Question about Sony VAIO VGN-SZ330P/B Notebook
The only way i can use my laptop is by using the ac/power .. the battery icon is saying 0% and it wont change
  • Sony Master
  • 32,281 Answers
Ifthe laptop battery is more than 3 - 4 years old then the battery could be wornout. Rechargeable batteries have a finite number of charge and discharge cyclesand will lose their charge capacity over time, i.e. won't charge to 100% andgradually the charge reduces until the battery won't charge up atall. ORThe battery shows a 100% charge but when the adapter is disconnected thebattery drops off to zero capacity in a very short time. Ifthe battery drops to an unacceptable charge level then the battery needs to bereplaced.
Posted on Dec 31, 2010
Ac wont charge laptop icon says plugged in but not charging? Got new Ac adapter
Battery dead? Is the cord/charger same power spec DC volts and milliamps?
Dec 24, 2012 | Computers & Internet
Tip
AC Adapter issues Q & A.
<p><b>Laptop switching to battery while connected to AC adapter</b><br /> <p><b>Q.</b> While turned on, the laptop will switch to battery power even if connected with the AC adaptor (sometimes during boot-up, or after a while) until the battery drains out, he then goes to hibernation (the battery light is off). If no battery in the laptop, it will shut down, and the AC light will blink very fast. The battery (li-ion) will only charge up to 10%, where it then jumps right up to 100%, and will discharge from 100% to 90% then jump to 0%, go to hibernation, and fails to complete the process, shutting down. The adaptor makes a small "camera flash charging" sound, stabilizing at 19v. When charging, it repeatedly makes the "charging sound" Faulty AC adaptor? Or Faulty battery? Or Both?<br /> <p><b>A. </b>First problem: The laptop switches to battery power even with connected AC adapter. Most likely you have a faulty power jack. It's either broken or loose. It's a known issue with laptops and you can fix it by replacing/resoldering the power jack or relocating it outside laptop case.<br /> <p>It also could be a problem with the power cord. Find a multimeter and check the AC adapter. See if the power cuts off when you jiggle the power cord. If it does, replace the adapter.<br /> <p>Second problem: The battery will discharge from 100% to 90% and then jump to 0%. It sounds like a bad battery.<br /> <p><b>Battery charging light is on even when power adapter is unplugged and laptop is stitched off</b><br /> <p><b>Q.</b>The yellow light for battery charging does not go even after switching the laptop off and power jack is disconnected. Battery does not charge at all with power source connected. <br /> <p><b>A.</b> First of all, try reconnection the battery if you haven't done it already.<br />The battery plugs directly into the connector attached to the motherboard. If the battery charging light stay on even when the power adapter is unplugged and the laptop is switched off, it's either bad battery or something is wrong with the motherboard. The only way to find the culprit is testing the laptop with another known good battery.<br /> <p>Also, you can try this. Remove the battery and plug in the power adapter. If the battery charging LED lights up even when the battery is removed, most likely you have a problem with the motherboard.<br /> <p><b>Battery charges only when the laptop is off</b><br /> <p><b>Q.</b> Bought a Laptop without AC Adapter. I noticed it would charge the battery OK when the laptop was off but once in windows it would not charge the battery.<br /> <p><b>A.</b> This is very important to choose the right AC adapter for your laptop. The output voltage MUST be exactly the same. If your laptop requires 18.5V you must use 18.5V adapter. The amperage should be the same or higher. If the laptop requires 4.74A adapter, you'll have to find an adapter which provides 4.74A or MORE. <br /> <p><b>While using AC adapter alone or battery alone, laptop works. While using them together, I am getting a problem.</b><br /> <p><b>Q.</b> While using AC adapter alone or battery alone, laptop works. However while using them together, laptop LED lights blinks and the power meter for battery drops down immediately to 0% critical level, whereas the battery LED indicator says it's full. I tried to unplug the AC adaptor while it went down to 0%, then the power meter for the battery came back to normal 85%.<br /> <p><b>A.</b> There could be a few different reasons why it happens:<br />1. It might be an issue with the BIOS. Make sure the laptop has the latest version of BIOS installed, update it if needed.<br />2. It might be a software related issue. If you have some kind of power management utility installed try uninstalling it and use Windows power management utility instead. Also I would try reinstalling the operating system if upgrading the BIOS or removing the power management utility does not help.<br />3. If you still experience the same problem even after upgrading the BIOS and reinstalling Windows, most likely you have a problem with the motherboard. Apparently the charging circuit is not working properly. I assume it's not a problem with the battery. You'll have to check the motherboard in this case. <br /> <p><b>Problem with my battery. 100% to about 40% the battery discharging normally then suddenly from 40% it drop directly to 2%.