Frigidaire GLTF1670A50 stopped spinning what can be the problem?Hope to hear from you soon. Thanks
Front end washer not washing or turning all u hear is the motor what causes this to happen
Hi Arthur Williams, this is AP! Thank you for your post.
I understand you are having trouble with your front load washer not spinning, but you can hear the motor. There are many situations that could prevent your drum from spinning. Overuse of detergent can result in too many suds restricting the tub from turning properly that will not spin out. Is the washer making a humming noise? Try putting the washer on spin only, if the drum will spin then it could be kinked hoses, if not it could possibly be the motor or the door lock assembly, timer, pump, control board not communicating. I would recommend having a technician come out to diagnose your front load washer. I hope this information proves helpful for you.
Thanks,
Mar 16, 2014 | Frigidaire ATF6000ES Front Load Washer
During the spin cycles in the wash the machine makes a loud whining noise while spinning? As soon as the cycle is finished the problem goes away. Is this a faulty belt or what. Please help.
Either the belt or you transmission could be slipping and it making the belt work harder on a full load. Try running the spin cycle without water to see if you hear it. If you do then it is the belt, but if you only hear with water then it is your transmission.
Apr 18, 2011 | Frigidaire FEX831CS Top Load Stacked...
Spin cycle goes very slow or doesn't work.
Hello, After looking at the User Manual for our Washer, E20 is an error code for the drain. It said that either the house drain line is clogged or the washer drain line is clogged. After my husband took the drain line off the washer, cleaned it out, we noticed that the lines had a lot of detergent build up and figured that this is probably the cause of the error code. We put the washer back together and it is working properly. We have always used the "he" detergent for the front loader and always used the proper amount; however, from now on, we will use less than the recommended amount.
I hope this helps some of you who are having this problem.
Thanks
May 19, 2010 | Frigidaire Affinity ATF6000ES 3.5 Cu. Ft....
Drains but will not spin. I can hear the motor
The machines spin motor winding may be short circuited kindly replace the motor
Dec 23, 2009 | Frigidaire Affinity ATF7000E Front Load...
MY WASHER DOESN'T SPIN CLOTH OUT
99% of all problems are a clogged filter and pump
Jul 06, 2009 | Frigidaire GLTF2940ES Front Load Washer
Washer does not spin after wash cycle
Problem solved. It was one of the resolutions posted by one of your clients. TKS. PS this one of the best problem solving sites that I have seen. Great Job Rick
Jan 29, 2009 | Frigidaire GLWS1233A Top Load Washer
Frigidaire top-load washer Loud noise during spin
its either the upper spin bearing or lower spin bearing. the upper can be replaced by itself but the lower requires the transmission the be replaced
Nov 20, 2007 | Frigidaire FWS833A Top Load Washer
Washing Machine don't spin.
Hi Mambo; Your problem is a fairly common one. The lid switch has gone bad. To test this, open the lid and locate the switch. It will be a small hole that has a plastic piece in it. Use a pencil and push down on it. If you hear, or feel a 'click' then you may have another problem. If you don't hear, or feel a 'click' then the switch is bad and will need replacement. Replacement will require some advanced knowledge of washing machines and the ability to use a box of tools proficiently. Best regards; HELP2DIY
Jul 08, 2007 | Frigidaire GLWS1233A Top Load Washer
Washing Machines Logo
79 people viewed this question
Top Washing Machines Experts
