I can not find my user name and password for my Thomson TG585v7
  • 1,719 Answers
There is no way to recover the lost password, although you may reset Thomson TG585 by pressing the reset button located at the back of the modem for few seconds while the modem is power on. The LEDs at the front would blink and the modem will restart with factory defaults setting.
Please note that after RESETTING THE Modem to Factory Defaults, ALL SETTINGS WILL BE LOST AND YOU HAVE TO RECONFIGURE IT. Please, refer the product guide/manual and make configurations as per the details provided by your Internet Service Provider (ISP).
Let me know if any further clarification/ assistance is required.
Good Luck!
Appreciate generously, if the solution could have been of any help!
CreativeTECH
Posted on Dec 31, 2010
Thomson tg585v7
I guess that the router had specs from the zone you buy it.So now you are in other zone and dont had the specs for that zone.
Feb 15, 2014 | Computers & Internet
How can i put a password for my router ? its Thomson TG585 v8
To setup security on the wireless router Thomson TG585 v8 please follow the below steps:
1.Open your web browser.
2 Browse to http://dsldevice.lan or to the IP address of your Thomson Gateway (by default: 192.168.1.254).
3 If you have protected your Thomson Gateway with a user name and password, the Thomson Gateway
will prompt you to enter these. Enter your user name and password and click OK.
4 The Thomson Gateway GUI appears.
5 On the left menu, click Home Network.Under Wireless, click your access point.
Your access point is listed in the following format: "WLAN: ()". For
example, WLAN: Thomson83C7C7 (54Mbps).
6 The Wireless Access Point page appears.In the Navigation bar, click Configure.
7 Under Security, Select Use WPA-PSK Encryption.In the WPA-PSK Encryption Key box, type a the key of your choice. The key must be in one of the following formats:
a. 8 to 63 alphanumeric characters. For example: MyKey123 OR
b. 8 to 64 hexadecimal characters (characters from 0 to 9 and from A to F). For example: C54F48A5.
Click Apply.
8 Configure your wireless client(s) with the same settings.
Please revert back for any more issues that you may face.
Regards
Anand
Apr 27, 2011 | Computers & Internet
I have a Thomson TG585v7 for my computer but i have forgotten the sercurity pass word lock for it, How can i go and change this or even find out what it is????? Thanks
Open INTERNET EXPLORER and. (In the URL address field), enter the IP address for your wireless router ( the DEFAULT GATEWAY. This information should be contained in your router's manual. If you cannot find it, enter "198.168.1.1" as the address. This is usually the default IP address for most routers.do not type "www" just the number
Enter the username and password for your router. This should also be supplied in the router's manual. If you don't have this information, go to routerpasswords.com and find the brand and model of your router. This site lists the default login information for most wireless routers you can try "ADMIN" for user name and "PASSWORD" for passsword.
You should now be able to see your wireless router settings. You can configure your network ports, as well as SSID (wireless network name) and passwords.
Jan 13, 2011 | Computers & Internet
I have a Thomson TG585v7 DSL wireless router. It
Check if there is any ip address added to the ethernet card of your laptop. And also check if you have enabled encyrption. If you are using DHCP then you better enable DHCP on router also..
Sep 22, 2009 | Computers & Internet
I am using THOMSON TG585v7 and THOMSON TG585n Modems in my workgroup network (more than 15 users.).how to disable internet for some particular users...i am n/w admin..please Help me. Thanks
Before my gateway add is 192.168.3.254 but by mistake i will make factory default so how can i again configure from 192.168.1.254 to 192.168.3.254 plz as soon as possible modem detail thomson gateway speedtouch tg585n
Sep 06, 2009 | Computers & Internet
Can I remove the aerial of the Thomson TG585V7 wireless router?
That is correct, you cannot. It was not designed to be removed. You can dissasemble the unit and install a new antenna, which will require some electronics background but it can be done.
Jul 16, 2009 | Computers & Internet
Cant open ports in elephant with router thomson TG585v7
You need to log on to the router using the default gateway.
Go to Start menu -> Accessories -> Command Prompt
type ipconfig
Note the default gateway
open your browser, in the address bar type in the default gateway ip address - like 192.168.1.254 --- or whatever the IP is.
That should open your router config pages... if it asks you for a user name and password... default usernames depend on your ISP usually, but try for the username Admin, admin, Administrator, administrator and for the password try the same as the username or leave blank... If you have no luck contact your ISP for logging on details.
A web page will open - go to
Toolbox
Game And Application Sharing
At top right click configure
Make sure UPnP and Extended Security are selected if you have those options
Then at the bottom
Create a New Game or Application
from there you just need to select which protocols you need to work with or select ANY
Enter the port you want opened
and add the same port number to the destination / trigger port.
That should be you. If not you need to telnet into you router
Telnet <default gateway IP>
and type Menu
The follow the previous instructions.
Aug 31, 2008 | Computers & Internet
Speedtouch username and password
i need user name and passowrd for modem speed touch
Nov 12, 2007 | Computers & Internet
Computers & Internet Logo
450 people viewed this question
David Payne
David Payne
