and the ESN on the face illuminated.
3 Suggested Answers
  • 24 Answers
SOURCE: Eclipse 54400
the unit is locked up eclipse has a feature called esn or eclipse security network. you use a cd to program a passkey that only the owner knows. then if it is stolen the unit is useless. unless you know the right cd cool huh? if the unit is registered to you they will help you unlock it but if not they wont. cool huh. kinda makes you feel good that even if someone does steal your radio they cant use it.. ever.. eclipse also offers a one year theft guarantee out of the box if you register it with them. cool huh..
Posted on Feb 21, 2008
  • 14 Answers
SOURCE: i unhooked my eclipse 54400 cd receiver now it is
I have the same problem what the F@#k is that?? usually you just push the reset button under the volume know(very small) but, this is not working for me, maybe will work for you.
Posted on Dec 04, 2009
Radio worked, battery replaced, radio light up but does not work?
assuming it displays the message "sec"; eclipse models use a securty cd to generate an new temporary security code and let you unlock it if you have that cd it ok but if not you have to get it or get the whole module serviced at your local eclipse dealer...
Apr 25, 2016 | Mercedes-Benz S-Class Cars & Trucks
No security code audio system
These units do not have a security code like some radios. Instead, they are coded using a CD. You insert a CD into the radio and it codes to that disc. You need that same CD if you ever want to unlock the player. If you don't have it, you are SOL. Eclipse is no longer in business and they were the only ones that could reset it. The system is known as "ESN Security".
ESN Security: This unit is equipped with the Eclipse Security Network. You can register a particular music CD as a "key" device which unlocks the security. If the registered CD is not detected, the navigation and audio functions will be disabled when the main unit is disconnected from and reconnected to the vehicle's battery.
Dec 16, 2013 | Eclipse CD2000 CD Player
2008 Mitsubishi eclipse radio not working after battery change
Unfortunately in newer vehicles, they sometimes need to have the computer re-flashed IF you unhook the battery with the radio on. It's a crummy deal. The dealership will probably have to re-flash the computer. You could try turning the stereo off, then disconnect the cables on the battery for a minute, then re-connect and POSSIBLY it could reset the system and it may work again. Don't get your hopes up, this may not fix it.
Nov 11, 2012 | 2008 Mitsubishi Eclipse GT
Won't power up. Displays SEC / Help Then SEC / 8D201399 Note the serial number is CD201399. Alan
All Eclipse brand radios have a feature called ESN (Eclipse Security Network) installed. This means a Key CD may be inserted into the head unit so that if the unit is stolen or battey is disconnected from the unit you will have to enter the key CD to unlock the unit.
For example, lets say you purchased this unit from bestbuy. You installed it in your car and you wanted to activate the ESN security feature. You need to choose anyone of your cd's from your collection, lets say you chose The Offsping, Conspiracy of One. Input the disc hit the correct buttons ( I'll explain those later) and your Eclipse 54400's ESN is active.
Now, your 54400 is stolen a week later, the thief will plug in the 54400 into his car and it will show SEC [disc], so he/she will insert a cd and it will say [ERR]. If he or she does this 5 times it will show [call 800] which will lead them to Eclipse customer service, but you will have already called eclipse and told them that your unit was stolen. Whether you get your head unit back is highly doubtful but nobody else will be able to use it.
Now for your answer, to activate ESN:
1.Turn the vehicles ignition on and press the power button 2. Press and hold Radio station preset 1 and the FM-AM button for more than one second 3. Insert the CD of your choice. A [SEC] message will now aooear on the screen and ESN is active. Anytime the unit loses power you will have to reinsert the key cd.
To deactivate the ESN feature:
1. Turn the vehicles ignition on and press the power button or the FM-AM button (make sure the tuner is on). 2. Press and hold the radio station preset button 1 and the FM-AM for more than one second. 3.Once the display flashes [disc] insert the key cd you selected to activate the ESN. The display should now read [CnCl]. The ESN is now deactivated.
To resume normal operation after the power has been disconnected to the unit:
1. Wait for the dispaly to read [disc]. 2. Insert you key cd, if the correct CD is inserted your display will read [---] and the cd will begin to play. If the wrong CD is inserted it will display [Err]. If you insert the wrong CD 5 times it will say [call 800] and then you have to send the unit to eclipse to have it rest. Good Luck!
How to read the Electronic Serial Number:
1. Turn the vehicles power on. Prss the FM-AM button. 2. Press radio preset button 4 and the FM-AM button for more than a second and the display should show your 8 digit serial number. This number is to identify your unit if it is recovered after being stolen. Yep, that will happen!
Keep in mind that the "security code" in a radio basically fulfills this function, ensure that in case of theft, the computer does not work in another vehicle;
I didnt know there was a website to get the radio codes. Before you pay anyone to get your radio security code, I recommend you get on the internet, Eclipse dealers, ask for the parts counter, tell them you need your radio code, have your serial number handy as well as all other numbers off the radio housing.
Or, call 1-800-233-2216 (Fujitsu ten) and they will assist you in the removal of the security code for a $25 charge. the number being displayed is probably the serial number of your unit. If you can remove your radio the SN will be on a tag.
Hope this helps.
Oct 28, 2010 | Eclipse CD3422 CD Player
How can I clear / reset a Cisco IP Phone 7910
How to set a Cisco IP phone to factory default Reset configuration of Cisco IP Phone (7910, 1911, 7940, 7941, 7960, 7961)
To set the Cisco IP phone to factory default completes the following steps: should be completed:
For 7940, 7941, 7960, 7961 phones:
1. Power up the phone (unplug power cable and plug in again and hold the # key.
2. Release # when lights start flashing.
3. Press 123456789*0#.
4. Press 1 to keep network configuration or 2 to lose the network configuration.
For 7906G and 7911G phones:
2. Release # when MWI starts flashing.
3. Press 3491672850*#.
Oct 28, 2010 | Cisco 7910 IP Phone
2002 eclipse wont start. electronic immobilizer light flashing. how do i deactivate immobilizer?
disconnect the neg battery terminal for 30 sec leave drivers door open, reconnect and start your car, if the alarm turns on after conecting battery use your key in the drivers door and unlock
Nov 12, 2009 | 2009 Mitsubishi Eclipse Spyder
I unhooked my eclipse 54400 cd receiver now it is reading call 800 up 7630 dn 1779
Aug 15, 2009 | Eclipse 5440
Eclipse cd2000 car stereo
does it have a reset button or switch.. usually found on the underside of the face plate
May 09, 2008 | Eclipse CD2000 CD Player
Eclipse 54400
Feb 21, 2008 | Eclipse 5440
Car Audio & Video Logo
65 people viewed this question
Top Eclipse Car Audio & Video Experts
xxxxxx xxx
Are you an Eclipse Car Audio and Video Expert? Answer questions, earn points and help others