</b><br /> <p><b>Q.</b> When I use only on battery, from 100% to about 40% the battery discharging normally (last about 1 hour) then suddenly from 40% it drop directly to 2%.<br />When I plug the AC cord, it won't directly charge (the charge LED is still not on). After 10 to 20 minutes it then starts to charge the battery (the indicator say that it can be charged to 100%).<br />If I turn-off the laptop and then charge the battery, it won't also directly charge but the delay is much shorter (maybe just about 1-2 minutes).<br />Is this the sign of a bad battery (when hot it can't be charged?) or maybe a bad AC adapter (not enough power to charge the battery when the laptop is turned on?)<br />Note that this symptom is always repeating when I use the laptop.<br /> <p><b>A.</b> From the first part of your complaint description I can see that you have a bad battery. The percentage might vary, but the process of discharging is the same - the battery discharges fine until some point and then the remaining charge suddenly drops to the minimum. You'll have to replace the battery.<br />I'm not sure about the second part. Probably it's a battery related problem too. Just in case check if there is a newer version of BIOS available for your laptop. If you find one, upgrade the BIOS. <br /> <p><b>The battery is 100% charged but it will die within a few minutes as soon as the laptop is unplugged.</b><br /> <p><b>Q.</b> When I unplug the power it will run off the battery, the battery icon says it is 100% charged and I have 2+ hrs remaining, but within a few minutes I get the "critical battery level" message and it will die. When I plug it back into AC power the battery charge light comes on (and will remain on for over a hour), but I will have the same problem with it dying as soon as it is unplugged. Do I need a new battery?<br /> <p><b>A.</b> It looks like you have a bad battery. Here are some behaviors typical for a dying laptop battery:<br />1. The battery charges normally (according to the battery icon) but as soon as you unplug the laptop, it dies almost momentarily.<br />2. The battery charges normally. When you unplug the laptop, it discharges normally until some point and after that point starts discharging very fast. For example it might take 10-15 minutes to discharge from 100% to 80% and then it discharges from 80% to 0 for 2-3 minutes. <br />
on Mar 15, 2011 | Computers & Internet
Tip
on Jan 17, 2011 | Computers & Internet
I have an nv5468u with Part Number LXWDG02030. My laptop wont charge the battery, I can still turn it on using the ac adapter but it wont charge the battery, the battery light indicator just alternates...
Hi there. Your problem seems to be the battery. Usually when the battery is at the end of its life the indicator stays at 0%. If you are still unsure you can go to download.com and get free battery testing software. Good luck...
Mar 30, 2011 | Gateway NV5468u Notebook
My HP dv4030us is about six years old. I use it, primarily as a desk top, so it is always plugged in to AC. I perodically used the battery, but after 6 years, it would not hold a charge. I bought a...
I had a similar problem with my Acer Aspire after I got a replacement battery about 6 months ago.
I was told to disconnect the laptop, turn it off, disconnect the battery, then press the power button for 30 seconds to reset the charging circuit.
I did this, but it didn't work any better. I thought that since my charger seems to run the computer, but it says 0% Available (plugged in, charging) that there was something wrong with the battery.
So, I contacted the manufacturer of the battery and they said they would refund my money within 7 days after receipt, and they gave me an RMA number for the return on the address label.
I, also, got the battery from Ebay.
Since your problem is that the battery icon with a red X over it says 0%, I would say that maybe the battery is bad, or maybe the battery is not connected very well at the contacts. Maybe blow the contacts off with compressed air in order to clean any dust which may be on it.
I would maybe try another battery to try to see if the charging circuit is bad on the laptop.
If another battery doesn't work, then the charging circuit between the laptop and the battery may be faulty.
Good luck on this repair.
Jan 12, 2011 | HP Pavilion dv4000 Notebook
Tip
Q. While turned on, the laptop will switch to battery power even if connected with the AC adaptor (sometimes during boot-up, or after a while) until the battery drains out, he then goes to hibernation (the battery light is off). If no battery in the laptop, it will shut down, and the AC light will blink very fast. The battery (li-ion) will only charge up to 10%, where it then jumps right up to 100%, and will discharge from 100% to 90% then jump to 0%, go to hibernation, and fails to complete the process, shutting down. The adaptor makes a small “camera flash charging” sound, stabilizing at 19v. When charging, it repeatedly makes the “charging sound” Faulty AC adaptor? Or Faulty battery? Or Both?
A. First problem: The laptop switches to battery power even with connected AC adapter. Most likely you have a faulty power jack. It’s either broken or loose. It’s a known issue with laptops and you can fix it by replacing/resoldering the power jack or relocating it outside laptop case.
