Question about Indesit Washing Machines
Just new out of the box. Will wash ok but won,t release water, then error code F11 appears with all lights flashing.
  • Anonymous Mar 27, 2014
    ERROR CODE F10 APPEARS ON WASHING MACHINE PANEL
    Top Expert:
  • Indesit Master
  • 9,472 Answers
F11 - No hot fill.The ambient temperature is likely to be below freezing possibly due to the pipes being frozen. Also check that the taps are on or if the drain hoses are kinked.
Posted on Dec 31, 2010
WHAT MEANS ERROR CODE FOR MY DRYER MACHINE F11?
Communications error.
  • Troubleshooting and Repairing the F11 Error Code in a ... www.youtube.com/watch?v=RXH5MWzZJKM
    • BY SAMURAIREPAIRMAN
    • 6 MIN
    • 121K VIEWS
    • ADDED 2013-10-22
    Video embedded · Troubleshooting and Repairing the F11 Error Code in a ... Troubleshooting the F35 Sud Error Code in the Whirlpool Duet Steam ... Washer Dryer ...
  • Kenmore Elite He3 F11 Error Code - WordPress.com https://hydripinri.files.wordpress.com/2015/10/kenmore-elite-he3... · PDF file Kenmore Elite He3 F11 Error Code circuitboardmedics.com/whirlpool-duet-fdl-ccu-repair/ How to troubleshoot the ... Kenmore F1 Error Code He2 Dryer Problems Amp Solutions
  • Kenmore Washing Machine Error Code F11 - WordPress.com https://meofapitri.files.wordpress.com/2015/07/kenmore-washing... · PDF file Kenmore Washing Machine Error Code F11 what does f11 mean - Kenmore Elite HE3 Washing Machine. The F11 code is from a communication break in the serial link from ...
  • Related searches for ERROR CODE DRYER F11
  • Whirlpool Duet F11 Error Repair ' Circuit Board Medics circuitboardmedics.com/whirlpool-f11-code Whirlpool F11 Error. This is a repair service for the Whirlpool Duet F11 error code on a Whirlpool Duet washer.
  • Bosch Tumble Dryer Fault Code F11 - prapmumbmihe https://prapmumbmihe.files.wordpress.com/2015/08/bosch-tumble... · PDF file Bosch Tumble Dryer Fault Code F11 Bosch Exxcel tumble dryer error code F:09 · Bosch Exxcel WVT. Asciugatrice Bosch Wts86511It: Errore F11 Hello, My dryer ...
  • Whirlpool F11 error code - Appliance Repair Forum forum.appliancepartspros.com > ... > Washer Repair
    • LAST UPDATED: 2014-02-18
    • 6 POSTS
    • FIRST POST: 2012-02-18
    I got an F11 error code on the washer and tried some of the things discussed on the Applianceblog.com site for simiilar duet washers and found a link to this site ...
  • Jan 30, 2016 | Dryers
    What could be the cause for a F 28 error code ? Kenmore model #110.47512601
    It may be caused by a power issue. Make sure that the washer is plugged into a grounded plug.
    Jul 10, 2014 | Kenmore HE2 Plus Front Load Washer
    Flashing F 11, drum spins by hand.unplugged for 30 sec and plugged back in started to fill then stopped .flashed F11 again
    The F11 error can be difficult to resolve even for us technician's.
    The F11 error occurs when the central control and motor control don't talk to each other.
    If one of the controls was actually bad then I'd expect to see the error code every cycle. If it does, start by checking all the wiring connections from the panel to the CCU. Post back your results.
    Dec 02, 2012 | Whirlpool Duet GHW9150P Front Load Washer
    Ariston AQXXF 129 Error code F 05 - What is this?
    see this causes and fix it. God bless you
    F05 Water temperature sensor error If during the water heating step in the wash cycle, the water temperature sensor (NTC) value is out of range, or the heating element circuit has failed, the F05 error code will be displayed.
    Potential Causes
    • Check the Water Temperature Sensor, Heating Element and Element Relay
    • Check connections to the Sensor, Heating Element and Relay
    Replace failed component.
    Sep 30, 2012 | Ariston Technologies Washing Machines
    Error code e01
    do the following steps: God bless you
    To start test program, press and hold both POWER SCRUB PLUS and RINSE & HOLD program buttons, then turn unit on by pressing ON/OFF button. When program buttons are released, lights above them will flash. To end test program, press ON/OFF button.To check program indicator lights (POWER SCRUB PLUS, REGULAR WASH and RINSE & HOLD), press and hold each program button. When REGULAR WASH program button is pressed, CLEAN light also comes on.
    To start testing, press both POWER SCRUB PLUS and RINSE & HOLD buttons a second time. When testing has ended and a fault was detected, the following indicator lights will be lit:
    POWER SCRUB PLUS = Heater fault
    REGULAR WASH = Water filling fault (over or under filling)
    RINSE & HOLD = NTC (temperature sensor) fault ? note circulation motor stops shortly after it started during an NTC fault
    To check for heater, high limit or flow switch problems, start testing until heating starts. Using a meter with a current coil, measure current going into dishwasher. If current is ~ 11 A, then heater, high limit and flow switch are OK. If current stays at ~ 1.5-2 A, then heater, high limit or flow switch are faulty.
