Question about D-Link AirPremier DWL-3200AP, AirPlus G DWL-G730AP (DWL3200APBUN) 802.11b/g Wireless Access Point
I want to extend 2640t router's range by using 3200AP as wireless extender. Could establish handshaking between two devices using physical (cat6) cable but not wireless connectivity. In which mode 3200AP to configure: AP/WDS/Bridge.Kindly help
    President:
  • 2,022 Answers
Yes u can just use the same range ip address for both device like 192.168.0.1 for dlink and 192.168.0.2 dor airplus.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Posted on Dec 31, 2010
How does it connect to my router
You can connect to the router either with Cat6 Ethernet cabling ("Access Point Mode") or wirelessly (client and bridge modes).
Dec 10, 2015 | D-Link DAP-1360 Wireless N Range Extender
How to set up netgear ex6100 wifi range extender
Overview:
This article describes how to set up a NETGEAR EX6100 in Extender Mode
The extender connects wirelessly to your existing WiFi network, and then it creates a new WiFi extended network and links the two WiFi networks.
Symptoms:
Cannot connect to extender
Extender broadcasting EX6100_NETGEAR_2GEXT
Extender broadcasting EX6100_NETGEAR_5GEXT
Extender cannot access Internet or network
Process:
1. Place your extender in the same room as your WiFi router.
2. Plug the extender into an electric outlet and wait one minute.The PowerLED lights green.
If the Power LED does not light, press the Power button on the side.
3. Make sure that the mode switch on the extender is set to Extender.
4. Use a WiFi network utility on a computer or mobile device to find and connect to the EX6100_NETGEAR_2GEXT or EX6100_NETGEAR_5GEXT (SSID) WiFi network.
Note: EX6100_NETGEAR_2GEXT and EX6100_NETGEAR_5GEXT are the default name of your extender's wireless networks, and by default it is unsecured. If you changed the wireless name or security in the past, connect to the new name or enter the passphrase when prompted. EX6100_NETGEAR_5GEXT is only visible if your wireless adapter is 5 GHz capable.
After the wireless connection with the computer or mobile device is established, the Client Link LED lights solid green.
5. Open a web browser window from the same computer or mobile device.The browser takes you directly to NETGEAR genie Smart Setup.
Note: If you are not automatically directed to NETGEAR genie, launch an Internet browser and type www.mywifiext.net in the address field of the browser. Enter admin for the user name and password for the password.
6. Select a 2.4GHz WiFi network to extend and click the Continue button.
7. Type the network passphrase (also called password or security key) in the Passphrase field and click the Continue button.
8. Repeat steps 6 and 7 to select a 5GHz WiFi network.
Note: If your router does not support the 5GHz band, click the Skip button.
9. Select Private Network(home network) or Public Network radio button, and click Continue.
Note: Selecting Public Network will enable NAT and DHCP on the EX6100. For more info on NAT refer to: What is NAT (Network Address Translation)?
10. Type the name (SSID) for your WiFi extended network in the 2.4GHz and 5GHz Network Name (SSID) field and click the Continue button.
Note: You can use the same security settings as your existing network by selecting the Use the same security mode check box.
The WiFi extended network settings are applied.
11. Use a WiFi network manager on a mobile device or computer to connect to the extenders newly created WiFi network.
12. Click on the check box and click on Continue to finalize the installation.
13. Unplug the extender and move it to a new location closer to the area with a poor WiFi signal.
Note: The location you choose must be within the range of your existing WiFi router network.
14. Plug the extender into an electrical outlet and wait one minute. The Power LED lights green. Connect to the extender network and enjoy the extended Wifi network.
May 02, 2014 | Computers & Internet
Gigabyte b49g wont link with wireless extender
first, Keep in mind that you bring the device into the same room as your wireless router.Use NETGEAR, Linksys Router.
second, Green LED on the extender is showing green to be able to get the optimum performance on your devices.
third, if not get it than just reset to factory defaults
then manually changed the security settings for your router .
Apr 14, 2014 | Gigabyte GN-B49G Router
Mywifiext net welcome
You can't connect the range extender to the wireless router or you can't connect your wireless devices to the range extender?
If its the router what is the name and model of the router?
Nov 19, 2013 | Computers & Internet
Expand range extender
You can install a wireless range extender. Try a Netgear Dual Band WiFi Range Extender, this device extends the wireless range of your existing wireless router, it connects to your wireless router using a wireless connection without the need of a LAN cable.
May 19, 2013 | TP-LINK TL-WR1043ND Router
I recently installed CAT6 cable to run between my computer and main stereo. The run is 50' so I also purchased a USB extender. My issue is that once I hook the network up to my computer, it can no...
Yes- don't use USB as an extender- Network spec for Cat 6 without a repeater ranges from about 165 feet to 75... You should be able to run the cable straight through.
Jun 15, 2011 | IOGear USB Booster Cable G2LUB16 USB...
How do I hook up a G wireless router to my h/p computer
The usual setup is to connect your internet cable or dsl model to the WAN port on your wireless router. any devices that were formerly connected to your cable/dsl modem then get connected to the LAN ports on your router. You will need to connect to the wireless router via etehrnet cable the first time in order to setup your wireless connection, it's usually a simple setup following the prompts.
Sep 29, 2009 | Belkin (F5D8231-4) Wireless Router...
Extend the range of my N1 router - how?
I have 2 x Belkin N1 vision dsl (cable) routers. One is connected fine with Virgin 20 meg broadband. Is it possible to use the other N1 vision router as a range extender up stairs to get better signal , without using any cat5 cabling ? I.e router-to-router
Aug 04, 2009 | Belkin N1 Vision Wireless Router
Use Belkin f5d7230-4 as a wireless access point
Hi Druid,
Based upon what I've read regarding and experience with the F5D7230-4 is it will only work with another F5D7230-4 or F5D7231-4, F5D7130, F5D7132 and this are all Belkin products as well I thiink it has something to do with the WDS compliance for this specific model that's why they have clearly specified on the User Guide which devices are guaranteed to work with an F5D7230-4 that is set to AP Mode(Bridge/Repeater).
If you really want to exend the wireless coverage of your Linksys router I suggest you try the Wireless G Range expander(WRE54G v2.0/3.0 version 1.0 I do not recommend since it's somewhat challenging to configure since it has no ethernet port all the setup will be done wirelessly)
click this link for the User Guide of your Belkin router.
Aug 17, 2008 | Belkin (F5D7230-4) Router (587009)
Computers & Internet Logo
277 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
