Hello we have missed place the manual of our grundig GU37FHD1080 LCD TVand when my husband connect the tv to the dvd each time we turn down the volume on the tv it automatically goes on to the dvd channel. I would also like to know how to get a new manual.
    Brigadier General:
  • 8,909 Answers
If you were to log on to the manufacturer's web site, I think you will be pleasantly surprised as usually one is able to download, by model number, Customer Instruction Manuals, list of Dealers for spare part supplies and Driver downloads as required.
Just Google the manufacturer's name and follow the links. Make certain you are directed to the manufacturer's web site as some search engines direct you to other sites and they charge for the information that is normally free of charge.
I hope this helps.
Posted on Dec 31, 2010
Tip
Samsung manual(PDF)
Hello
This is a great tip explaining where you will be able to download a vast range of Samsung manuals in PDF format free of charge. Click HERE to navigate to website.
This catalog will include:
  • TV
  • Monitor
  • LCD TV
  • Printer
  • Digital camera
  • Laptop
  • Plasma TV
And this is just to name a few.
Feel free o have a look at Samsung's official website.
I really hope that you can find this helpful. Please rate accordingly.
Kind regards
Andrea
on Mar 02, 2010 | Computers & Internet
Grundig lcd tv has vertical purple lines that fade after a few minutes
Sounds like a panel fault. If you wish to get some details; check the site linked here. Viewing it in "Mosaic" will make surf easy. Surf the site with patience. Pull up older posts. Surf the site with patience.
Apr 07, 2014 | Grundig Televison & Video
Grundig gu37fhd1080
Hi Bill
It sounds like a fault with its main system control memory IC. Please contact any service technician, to confirm it. In most cases, this component might need replacement. Gopakumar Gopalan Google
Mar 07, 2014 | Televison & Video
The DVD player in my set keeps ejecting the DVD mid-play.
Hi well look a DVD is a DVD is a DVD, all you need to do is obtain another one, and I would suspect that it will simply be a standard unit? ALL SATA and IDE are all the same effectively. So what you can do is obtain the correct "Format" of the DVD either SATA or IDE, I suspect it will be SATA, and simply try it, it will do NO harm, and at worst simply wouldn't work The best place to obtain this part will/would be Grundig itself. To get the actual parts number, obtain a service manual, this will show you how to repair the unit as well as this it has ALL parts numbers etc too. Accordingly I provide a download link below for you. Also most likely you would be able to obtain one from your local computer shop too, as said they are all the same...You just need a High Density DVD re-writer just get the one in the service manual, or search the 'net using that data to get one similar etc.
http://www.eserviceinfo.com/equipment_mfg/Grundig_2.html
Make contact with Grundig support and they will help you. link below.
http://www.grundig.co.uk/
A SATA drive has only a small data cable/socket and the IDE has a very wide data cable/socket.
below is a place to obtain spare parts ie: The DVD. remember any DVD that will fit and is same standard will work. Use the service manual.
http://www.partmaster.co.uk/cgi-bin/shop.pl?shop=grundig
Oct 19, 2011 | Grundig GU19WDVDPCX 19 in. LCD TV
Can't find sky remote code for grundig gu37fhd1080
Hello
Sky remote codes for Grundig are:
563 582 515 098 584 219 104 233 223 065 471
Sky+ Remote Control Unit Programming Procedure Follow the steps below
1. Select any channel on the TV.
2. Point your Sky+ remote control away from the TV and press the tv button.
3. Press and hold down the Select and red buttons simultaneously on the Sky+ remote control until the red light at the top of the Sky+ remote control flashes twice.
4. Input the 3 digit number from the Sky+ remote control codes then press the Select button. The red light at the top of the Sky+ remote control should flash twice.
5. Point the Sky+ remote control at the TV and try the volume button.
If this works try the other TV functions.
If these work then the correct code has been selected.
It's important to note that not all TV functions will be supported by the Sky+ remote control e.g. Picture in Picture.
If all functions do not work correctly, then repeat steps 1 - 3 and work through all the relevant 3 digit numbers from the Sky+ remote control codes, until you find the code which supports all or as many of the TV functions as possible.
Please note: In order to operate both your TV and Sky+ with your Sky+ remote control, you will be required to switch modes e.g. to switch on your TV from stand-by, you would need to press "TV" followed by the "Stand-by" button. Then to change channel on your Sky+ you would need to press the "Sky" button followed by the "TV guide" button.
Aug 20, 2011 | Televison & Video
I have a Grundig GU22DVD TV/DVD combo and the remote has stopped working even with new batteries. We,ve just moved it to a new house and need to tune in the digital channels without the remote. Is this...
Take out the battery an hour,put in back in,have the same problems.The remote is dead.Try website like Remotes.com to buy an exact remote.Yes,u can use the manual control buttons on right side of the tv,but a little hard.
Sep 06, 2010 | Grundig GU19WDT 19 in. LCD TV
Grundig GU22 DVDP LCD TV. No image on screen.
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Nov 17, 2009 | Grundig GU22DVDPX 22 in. LCD TV
Televison & Video Logo
199 people viewed this question
Top Televison & Video Experts
Electro Med Services...
