Question about Intel D845GVSR Motherboard
MOTHERBOARD INTEL D845GVSR
All the jumpers are in correct position although led of motherboard glows no fans are working it is not taking boot
  • 2 more comments
  • maceyak3 Aug 07, 2008
    same as stated however, I have the HDD,Power ,and SW leds disconected and am not sure where they go. there are no plugin other then front panel 9prong at the lower left of board
    i
  • Anonymous Aug 07, 2008
    I have the same problem as LUCKY007.
  • jeeva_yr Nov 19, 2008
    all the jumpers are in correct position although led of motherboard glows no fans are working it is not taking boot
  • jeeva_yr May 11, 2010
    jumpers are not conect properly
  • 24 Answers
Fiend your solution direct from intel. Here is your solution........
http://www.intel.com/motherboard/prob676ijt65/solution
103
Posted on Mar 13, 2009
    Novelist:
  • 183 Answers
Check the Power cable if it is working fine, if it is then check the SMPS(Powersupply) and then the Motherboard.
Posted on Jul 09, 2008
Fan Speed 100% on Intel D845GVSR motherboard
see if you plug them in the right spot cpu gose by the cpu case fan will say case on board some take two wire fans some 4 wire some 3 wire jim
Feb 20, 2010 | Intel D845GVSR Motherboard
D845GVAD2
This can be a sign of bad power suplly,
The fact that it turns on is not a sign that is working properly.
Test with different power supply
Jun 10, 2009 | Intel D845GVSR Motherboard
No display or no boot
i suggest you flash your bios.
if this doesn't work replace your motherboard...
Apr 14, 2009 | Intel D845GVSR Motherboard
No Power At Start Up
most likely need a mb replaced
Jan 19, 2009 | Intel D845GVSR Motherboard
Power failure
100
Oct 31, 2008 | Intel D845GVSR Motherboard
Mother board D845GVSR
hi im wesley. does the pc boot up at all?
Jul 09, 2008 | Intel D845GVSR Motherboard
Intel d845gvsr
108
Jul 08, 2008 | Intel D845GVSR Motherboard
ON MOTHERBOARD PROCESSOR
1.replace a new fan.
2.check the power supply.
I have a Boot Problem with my INTEL P4 3.0Ghz. 800Mhz FSB,1M L2 Cache, Socket 478 CPU
I have experienced something similar with my new Core2Duo processor and a fairly new Socket 775 processor. Troubleshooting it led me to believe the CPU simply wasn't compatible with the motherboard. Although it's a shot in the dark, I suggest that you try out some of the following: - Did you try pulling out the graphics card to see if you got it to POST then? The graphics card or the monitor may need replacing. - Did you remove the RAM? - Are you sure all cables are attached properly? - Try to take out the CPU, talk to a friend with a socket 478 motherboard and replace his CPU with your CPU. Does it work now? If yes, motherboard needs to be replaced.
Nov 12, 2006 | Intel P4 Prescott CPU 2.8A Ghz W/1MB CACHE...
Intel D845GVSR Motherboard Logo
189 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
