Question about JVC RX-7000V Receiver
I am using a JVC RX6000 video audio receiver, and i hooked 5.1 BMB brand home surround speakers to it, and connected my ASUS media player that has optical output and used optical cable to connect to the back of the JVC RX6000... as i play different movies, the JVC doesn't recognize any sound... either Dolby Digital, or DTS... so i have no idea why... any ways of solving this? thanks
  • Anonymous Jan 03, 2011
    Hi Mark, thanks again for response, but how do I set the rear speakers to Flat mode (no extra base or treble)? I also notice that there would be no crackles or pops in the rear speakers if I choose analog mode, instead of digital DTS, but I am always afraid of hearing the cracking or popping sound when testing them, because they are pretty loud and sudden.
    Thanks for the link to the manual too... I will try to adjust the bass/treble sounds to the minimum, but it says i can reduce or increase between -10 to 10... what does that mean? Which one would be smallest and which would be largest? Thanks again Mark!!
  • JVC Master
  • 6,694 Answers
check the digital output setting of ur media player. it should be in the format raw not pcm. also check the audio format of ur movies in the media player. is it dolby digital ,dts or mp3. if u have down loded the videos it will be in mp3 format unless u have selected the dts downloads. if it is in mp3 or any other formate ur receiver will not support. if u press the surround button on ur remote u can select artificial surround effect for the mp3 audio.
ok
Posted on Dec 31, 2010
Testimonial: "Thanks Ajin!! It was also useful info, and helped me along with Mark's info to get DTS output!!"
  • 312 Answers
This is a common problem. Each input will default to analog. Even though you have plugged an optical cable into the inputs of the Receiver, you have to change that input to digital.
For example, if you connect a CD player RCA cables to the Receiver. The receiver will recognize the Analog signal at the CD input. If you unplug the Analog RCA Cables and plug in the Digital optical, the receiver will still be at it's normal default input for the CD player which is Analog. You then have to switch the input, using either the remote or it may be able to be done with the buttons on the front.
As soon as it is changed to Digital, you will get nice sound.
Hope this helps,
Happy New Year,
Mark
Testimonial: "Thank you very much Mark!! It did solve my problem and now I am enjoying DTS surround sound!! Happy New Year and best wishes to you!! cheers!!"
  • 3 more comments
  • Anonymous Jan 02, 2011
    Hi Mark!! Thank you very much for the help!! Now I can get to enjoy DTS surround sound, but there is a worry! I have speakers that are same size and power to front and rear speakers, and the JVC accidentally selected front and centre to be "large", while the rear speakers were "small". Not sure if that affected my rear speakers, but when I try to play Toy Story 2 at the beginning, I hear loud crackles and pops from my rear speakers whenever there is something happening on screen... is there damage to the speakers? I set them all speakers to "small", just in case... or what should i do? thanks again Mark!!
  • Mark Freedman
    Mark Freedman Jan 02, 2011
    Hi Alex,
    I located the manual for your unit and it has some a good instruction section starting on page 12 on setting up the correct size for the speakers, front, center and rear. Also I would have the rear speakers set for Flat sound. i.e. no extra bass or treble. At least just for starters.
    Also check to make sure of the following:
    That each speaker is the right speaker. I know it may sound silly, but if you connect, for example the center channel output to any of the rear speakers you could end up over driving them. You will need to change the default speaker sizes as well.
    Here is a link to the Manual so that you can download it.
    Hope this helps, Let me know. Best Regards, Markhttp://www.retrevo.com/support/JVC-RX-60...
  • Mark Freedman
    Hi Alex, I located the manual for your unit and it has some a good instruction section starting on page 12 on setting up the correct size for the speakers, front, center and rear. Also I would have the rear speakers set for Flat sound. i.e. no extra bass or treble. At least just for starters. Also check to make sure of the following: That each speaker is the right speaker. I know it may sound silly, but if you connect, for example the center channel output to any of the rear speakers you could end up over driving them. You will need to change the default speaker sizes as well. Here is a link to the Manual so that you can download it. Hope this helps, Let me know. Best Regards, Markhttp://www.retrevo.com/support/JVC-RX-60...
