My logik tv appears to not have red pixals as the screen is mainly green but the blue still shows up how do i fix it or do i just take it back to the shop??
    Brigadier General:
  • 8,909 Answers
If the connections from DVD Video etc have been checked and it still has red missing, if it is under warranty, don't bother trying to fix it. Take it back for replacement if very new or repair if over 28days old.
Hope that helps.
Posted on Dec 31, 2010
I have an old Dell DE051 tower and I have it hooked up to my TV via VGA cable. When I turn on the tower, the dell loading screen appears and then moves onto the Windows XP loading screen. The problem...
Could be the pixal setting on the tower is too high for the TV? Can you change the video card settings to the TV Pixal rating? You could have a bad video card. Good luck.
May 01, 2014 | Computers & Internet
THE TV WILL NOT POWER UP
It depends on a lot of other things, but you could try these steps . . .(assuming its a TFT flat screen)
Has the mains fuse blown ? try a different mains cable.
If it works from a power supply/mains transformer (a small box attached to the mains supply cable), check that box - they usually have a small green light on them to show they are getting power. These are easily replaced if that part is faulty.
Has the power cable come detached from the rear of the TV ?
Does a power light appear on the actual TV front (usually blue or green), and then go red (or off) after a few seconds. In that case the screen has a more hard to fix problem inside :(
Apr 04, 2010 | Sylvania LD370SS8 37 in. LCD Television
I was just given this t.v because friends couldn't figure out what is wrong with itl. The colors don't line up right,looks kinda blurry depending on the lighting of the program being watched. How do i fix...
According to the manual:
1) go to the "TV Main Menu"
2) Select "Screen"
3) Select Adjust Projection TV (obviously only if a projection TV).
This then allows you to adjust the TV's 3-colors. Selecting GREEN CENTERING brings up a control panel that lets you center the green projection tube on the screen. Selecting RED CONVERGENCE or BLUE CONVERGENCE lets you align the Red & Blue projector tubes. Centre the green projector tube 1st. Then adjust the red & blue until the test pattern on the TV screen appers white.
Good Luck!
Jun 08, 2009 | Proscan PS50700 50" Rear Projection...
Proscan 26LB30Q Vs PS2 = HELP
The red white and yellow cables are composite connections. The red/green/blue connections are component connections.
The playstation's composite connections consist of two audio connections- red & white, and a composite yellow video connection. The TV's white connection is the audio, and the red/green/blue are component video. You need an adapter that will connect the one yellow(composite video) to the three red/green/blue (component video) connections
Feb 28, 2009 | Proscan 26LB30QD 26 in. LCD HDTV
RED TINT
yOUR CRTS ARE SHOWING THE SIGHNS OF WEAR. ON THE FRONT OF THE SET BEHIND THE SPEAKER GRILL OR FRONT FACIAL. THERE ARE 6 CONTROLS 3 FOR SCREEN RED GREEN AND BLUE AND 3 FOR FOCUS RED GREEN AND BLUE. YOU CAN TRY TURNING THE RED SCREEN DRIVE CONTRIL COUNTER CLOCK WISE. JUST A VERY LITTLE BIT.
Jan 22, 2009 | Televison & Video
Harwa tv childlock code
For Harwa (also branded Logik) 54cm colour TV with remote RC-A07 showing blue screen with red lock in the corner, hold down "music" button on remote for 10 seconds to unlock.
Oct 24, 2008 | RCA TruFlat 27F520T 27" TV
Sharp Aquos LC-32D41U
The unit has bad drive ic's,which is part of the lcd panel.It is not cheap to fix.
Feb 28, 2008 | Sharp Aquos LC-42D62U 42 in. LCD HDTV
The picture is only producing the basic colours red green and blue
You can start with the make, model and age off the back of
the TV..........................T.
Dec 24, 2007 | Televison & Video
Red & green lamps shutting off leaving a blue screen
Could you show a picture of the distended cover you mentioned?
Were the light blue lines you were referring to, diagonal, or truly horizontal?
Oct 15, 2007 | Sony KP-57WS500 57" Rear Projection...
My tv is picture is blue and green
Hi there my t.v has a similar problem, I turned it on and the colours arn't right, there the colours go out in three circles mainly mainly blue, green, red yellow, but depends whats showing on the t.v? Please help.
Apr 17, 2007 | Bush 5693D 24" TV
Televison & Video Logo
71 people viewed this question
Top Televison & Video Experts
Electro Med Services...
