My MILNOR washer extractor MODEL # 30015T5E is taking too long to finish its washing cycle. I need possible fauls as well as electrical circuit or schematic for the same. pls help. it urgent.
  • 1462 Answers
SOURCE: wont finish washing cycle
suspect not draining. if not then problem could be the filter. at back, remove the small panel at the bottom. you will see a hose from the bottom of the tub to the pump. remove this hose at the tub end and the filter is inside.be carefull, if machine has not drained, a lot of water will come out. disconnect from mains of course
Posted on Jun 13, 2007
SOURCE: GE ADORA model WHDVH626FWW
you have to clean out the filter on the bottom by removing the lower panel and twisting the cap... careful lots of water comes out but will work great after
Posted on Dec 13, 2007
  • 3 Answers
SOURCE: maytag washer model #LAT9205AAE
Could either be the settlement issue, or it could be a clogged control valve. Turns out that this washing machine is very sensitive to certain kinds of soaps and if you use a detergent that is too dense or use too much, over time, your valve will become clogged and need replacement.
By the way, on the lawsuit, Maytag takes a firm stance on any new claims as they did specify an expiry date to take claims. I escalated to senior management at Westinghouse and did get an evaluation done by one of their partners. The problem was not related to the lawsuit issue. The only problem was that the repair company they had sent, didn't call back to re-schedule so I gave my business to someone else.
Posted on Dec 18, 2007
fixitallguy
  • 11 Answers
SOURCE: I have a model LSQ9659LW1 top load washer
the belt is broken or slipped off motor .
Posted on Dec 22, 2007
  • 27 Answers
SOURCE: HOTPOINT ULTIMA WF860
H2O means the applionce isnt getting enugh water but it sounds to me like youre waste hose is to far down your stand pipe it should be in no more than 4 inches and also make sure you are connected to the cold feed not the hot
Posted on Feb 22, 2008
Kleensmaid heavy duty washer by speed queen, washes but shuts down on what seems to be overspeed on the spin cycle
Amazon.com: Customer Reviews: Speed Queen 3.3 Cu. Ft ...
www.amazon.com/Speed-Queen...Washer/.../B004ZO...
Amazon.com, Inc.Find helpful customer reviews and review ratings for Speed Queen 3.3 Cu. ... If you need more water in the tub you can hold down the reset switch until the machine ... I tried the delicate wash and spin cycle, but the clothes retain too much water and ..... It takes time to correlate the number of turns and the direction to turn it.Missing: overspeed
Commercial Washer and Dryer Problems
www.affordablelaundry.com/commercial-washer-and-dryer-problems
The water should shut off once it reaches wash level, if it doesn't, and water level hasn't... (these are the glass type fuses) be sure to turn power off before checking them. ... If you have the voltage in, but not out, it's the contactor. .... We repair: Speed Queenwasher, IPSO washer, Milnor washer, UniMac washing machines.Missing: overspeed
[PDF]View document in PDF
Dec 19, 2015 | Speed Queen Washing Machines
I have a aeg washer/dryer- it washes fine but then I have problems drying Any idea how I can solve this? problem
Please start with your clothes after the washer finishes it's washing cycle.
Take them out and see how dry they are.
They should be nearly dry.
If not, perhaps the reason you are having problems is they are too wet to begin with for the dryer to properly do it's job..
This is not a rare problem.
One possible reason for the clothes not to be dry when the washer finishes is a loose or worn out belt under the washer.
Another problem some washers have, particularly washer/dryer combos, is that they are sometimes not very effective.
In that case, either smaller loads or rerunning the spin cycle at the end of the washing cycle might help you.
God bless your efforts.
Nov 30, 2015 | AEG Washing Machines
Why doesn't my washing machine complete the spin cycle?
Good Afternoon Friend,
I understand that your Frigidaire washer, model# ATF7000EG0, is not finishing the spin cycle. I suggest resetting your appliance, by either unplugging it or shutting the power off at your home's circuit breaker, for 3-5 minutes. Restore power and start your washer on any cycle. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your washer status has changed successfully. Hope this is helpful.
-Best Regards-
WP
May 30, 2014 | Frigidaire Washing Machines
Wash machine quits mid cycle
Your Circuit Control Board is starting to Fail.... The Electrical Reset is the give away....
Mar 03, 2014 | Whirlpool Duet GHW9150P Front Load Washer
My kitchenAid clothes washer won't always agitate but the timer will finish the cycle
Possible that the timer is not switching the circuit to the designed cycles and so it does not go to the spin mode. It can be due to loss in mechanical contact due to worn out points or dirt accumulation. Use a cleaner, WD40 , could be good to try on the timer before you can estimate the cost of a timer.
Jan 20, 2013 | Washing Machines
Bosch Nexxt 100 series front load washer will not spin. The machine will go through the entire wash cycle from wash-rinse-spin-finish but does not spin. I tried a separate spin cycle and nothing happens....
Just going on these symptoms, you may need a new control/timer.
Inside the control /timer are electrical contacts, and when your machine gets to that part of the cycle, the contacts are not closing to allow the cycle to complete.
If you have circuit board, you will perhaps need a new one of those.
If you do not, probably a control/timer assembly.
If you type "SeasPartsDIrect" into you computer's search engine, and then type your complete model number into the blank when you are asked for it, you may look at the schematic and see whether you have a control / timer or a circuit board.
Oct 08, 2017 | Bosch Nexxt 100 Series WFMC1001UC Front...
Washer won't start cycle after door is closed
Try taking the top of the machine off and checking all of the electrical connections, including the one to the door lock. I have to do this about once a month with my machine and it seems to work.
Jan 20, 2009 | Whirlpool Duet GHW9150P Front Load Washer
Won't turn back on and finish cycle
Press "end of cycle" for over 3 seconds, & wait for 2 minutes to open door. You can then re-start the wash. It is possible you cld hv damaged fhe door switch. For front loaders you do not open the door during a wash, never. Less problems.
Mar 30, 2008 | GE Energy Star WCVH6260F Front Load Washer
Kenmore Washer won't agitate, spin or drain
It's not your exact model but does have some good information about the possible causes.
http://www.shopyourway.com/questions/1099421
Apr 07, 2017 | Washing Machines
Washing Machines Logo
412 people viewed this question
Top Washing Machines Experts
