Question about Ovens
Arda 900mm freestanding oven.. We bought a new house and it had the Arda oven installed but we don't have a manual for it.. And not sure what one of the control knobs does.. It's the knob on the far right that controls the oven. Both elements, just top, just bottom, fan forced, not fan forced etc..
SOURCE: Top oven will not heat up
Had a similar problem. The overheat sensor had failed to the open position and the oven control would light up and you could set the temp, but it would drop to 100 degrees and then go blank.
Posted on Jan 06, 2008
  • 190 Answers
SOURCE: Bosch oven not heating to temp
Dear customer,
i recommend u to try the following routine to sort out this problem
  • Check timer and clock settings
  • Reseat the element
  • Test the element
  • Test the element connectors
  • Test the oven temperature control
  • Test the oven selector control
  • Recalibrate the temperature control
  • hope u find this useful. thank you.
    Posted on Jul 09, 2008
    • 1462 Answers
    SOURCE: Neff B1432 2002 Element blown
    did you check the old element with a multimeter to make sure it is in fact faulty?
    check continuity across the thermostat as well
    Posted on Nov 29, 2008
    jumptrout51
    • 3361 Answers
    SOURCE: Oven blows main switch
    There is a short circuit between the lower oven control and the lower element.
    Disconnect the lower element. Put electrical tape on the loose terminals and turn the lower oven on.
    If it does not blow, replace the lower element with a new element.
    If it does blow, Check the wiring to the lower element for continuity to the frame of the range.
    If you get continuity replace the damaged wire..
    Finally, check the control knob switch for continuity to ground on the frame of the oven.
    Posted on Mar 20, 2009
    jumptrout51
    • 3361 Answers
    SOURCE: the element won't turn off. When I turn the knob,
    Probably a broken element. It is shorting out against the element canister. If not broken and shorted. You have a bad timer.
    Posted on Jul 03, 2009
    I just bought a about 35year old house it has a chef contessa deluxe gas freestanding oven and warmer i don't know the model no can you help i need a manual and parts
    Hello Helen, most model number labels can be found either under the cook-top surface burners; on the side of the oven unit; or in the back near the vent. Other places to consider, behind the oven door jamb along the top or side edges. If your particular stove unit has a kick plate, you may find the oven's schematic attached to the inside of the kick plate with may contain the technical data to your unit. Hope this helps.
    Feb 12, 2017 | Ovens
    We have a Arda oven where can I find a.user manual
    you can search thru Google for Arda manual
    Dec 28, 2016 | Ovens
    Frigidaire Gallery 30'' Freestanding Electric Range We recently bought a house with this stove in it. however the oven door outside window part is off.....how can we re-attach it.
    Hey Alice, I appreciate your post!
    I understand that you need help reattaching part of your Frigidaire range. I have located a parts schematic and attached it for you. If you need any additional assistance please feel free to reconnect. Good luck! -Matt
    ftp://ftp.electrolux-na.com/ProdInfo_PDF/Lassomption/5995639282.pdf
    Dec 20, 2015 | Frigidaire Gallery 30 " Stainless Steel...
    Self cleaning oven error code FSEO
    Probably a bad door lock solenoid. That is some kind of door lock problem. Trouble is they are not all the same. This training manual shows locations of model number. Perhaps if you post that I might can come up with a tech sheet and you would get a better answer. see page 4
    Apr 11, 2010 | Whirlpool 30" Self-Cleaning Freestanding...
    No instructions on how to use self cleaning Frigidaire range/oven
    stove stuck in self cleaning mode door was open when cleaning mode was turned on will not shut now what do i need to bdo?
    Feb 14, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
    Kenmore Elite Freestanding Electric Range - Cooktop not working
    Your stove probably requires a separate 20A circuit with 12 ga. wire.
    May 19, 2017 | Frigidaire 30" Self-Cleaning Freestanding...
    Ovens Logo
    317 people viewed this question
    Top Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Are you an Oven Expert? Answer questions, earn points and help others