  • Anonymous Jan 04, 2011
    Because my rear speakers are popping and crackling during DTS output, I believe my settings of bass or treble might be overloading my speakers... should I set the rear speakers to "flat"? should I do that to all my speakers? will they still be discrete channels for DTS? What levels should I put for bass and treble if I were to put as "flat"? should i also turn off bassboost? I am kind of scared to hear those cracks and pops because they are loud, despite my volume to be either high or super low!!
    So far, it is only happening to the rear speakers, and it only happens during DTS/Dolby selection even at very low volumes, even with only at volume level 1 or 2... it doesn't happen with analog surround sound... so far i did set to all my speakers as "SMALL", and the wires weren't changed at all... before I used a pioneer that supports AC3 Dolby only, but not DTS... i am pretty sure the pops and cracks are not from the movie, since I also tried Hurt Locker and at the beginning, when there was explosion, i heard a pop even at volume level 1, so i turned off the volume right away!! wow, very nervous to even try out the sounds... i am only using an ASUS O-Play media player, and using optical cable to the receiver. When you mean setting everything at flat, does it mean putting the bass/treble all at 0 db? Please let me know... thank you once again!!
  • Mark Freedman
    Mark Freedman Jan 04, 2011
    Hi Alex, It sounds to me like you have digital clipping of your rear inputs. It may be that there is a menu item on the input stage that you can change to that clear this up. There may also be a digital output mode for the DVD player that clears it up. I think I would now look at the DVD output mode menus and try to clear it up with that. Why do I think it is digital overload? Just by how you verbally described it . I really hope this helps. If it does not help, pull the woofer off line and only use it for testing until this is solved. No sacrifices allowed.
    Best,
    Mark
Elite 6035 surround sound. How do I connect?
Need help hooking up my surround sound speakers with receiver ...
www.hometheaterforum.com/.../286294-need-help-hooking-up-my-surr...
Sep 1, 2009 - 4 posts - ‎1 author
Ok I have a brand new set of Genesis G-6.1 surround sound speakers (I got them for $20 brand new in the box so I ... Or do I just connect all the speakers to the receiver like usual? ... Elite Audio EA-608 ... Genesis G-6035 Olin Ross - Beginners, General Questions & HTiB (Home ...
Apr 7, 2009
Info. on Genesis 6.1 Home Theatre system - Beginners ...
1 post
Jul 24, 2008
Can't hear the bass sound... - Receivers/Separates/Amps
May 30, 2008
Davinci audio? - Speakers, Subwoofers & Headphones
Aug 28, 2006
More results from www.hometheaterforum.com
Have any universal codes for EA-6035 5.1 A/V Surround ...
Dec 25, 2015 | Elite Televison & Video
Hi how do I get surround sound coming from my tv
A Samsung home theatre system can make watching movies at home like going to the theater. Proper setup is essential to get the full benefit of the Samsung system, which is available in 5.1 and 7.1 channel surround sound configurations.
Typically the final step in setting up any home theater is connecting your TV to your system.
Like most home theatre systems, your Samsung home theater receiver will allow you to plug all of your components into it, meaning you only have to run a few cables to connect your television to your system.
Make sure your playback devices are properly connected to your receiver.
Whatever playback devices you use, make sure they are plugged into the appropriate inputs on your receiver.
DVD and Blu-ray players, satellite boxes and cable boxes should all be plugged into video inputs, and CD players should be plugged into audio inputs.
Your receiver will have labels on the back panel indicating into which input you should plug your devices.
Connect the video out to your TV's video input. Make sure you use the correct cable to make the connection. For newer receivers, the connection will likely be either HDMI or component.
If your receiver has an HDMI output, use an HDMI cable to connect the receiver to the HDMI input on your TV.
If your receiver uses a component output, use a component cable to connect your receiver to the component input on your TV.
Connect the audio output of your TV to one of the audio inputs on your Samsung receiver if you want to output your television's audio through your home theatre system.
Most recent TVs will either use an optical cable or a digital coaxial cable to connect to the receiver, allowing you 5.1 channel surround from your television.
If you have an older set, you will likely have to use standard RCA cables.
Turn on your receiver and press the "Setup/Menu" button on your receiver's remote.
