Runtime errors keep comming up on certain programs on startup, if i disable them it is okay but than it seems to happen with some other programs that end up back in startup
    Champion:
  • 214 Answers
Hi, try restore to a date when your system was working ok
Posted on Jul 08, 2008
My desktop (windows XP) is telling me almost every startup that its using too much virtual memory. Why is this happening and can I stop it? Also i'm getting the message " a script seems to be running...
Most likely cause would be a rogue startup program that starts an instance of Internet Explorer (or some other browser). If you can get to the desktop then use a utility called autoruns from Microsoft (http://technet.microsoft.com/en-us/sysinternals/bb963902.aspx) and disable any suspicious looking startup programs.
Jan 06, 2014 | Computers & Internet
Upon starting my laptop, an error pops up prior to my desktop's icons stating that (Pardon the incorrect formatting) C://documents Cannot be found Then I hit okay and it loads everything fine. Then
Try disabling startup programs. Go to Start > Run (search in Win 7) and type MSConfig. In Startup tab, uncheck anything that you don't want Windows to load automatically. It will make Windows boot faster and use less resources while running. This just disables them in startup. Programs will still load, but when only you initiate.
Nov 02, 2012 | Computers & Internet
IMF.exe missing component rtl120.bpl how to restore it?
error is a common system error which tells you that rtl120.bpl file is missing or corrupted when you try to open certain files, applications or just start up the computer. Usually rtl120.bplerror happens when there is a conflict in the path of the Dynamic Link Library or when there is some missing/ corrupted entries in Windows registry. rtl120.bpl error may cause the related programs stop functioning and accesses areas of your system memory incorrectly.
Method 1. Fix rtl120.bpl error Manually by Going Tweaking The Registry Keys.
  • a. Click "Start" menu--"Run"--type in "regedit".
  • b. Delete these registry keys as below manually:
    HKEY_CURRENT_USERSoftwareMicrosoftWindowsCurrentVersionRun
    HKEY_LOCAL_MACHINESOFTWAREMicrosoftWindowsCurrentVersionRun
list.jpgMethod 2. Fix rtl120.bpl error by Disabling Related Programs from Startup.
The DLL file would be infected by virus or Trojan. If the anti-virus program on your computer detects and deletes the infected file, you would probably receive error message alarming you that the DLL file cannot be found. You absolutely will fail to run the relevant application or program but keep receiving DLL error message on the startup. In such situation, you have to re-download and install the application to re-register the DLL information. Accordingly you have to disable an application run automatically on system startup in order to avoid such DLL error message:
  • a. Click "Start" menu--"Run"--type in "msconfig"---Start--- select the certain item to disable.
  • b. Reboot your computer.
Mar 21, 2012 | Toshiba Satellite L35-S2194...
Runtime Error! Program: C:/Program Files/Sony/VAIO Gate/VAIO Gate.exe This application has requested the runtime to terminate it in an unusual way. Please contact the applications support team for...
Hi,If you want to fix the problem you can try to reinstall the application. If you just want to disable the message you can try this:
1. Go to Start Up \ Run command and type: msconfig then press Enter. 2. Go to Windows StartUp and search the item with this string: "C:/Program Files/Sony/VAIO Gate/VAIO Gate.exe" and remove the check. Then Apply and Close.
Mar 21, 2011 | Computers & Internet
I keep getting a message in a grey box as below. Any help would be appreciated. Microsoft Visual C++ Runtime Library Runtime error Program:C\PROGRAM FILES\MICROSOFT OFFICE\OFFICE10\WINWORD.EXE
I'm assuming this error is occuring when you open Microsoft Word. I'll continue under that assumption.
I suggest that you perform both of these fixes:
FIX #1
  1. Click Start, and then click Run.
  2. Type "regedit" and click OK.
  3. The Registry Editor will pop up. BE VERY CAREFUL WHILE USING THIS EDITOR. Do not delete anything unless you are sure you are deleting the correct folder or key.
  4. On the left sidebar, expand this path: HKEY_LOCAL MACHINE > SOFTWARE > Microsoft > Office > (May have several folders here, only one will have the Word folder in it. Find it.) > Word
  5. You should see the folder 'Add-ins' or 'Add-ons' in the 'Word' folder. Delete the 'Add-ins' or 'Add-ons' folder. DO NOT DELETE THE 'Word' FOLDER.
