Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
Hi i have a 03 EFI road king Ive put a new ecm a new coil checked for valve leak down , but still can't find this misfire and blow back through the throttle body just above 1500RPM
    President:
  • 2,047 Answers
Misfires and blowbacks in combustion engines are always as a result of either air in the engine systemor dirt which has refused to burn inside the combustion system.
What you have to do is try getting the gasoline inside the system out allow it to settle and filter out the particles which would settle at the bottom of the gasoline which is poured out. Also try to get the gas tank washed out to clean out all dirt in the unit.
After this check the spark plug if it is burnt out if yes replace it. When all this has been done couple the unit back and runt it for about fifteen minutes the system will not misfire or blowback anymore.
Hope this solution has been helpful?
Posted on Jan 03, 2011
2003 harley davidson road king cranks but will not start
Hi Anonymous, when checking for spark the CKP needs to measure the compression bump in order to send the correct signal to the ICM/ECM so always check for spark with either a third plug grounded or lift the end of the plug boot 1/2 " off one of spark plugs that are in the head. and the usual suspects are:
1. Fuel tank empty
2. Fuel supply valve turned off.
3. Fouled spark plugs.
4. Engine flooded with gasoline as a result of over use of enrichner.
5. Fuel valve or filter clogged.
6. Vacuum hose to automatic fuel supply valve disconnected, leaking, or pinched.
7. Discharged battery, loose or broken battery connections.
8. Loose wire connection at coil, battery or plug between ignition sensor and module.
9. Spark plug cables in bad condition and shorting, spark plug cable connections loose,
or cables connected to wrong cylinders.
10. Ignition timing incorrect due to faulty ignition coil, ignition module, or sensors " Manifold Absolute Pressure" "Camshaft Position Sensor" "Crank Position Sensor" "Brake Apply Sensor
11. Engine lubricant to heavy ( winter operation )
12. Sticking or damaged valves or push rod wrong length.
13. Primary cam sproket spline sheared or missing spacer.
14. Security alarm system not disarming.
For a primary suspect please visit the website below: Good luck
Big Twin Carb EFI DTC Intructions codes Harley Davidson Forums Harley...
Nov 13, 2013 | 2003 Harley Davidson FLHRCI Road King...
2001 Road King won't start. Wants too but wont
1. Fuel tank empty
Nov 04, 2013 | Harley Davidson Motorcycles
No fuel or spark? what the heck!!!!
1. Fuel tank empty
Oct 21, 2013 | 2000 Harley Davidson FLHR-FLHRI Road king
2001 Fuel Injected Road King Hiccups and backfires under 2500 rpm
Hi Anonymous, and the usual suspects are:
1. Spark plugs in bad condition or partially fouled.
2. Spark plug cables in bad condition or leaking.
3. Spark plug gap to close or to wide.
4. Faulty ignition coil, module and or sensor.
5. Battery nearly discharged.
6. Damaged wire or loose connections at battery terminals,
ignition coil, or plug between ignition sensor and module.
7. Intermittent short circuit due to damaged wire insulation.
8. Water or dirt in fuel system, carburetor or filter.
9. Fuel tank vent system plugged or carburetor vent line closed off.
10. Carburetor controls misadjusted.
11. Damaged carburetor.
12. Loose or dirty ignition module connector at crankcase.
13. Faulty MAP, CKP, and or CMP sensors.
14. Incorrect valve timing.
15. Weak or broken valve springs.
16. Damage intake or exhaust vale.
For a prime suspect please visit website below and good luck:
Dec 27, 2012 | 2001 Harley Davidson FLHR - FLHRCI Road...
2001 road king is only firing on back cylinder. replaced plugs and coil still the same, what is next?
Hi Advantagecol, and the usual suspects are:
Aug 23, 2012 | 2001 Harley Davidson FLHR - FLHRCI Road...
Stop backfire on 2001 road king
Jun 15, 2012 | 2001 Harley Davidson FLHRCI Road King...
Need to fix lean misfire on 02 fuel injected
Hi Lance, and the usual suspects are:
May 26, 2012 | 2002 Harley Davidson FLHR - FLHRCI Road...
2000 road king classic won't start
Hi Choove, when checking for spark the CKP needs to measure the compression bump in order to send the correct signal to the ICM/ECM so always check for spark with either a third plug grounded or lift the end of the plug boot 1/2 " off one of spark plugs that are in the head. and the usual suspects are:
1. Fuel tank empty
7. Discharged battery, loose or broken battery connections especially the negative cable at "BOTH" ends
For a primary suspect please visit the website below. Good luck and have nice day.
Set Change Override Transport Harley Security Alarm PIN Code No Key Fob...
Apr 22, 2012 | 2007 Harley Davidson FLHRC Road King...
Bike will not start up. Battery is fully charged but will not fire.
Hi Marko84hd, when checking for spark the CKP needs to measure the compression bump in order to send the correct signal to the ICM/ECM so always check for spark with either a third plug grounded or lift the end of the plug boot 1/2 " off one of spark plugs that are in the head. and the usual suspects are:
1. Fuel tank empty
Mar 18, 2009 | 2002 Harley Davidson FLHR - FLHRCI Road...
1997 ford f150 cyliner 7 misfire
sme problem had to have it put on computer and codes reset
Feb 05, 2009 | 1998 Ford F150 Regular Cab
Lands Phones Logo
46 people viewed this question
Top Harley Davidson Lands Phones Experts
ted dux
Ronny Bennett Sr.
Ronny Bennett Sr.
David Payne
David Payne
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