Q.The yellow light for battery charging does not go even after switching the laptop off and power jack is disconnected. Battery does not charge at all with power source connected.
A. First of all, try reconnection the battery if you haven’t done it already.
The battery plugs directly into the connector attached to the motherboard. If the battery charging light stay on even when the power adapter is unplugged and the laptop is switched off, it’s either bad battery or something is wrong with the motherboard. The only way to find the culprit is testing the laptop with another known good battery.
Q. Bought a Laptop without AC Adapter. I noticed it would charge the battery OK when the laptop was off but once in windows it would not charge the battery.
A. This is very important to choose the right AC adapter for your laptop. The output voltage MUST be exactly the same. If your laptop requires 18.5V you must use 18.5V adapter. The amperage should be the same or higher. If the laptop requires 4.74A adapter, you’ll have to find an adapter which provides 4.74A or MORE.
Q. While using AC adapter alone or battery alone, laptop works. However while using them together, laptop LED lights blinks and the power meter for battery drops down immediately to 0% critical level, whereas the battery LED indicator says it’s full. I tried to unplug the AC adaptor while it went down to 0%, then the power meter for the battery came back to normal 85%.
A. There could be a few different reasons why it happens:
3. If you still experience the same problem even after upgrading the BIOS and reinstalling Windows, most likely you have a problem with the motherboard. Apparently the charging circuit is not working properly. I assume it’s not a problem with the battery. You’ll have to check the motherboard in this case.
Q. When I use only on battery, from 100% to about 40% the battery discharging normally (last about 1 hour) then suddenly from 40% it drop directly to 2%.
When I plug the AC cord, it won’t directly charge (the charge LED is still not on). After 10 to 20 minutes it then starts to charge the battery (the indicator say that it can be charged to 100%).
If I turn-off the laptop and then charge the battery, it won’t also directly charge but the delay is much shorter (maybe just about 1-2 minutes).
Is this the sign of a bad battery (when hot it can’t be charged?) or maybe a bad AC adapter (not enough power to charge the battery when the laptop is turned on?)
A. From the first part of your complaint description I can see that you have a bad battery. The percentage might vary, but the process of discharging is the same – the battery discharges fine until some point and then the remaining charge suddenly drops to the minimum. You’ll have to replace the battery.
I’m not sure about the second part. Probably it’s a battery related problem too. Just in case check if there is a newer version of BIOS available for your laptop. If you find one, upgrade the BIOS.
Q. When I unplug the power it will run off the battery, the battery icon says it is 100% charged and I have 2+ hrs remaining, but within a few minutes I get the “critical battery level” message and it will die. When I plug it back into AC power the battery charge light comes on (and will remain on for over a hour), but I will have the same problem with it dying as soon as it is unplugged. Do I need a new battery?
A. It looks like you have a bad battery. Here are some behaviors typical for a dying laptop battery:
on Jun 12, 2010 | Computers & Internet
Have a compaq presario running win 7. The system does not recognize when it is running on ac power (original ac adapter). The battery charges but the only sign of this is the battery icon says xx%...
Hi, it seem as if your battery is faulty you should try another battery to see if the computer will recognize when it is charging, you can also try your battery in another compaq presario computer to see if it will have the same problem.
Aug 02, 2010 | Computers & Internet
Dell 9400 wont show AC power icon
If the computer is connected to an electrical outlet, the about10.jpg light operates as follows:
  • Solid green: The battery is charging.
  • Flashing green: The battery is almost fully charged.
If the computer is running on a battery, the about41.jpg light operates as follows:
  • Off: The battery is adequately charged (or the computer is turned off).
  • Flashing orange: The battery charge is low.
  • Solid orange: The battery charge is critically low.
Looks like the AC adaptor is faulty.
Aug 25, 2009 | Dell Inspiron 9400 Notebook
Bought a new battery and it wont charge, says on AC power
Take the Battery back Its defective , New batteries should charge for 18-24 hours, and the computer should tell u that it wont run till the battery is fully charged.
Jul 22, 2009 | HP Compaq Presario V2000 Notebook
I have a dell 1545 and when it is plugged in the battery icon says "plugged in battery not charging" when i unplug the ac adaptor and plug it back in it says "the ac power adaptor type cannot be...
try to remove the battery first and plug in the ac power adaptor and see if it works. if yes, then your battery is faulty.
if it doesn't work i suspected that there's a problem with the power socket from your machine. you can check it with the nearest service center near you.
Jul 02, 2009 | ASUS F3Jc-AP141C Notebook
Sony VAIO VGN-SZ330P/B Notebook Logo
131 people viewed this question
Top Sony Computers & Internet Experts
Alun Cox
Are you a Sony Computer and Internet Expert? Answer questions, earn points and help others