FIX #2
  1. Click Start, and then click Control Panel.
  2. Double-click 'Add or Remove Programs'.
  3. Click 'Microsoft Works in Word Suite Add-in', and then click 'Change/Remove'.
  4. Click OK to confirm the removal.
  5. Click Close.
  6. Restart your computer.
One or both of these fixes should solve your problem.
Feb 20, 2011 | Microsoft Windows XP Professional
I have a problem with buffering...when it starts buffering it goes for about 5 seconds...it stops then it starts again...but then, I start getting sound but no picture...or when I do get a pic, it just...
i gotta know in which application u r having problem with..??
assuming that u r using win xp pro sp2..& IE 7 as browser..
however, it seems that itz having problem in allocation or the files r too large in size..it also happens to unknown file format or association type..!!..try using mozilla firefox with 'downloadhelper' n 'greasemonkey' plugins..
hv installed: java runtime, flash player, shockwave player, quick time..
increase the virtual memory size: open 'Run'->type "sysdm.cpl"->click on 'Advanced' tab->click open 'Settings' submit button under Performance->click on 'Advanced' tab->here u'll find 'Virtual Memory' settings->click open 'Change' submit button in here->type the 'Initial Size (MB): 1440'; Maximum Size (MB): 2880'..->click 'Set' submit button->press OK->OK->Cancel..->now restart the pc..
hv a licensed and UPDATED antivirus installed (i prefer avg/kaspersky, , without updation a full version antivirus is useless)..
download, install n run microsoft kb890830..http://www.microsoft.com/downloads/details.aspx?FamilyId=AD724AE0-E72D-4F54-9AB3-75B8EB148356&displaylang=en..
download n run Startup Control Panel..http://download.cnet.com/Startup-Control-Panel/3000-2094_4-10039330.html..'removeall the unnecessary startup items from here..(if u can't find what to remove, post me/us in ur comment with all the items listed in each n every tabs herein)..
remove all unnecessary software from add/remove programs..
download, install n run 'Advanced System Care Pro'..http://download.cnet.com/Advanced-SystemCare-Pro/3000-2086_4-10399324.html..
disable the following: a) 'Automatically Restart' right click on my computer->properties->advanced->startup nrecovery->(uncheck on the) Automatically Restart; b) 'Error Reporting' right click on my computer->properties->advanced->error reporting->disable error reporting->(uncheck on the) 'but notify me when critical error occur'..
to hv better supervision try contacting ur system admin/vendor....
Nov 07, 2009 | Office Equipment & Supplies
When I turn my computer on, I get a runtime error.
Clean Boot with Only MoSearch loadTOCNode(2, 'resolution'); The Mosearch.exe (Microsoft Office Search Service) and Mosdmn.exe (Microsoft Office 10 Search Filter Daemon) Startup items may be conflicting with some other program (or programs) running in the background. Therefore, clean boot your computer with only MoSearch selected on the Startup menu to determine whether this program is the source of the conflict. To do this, follow these steps:
  2. In the Open box, type msconfig.exe, and then click OK.
  3. On the General tab, click Selective startup.
  4. On the Startup tab, click to clear all check boxes except for MoSearch.
    NOTE: In Microsoft Windows Millennium Edition (Me), leave the *StateMgr check box selected as well.
  5. Click OK, and then click Yes when you are prompted to restart the computer.
  6. If the error message can be reproduced, repeat the preceding steps. In step 3, also click to clear the Process System.ini file and Process Win.ini file check boxes.
If the error message cannot be reproduced, this indicates that MoSearch is conflicting with some other program or programs running in the background. Follow these steps to locate the conflicting program:
  3. On the Startup tab, click to select one of the check boxes.
  4. Click OK, and then click Yes when you are prompted to restart the computer.
  5. If the preceding steps reproduce the error message, the last item added to the Startup menu is causing the conflict. If the error message is not reproduced, repeat these steps until all Startup menu check boxes are selected.
  6. If all the Startup menu check boxes are selected and the error message is still not reproduced, start Msconfig again, and then click to select the Process System.ini file and Process Win.ini file check boxes.
If this doesn't fix it, let me know and I'll post another, more advanced repair.
Good luck, and please let me know how you do.
~ Spoem
Mar 24, 2009 | HP Computers & Internet
Microsoft Visual C++ runtime error
good
u click on start button on yr taskbar , click on run then type (msconfig) that is start>>run>>msconfig then click on ok. a window will come out then click on the startup option at the top then click on disable all which u see below then click on ok to restart ur system n ur don.
May 26, 2008 | Intel PENTIUM-4 865GV CHIP MOTHER BOARD...
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
