Want to change pressure relief valve vizo heatline 24 looks very hard to get at
  • 3 Answers
SOURCE: gravity feed boiler/ american standard model#g27dpgc
your make up water pressure is greater than the safety relief pressure. The safety should be 30psi lift. the makup usually goes through a regulator called an automatic makeup valve. these valves operate infrequently on a closed system and get rusty. They stick. If yours is stuck open, then your makeup water pressure which is probably greater than 30psi is overpressuring your boiler.
Posted on Sep 30, 2008
mrhotandcold
  • 248 Answers
SOURCE: hi. my heatline vizo 24 boiler not working
overheat stat or fan best of luck
Posted on Oct 24, 2009
  • 3 Answers
SOURCE: to get heat downstairs i have to turn raiators off
Sound like a dirty system , power flush needed
Posted on Feb 07, 2010
garypetterss
  • 15 Answers
SOURCE: pressure relief valve
The pressure relief valve only leaks when there is excess pressure in the system, possible causes could be excessive static pressure, overheating, faulty pressure vessel or undersized pressure vessel.
Posted on Apr 11, 2010
  • 52096 Answers
SOURCE: why is the relief valve still opening
perhaps you changed the wrong T-stat there is 2 of them .
Posted on Sep 02, 2015
Changed filter as I have a few times, it is now slow leak from pressure relief valve. How can I fix it?
activate the pressure relief valve a few times to see it will seat better or replace the pressure relief valve
May 21, 2015 | Water Heaters
Heatline vizo 24
Your cold water fill tube inside the tank is broken off near the top of the tank. Replace the fill tube.
Aug 26, 2014 | Water Heaters
Pressure relief valve intermittent noise
check your water pressure and then make sure it is not to high or all the problems you have had were not the answer. it is a pressure /temperature valve not just . temp.
Apr 06, 2014 | RHEEM 40 GAL ELEC Water Heater 6YR SC...
Need to decrease pressure on a heatline plus 24 vizo? any ideas? also leaking small amount of water under boiler!
There is a pressure adjustment on the gas valve...make sure you set it with a manometer. If the water is just condensate, its ok except if you don't have enough combustion air for the btu rating of the water heater. If it is a leak, replace the water heater
Dec 11, 2013 | Water Heaters
Is the reed valve part of the pressure switch
relief valve should only open in a over pressure condition. If it is opening prior to reaching pressure ....replace it.
May 21, 2012 | Air Tools & Compressors
Pressure releif valve leaking
Hot water pressure relief valves serve two functions. The first is to remove high-pressure water from the hot water tank. The second function is to act as a high temperature valve to remove water that exceeds a predetermined point for the valve. Both of these relief settings are preset at the valve factory. Many pressure relief valves will come with a metal tag that identifies these release points. If you're attempting to remove the hot water heater pressure relief valve, pay careful attention to ensure that you replace with the correct valve.
Your hot water heater has a pressure relief valve safety mechanism. When pressure inside the water tank exceeds certain limitations, the valve opens up to allow the pressure to be released. A faulty pressure relief valve will not release excess pressure, which could cause extensive damage to your home. You should test the hot water heater pressure relief valve once every six months to ensure proper operation. If the pressure relief valve fails the test, replace the valve with a new one immediately
Locate the pressure relief valve on your hot water heater. The pressure relief valve has a lever handle on top with a drain pipe attached to it. The pressure relief valve is most often on the side of the water tank toward the top. Newer models of hot water heaters have the pressure relief valve on top of the water tank.
  • Inspect the area around the pressure relief valve for signs of leaking water. If there is leaking water near the relief valve connection, replace the relief valve. If no leaking is evident, proceed with testing the pressure valve.
  • 3
    Examine the area below the pressure relief valve drain pipe. Most water heater closets either have a drain in the floor below the pipe or the pipe is inserted into another pipe to direct the water out of the home. If the end of your drain pipe is not in another pipe or there is no drain in the floor, place a bucket under the drain pipe to catch water when you test the pressure relief valve.
  • 4
    Pull the lever handle on the top of the pressure relief valve up with your fingers. A working lever will lift up without difficulty.You should begin to hear water going through the drain pipe. Slowly release the lever to shut off the pressure relief valve. The pressure relief valve is good. If you did not hear water running through the drain pipe, lower the lever on the pressure relief valve and replace the valve. If the lever is difficult to raise, do not force the lever. Replace the pressure relief valve.
  • Now with all that said if you have a closed loop water supply system and you have a pressure vessal/expantion tank it may have gone bad and is making the TP valve leak. you can call your water provider to see if you have closed loop system.
    Feb 04, 2011 | Whirlpool Water Heaters
    Apr 11, 2010 | Rheem 50 Gallon FVR NATGAS Water Heater...
    To get heat downstairs i have to turn raiators off
    Hi check the water pressure in the boiler check the setting / speed of the pump see if this helps
    Feb 07, 2010 | Desa International CBN30T Central Heating...
    Hi. my heatline vizo 24 boiler not working
    Oct 13, 2009 | Water Heaters
    Heating & Cooling Logo
    Top Heating & Cooling Experts
    Paul Carew
    Tim Whalen
    Mack Baxter