When "Input" appears on the display, press the right arrow key on your remote to select TV from the list.
After selecting TV, press the up or down arrow keys on your remote to select the audio input jack into which you have plugged your TV's audio cable.
Press the "Exit" button on your remote to exit the setup menu and lock in the settings.
Samsung home theatre system owners guide download
http://downloadcenter.samsung.com/content/UM/200903/20090327091825515/HT-AS730S-XAA.pdfalso
If you're not an electronics junkie, hooking up your surround sound can seem daunting.
There are so many wires and settings that it's understandable why some people might rather pay someone else to do it for them.
But you can do it yourself as long as you make sure the speakers are positioned correctly; the wires are not only plugged in all the way, but plugged into the right places; and the settings on your television and amplifier are set up correctly.
Check to make sure your surround-sound speakers are correctly installed.
Locate the test function on your surround-sound remote control or amplifier panel to do this.
You will know your speakers are hooked up if sound comes out of each speaker during the test.
Make sure your audio cables are hooked up properly.
Make sure the audio cables running from your television to your amplifier are plugged in correctly. The red and white wires should be plugged into the "Audio Out" spot on the back of your television.
Those same red and white audio wires should be plugged into one of the "Audio Input" spaces on the back of your amplifier.
Turn on your television.
Locate the "Menu" button on either your television remote or your television set.
Scroll through your options until you find "Audio Mode" or a similar naming convention.
Select it.
Scroll through your options until you find "Digital Audio Out," or a similar naming convention. Choose it.
Scroll through your options until you find "Dolby Digital Out." Select that option.
Power your surround-sound system on.
Make sure you have the correct audio input selected.
After the correct audio input is selected, make sure you actually have the Dolby Digital aspect of your surround sound system turned on.
The default for most surround-sound systems is the standard two-channel, stereo output.
Set up a home theater
http://www.cnet.com/1991-7386_1-6214422-7.html
Aug 07, 2013 | Samsung Ht-E355 330W 5.1 Channel Home...
Have lenoxx ht 500 surround sound speakers & dvd but dvd is broken, need to purchase another dvd player but can't source lenoxx model, what other models can i connect surround sound to? or whe
If your surround sound receiver unit has rca audio inputs(red/white), you can hook up any brand of DVD player that has rca outputs. You would hook the yellow output from DVD player to yellow input on TV. Hook red/white output from DVD player to red/white input on surround receiver. Hope this helps.
Jan 03, 2012 | Audio Players & Recorders
I have a JVC DVD player that doesnt come with surround sound but i have surround sound speakers is there something I can buy so that I am able to use the speakers
If you have surround speakers with a surround system, then connect the Player to the surround system using for example RCA cables (White and Red).
If you have speakers only, connecting many speakers to a non-surround system won't give you surround.
In surround systems the sound is controlled, elaborated and distributed through the speakers by a circuit.
If you wnt surround sound the alternatives are :
  1. Connecting a surround system (eg.Home theater, receiver) to the player (amp+speakers)
  2. Upgrading the DVD to one with surround.
Let me know if you need more help.
bye.
G.
Jul 17, 2009 | JVC KD-DV7300 Car DVD Player
My surround rear spks dont work
The rear speaker decoding has to be enabled for them to function, regardless of the media. Enter the speaker setup menu and choose "yes" for the rear surround speaker decoding.
Mar 10, 2009 | Sony STR-DA3000ES Receiver
No Sound
Tell me in details how you connect your whole home theater system.Step by Step.Video and audio connection please.
I need to know does it happen only on certain component(ex. dvd player?)
solutiondoct
Oct 21, 2008 | Onkyo TX-SR804 7.1 Channels Receiver
No Prologic Surround Sound
im thinking the reciever is set to get its audio from somehwere other than the dvd, sounds like you did most of the troubleshooting but do you get audio out of the reciever if its just playing the radio or something other than a dvd?
Nov 19, 2007 | JVC RX-778V
JVC RX-7000V Receiver Logo
300 people viewed this question
Top JVC Audio Players & Recorders Experts
 Grubhead
Grubhead
Henry  Thomas
Henry Thomas
Are you a JVC Audio Player and Recorder Expert? Answer questions, earn points and help others