    If water level switch (f1) has failed (opened), REGULAR WASH light will come on and unit will continually fill and drain where testing won't be completed. If flow switch (e5) has failed (opened), water won't heat (to 150?F) and water won?t stop circulating. If NTC probe (f2/f4) has failed (opened), RINSE & HOLD light will come on immediately and testing will end shortly after water has started circulating.
    If more than one fault occurs, more than one light will be lit.
    Jul 21, 2012 | Dishwashers
    Clean light flashes 7 times on Whirlpool DU1148XTPB3 dishwasher and it won't run.
    The light flashing 7 times indicates error code number 7 and E7 is a error code for the flowmeter. What the flowmeter does is measure the amount of water coming into the dishwasher. The E7 error code can be cleared aby pushing the buttons in this order
    HIGH TEMP WASH-HEATED DRY-HIGH TEMP WASH-HEATED DRY -- OFF/CANCEL
    The error code will be cleared after pushing the buttons in that order...if after running the E7 error code returns the flowmeter would need to be replaced
    The flowmeter is the part on the left side of the tub it is where the water enters the tub
    The part number for it is W10195536
    GENE
    Sep 05, 2011 | Whirlpool 24 in. DU1055XTP Built-in...
    My Hotpoint Aquarius WF430 1300 doesn't complete its cycle, it stops after the wash & doesn't go on to the rinse & final spin. It seems to "freeze" after the wash is finished as the lights remain...
    If your lights are flashing, use these codes to pinpoint the error.
    These codes are reading from the top neon down.
    F01....OFF, OFF, OFF, Flash, OFF.
    F02....OFF, OFF, Flash, OFF, OFF.
    F03....OFF, OFF, Flash, Flash, OFF.
    F04....OFF, Flash, OFF, OFF, OFF.
    F05....OFF, Flash, OFF, Flash, OFF.
    F06....OFF, Flash, Flash, OFF, OFF.
    F07....OFF, Flash, Flash, Flash, OFF.
    F08....Flash, OFF, OFF, OFF, OFF.
    F09....Flash, OFF, OFF, Flash, OFF.
    F10....Flash, OFF, Flash, OFF, OFF.
    F11....Flash, OFF, Flash, Flash, OFF.
    F12....Flash, Flash, OFF, OFF, OFF.
    F13....Flash, Flash, OFF, Flash, OFF.
    F14....Flash, Flash, Flash, OFF, OFF.
    F15....Flash, Flash, Flash, Flash, OFF.
    f16....OFF, OFF, OFF, OFF, Flash.
    F17....OFF, OFF, OFF, Flash, Flash.
    F18....OFF, OFF, ON, OFF, OFF. Fault on control board, check Eeprom.
    these are the codes and this is what they mean
    f01 light 4, motor triac
    f02 light 3 motor, jammed/ tacho
    f03 lights 3&4 Ntc fault
    f04 light 2. pressure sw stuck on empty
    f05 lights 2&4, pressure sw stuck on full
    f06 lights 2&3, N/A?
    f07 lights 2&3&4 heater relay
    f08 light 1. heater relay
    f09 lights 1&4 eprom/setup error
    f10 lights 1&3, pressure switch not sensing
    f11 lights 1&3&4, pump/draining error
    f12 lights 1&2, communication error
    f13 lights 1&2&4, dryer ntc/ fan motor
    f14 lights 1&2&3, dryer heater
    f15 lights 1&2&3&4, dryer heater relay
    f16 N/A
    f17 light 4, door lock
    f18 light 3 comms error (3 phase motor) power board
    also try checking this manual
    http://imagebank.indesitcompany.co.uk/brochures_online/pdf/Hotpoint/Laundry/WFseries_19504110305_Jan05_book.pdf
    Mar 05, 2010 | Washing Machines
    F11 fault code
    Please find the steps that needs to be taken for trouble shooting F11 fault code specially if there was a power cut.
    1, Power off at the machine. Do the next 4 steps within 3 seconds.
    2, Press Temperature Button in.
    3, Power on
    4, Release temperature button
    5, press Soil Type button
    You will now hear the door lock release so you can get to your pants.
    Diagnostic code is now displayed. You can switch the washer off and back on and the error code is clear. If you do this it will work.
    I am sure it would help you to resolve the issue.
    God Bless.
    Jul 09, 2009 | Dyson Flowcheck CRO1 Front Load Washer
    How to repair a F 11 fault on a DYSON CR01 flow check
    To Clear F11 Code after a power cut.
    3, Power on
    Thanks for using Fixya.
    May 28, 2009 | Dyson Flowcheck CRO1 Front Load Washer
    Hotpoint Aqualtis Error code F11
    please could someone help as i have the exact same problem with my aqualtis zqxgf149,exactly as above,fitted new pump myself and its now emptying the water but wont spin and in wash cycle f11 comes back up
    Jun 27, 2008 | Washing Machines
    Washing Machines Logo
    234 people viewed this question
    Top Indesit Washing Machines Experts
    Gerry Harvey
    Gerry Harvey
    Darren Moxam
    Darren Moxam
    shaun taylor
    Are you an Indesit Washing Machine Expert? Answer questions, earn points and help others
