With another laptop all chargers seem to work but on mine its own charger does not work yet the other charger works excelently
  • 32,281 Answers
Whenyou connect the power adapter into the laptop, does the power LED light up? Ifnot then - The battery adapter or the adapter's power lead or the laptop's powersocket could be faulty. Check power adapter's DCplug that connects into the laptop power socket with a multi-meter, the voltageshould be slightly higher than the voltage that is printed on the label on thebottom of the adapter. If the voltage is zero or way below the voltage that isprinted on the label then the power adapter is faulty and needs to be replaced. If the adapter is OK thenconnect it to the laptop and power it up, then look at the power/batterycharging LED light and wriggle the power plug in the laptop's powersocket. If the power/battery LED light flashes and in a certain position thisLED light stays firm, then the power socket is either faulty or it has a drysolder joint where it is connected to the motherboard. This can be repaired but itrequires the laptop to be completely dismantled to get at this power socket andrepair. If you cannot DIY then I suggest you get a quote first.
Posted on Dec 31, 2010
The laptop charger just stopped working is a solution to repair it
Mr. Mabelann i suggest you a new charger to buy if your charger is burned due to electricity. Me and my friends have a experience to repair a charger of our laptops but after some time it create disturbance like touch pad does not work properly. Mouse cursor is not working properly and often a problem of up and down.
I also recommend you to see your charger carefully with other wire plugs.
Nov 28, 2013 | HP Pavilion Computers & Internet
Toshiba l300 n723
contact service center
Oct 09, 2013 | Computers & Internet
Macbook charger is not working
short of buying a new one there is noting else you can do as laptop chargers can be purchased rather cheaply at wal-mart and amazon.com sorry. you really can replace it for less than $10
Feb 19, 2013 | Apple 13.3 MacBook Pro Notebook Computer ...
Hi i have an HP Elite Book 6230p,my laptop stop charging recently, i was charging it and i removed my charger plugged in another charger of lower current rating it worked well for a while, but when i...
Nice books, have many. 8540s./. better.
i can not decode this post.
sorry
does it run with no battery and the correct pack
mine has 10 options new the i7 and the fast video card suck huge power and mine needs a 100watt pack, the 65w on mine is HOPELESS. see?
run the correct matching pack,
step 2 a new battery, i keep 2 good ones all the time
on Vacation, id not be wanting to find batteries 3000 south of here, ever. (south of the boarder)
test with no battery
then with correct power pack (the charger is a chip inside the pc and in this 19vdc pack its only a power pack pure DC.
then try a new battery ,
if you read your service manual at HP.com
it tells you all packs used and why, and the match.
sure does.
and varies by OPTIONS DAY1. in all case
unless upgraded like mine, is, and sucks max amps mine does.
Jul 03, 2017 | HP EliteBook 6930p Notebook PC
My compaq cq40 laptop charger is not working
Before you make a decision about the next step, maybe you would like to know why the laptop charger is not working. Here are some commonly found reasons for this problem.
  • You have been using the wrong laptop charger for your machine, or someone else has been using your laptop charger for another machine. This may seem like a harmless act, but it affects the battery on your laptop, and charger you are using as well.
  • Your laptop battery has become weak and worn out from excessive use. Due to this the battery is not charging at all (or charging very slowly) when you plug in the charger. In this case there is absolutely nothing wrong with the charger itself.
  • The wire of the laptop charger has got a distinct curve at one point, and this is restricting it from transmitting power. You need to look out for such bends in the wire, as this will ruin the efficiency of the charger in no time.
  • This may sound elemental and stupid to some, but it does happen to many people. Maybe you are simply using the wrong laptop charger by mistake, or maybe you have failed to switch on the power switch. Check both these things to be sure.
Any of these potential causes could be the reason behind your laptop charger not working. As a result of these, either the mains power lead of your charger may be damaged, or the power supply unit may be damaged, or maybe the lead itself is damaged or broken somewhere, or some circuitry inside the laptop is damaged, and not responding to the charger. It's hard to accurately tell which of these problems could be the real cause of your laptop battery not charging, without physically examining the machine.
Solutions and Answers
Now if you are well versed in computer hardware you can attempt to fix this yourself. Most people cannot do this, and it is advisable for them to visit a computer repair shop instead. They will examine the laptop charger not working problem, and suggest some suitable remedies for it. Depending on your budget, you can choose an option that suits you and simultaneously solves your problem. Here are some recommended solutions.
  • Buy a brand new charger which will definitely solve your problem of charging the laptop for a long time.
Compaq Presario CQ40 Laptop Charger
  • If you're hesitant to pay that amount, you can try and purchase a second hand laptop charger from eBay.
  • Get your's repaired and pay the repair shop the fees that they charge.
  • If your warranty is still valid, you can simply get the laptop charger replaced.
Reference: http://www.buzzle.com/articles/laptop-charger-not-working.html
Apr 25, 2011 | Compaq Presario CQ40 Series Laptop Charger...
Laptop only turns on every now and then, charger pluged in but charger light not on, when trying to turn on fan kicks in, charger light flashes, then nothing, please help?
It sounds like you have a bad charger cord. Does it do the same when powered off the battery? Like it is tryin to start up. An d also make sure battery is plugged in good to the laptop,
Oct 31, 2010 | HP Compaq nx5000 Notebook
The laptop wont charge
Just because the light comes on does not mean the charger is charging. You will have to use a meter and check the actual output of the charger. The problem could be the charger , charger plug, cables or battery. Start the checks with the plugs and cables and go from there. The light can come on but no power going out to the battery.
Oct 12, 2009 | Toshiba Satellite A55-S1063 Notebook
I need a charger for eMachines D620 laptop
I buy all my chargers on Ebay at a store called Monster Parts. These chargers have extra long cables and good warrarties, all for under 40 bucks. Most chargers are 25-25 bucks.
Oct 12, 2009 | Computers & Internet
How do I reset s9....the green light stays on constantly and I cannot connect at all.
If you guys haven't found a solution, you might want to try this out. Have your S9 charger hooked up to the unit and plug the charger into a surge protector. Flick the main switch of the surge protector on and off a few times and it should turn off the unit. Then turn on and pair if need to and it should be fine. Hope that works for ya!
Cpl. Ramos
Jun 24, 2009 | Motorola Mobility S9 Headphones
Computers & Internet Logo
47 people viewed this question
David Payne
David Payne
