It keeps saying carrige jam and it get stuck on the right side
    President:
  • 2,017 Answers
It is requiring servicing if you can open the cover and apply some lubricant oil on the steel rod it will fix the problem otherwise show it service center.
Hope this helps. Please rate my response.
Thanks.
Have a good day.
Posted on Dec 31, 2010
It keeps reading 'carriage jam, close door then press ok ... ' it will not stop.
If you open the printer cover you should be able to see a guide bar where the print carrige runs, if you can touch it feel if it is dry, if it is very dry (it may have black residue) then you will need to wipe the bar with a tissue or rag to clean it and then with a toothpick carefully add some singer oil (Machine Oil) maby 4 -5 drops along the bar, and slowly move the print carrige over the newly oiled section this should lubricate the bar again and stop your carrige jam issues
Feb 09, 2011 | HP OfficeJet 6210 All-In-One InkJet...
My brother mfc 465cn keeps saying paper jam. I do
The paper sensor is either stuck or dirty.
Just open it and follow the paper path and you should see where it is.
Otherwise, the sensor may be bad.
Apr 18, 2010 | Brother MFC-465CN InkJet Printer
Hp photosmart a520 series carrige jam nothing
Hello there You can still try this Generally when this happens, something has fallen into the printer, or a piece of paper has been jammed in there.
First step, remove the ink cartridge, and turn the printer upside down and gently shake it, see if anything comes out.
If nothing goes, or you can't hear anything rattling around, get a piece of cardstock paper (60lb or heavier) and gently push this through the printer, to see if it will help push out what might be stuck in there.
And gave the rode that the ink slides on a good clean and maybe a bit oil on cloth and wipe the rod with it.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 12, 2010 | Office Equipment & Supplies
My ink jet cannon printer MP600 is saying i have a paper jam there is no paper in it and it is still saying this and wont let me access any other functions or print
Recheck all jam clearing areas on the machine. Open doors, reseat the doors. Check for safety interlock switches, they are small and hard to find.
make sure the acuators are still in place, on the switches.
With the power off, move the ink carrige over left and right make sure there is no paper back there.
Make sure the carrige comes to its home position.
Other than this, possibly malfunction sensor or main board problem.
Oct 15, 2009 | Canon Office Equipment & Supplies
I get an error messege (carrige jam)
I have found that when I slide back the carriage to the left by hand and expose the bottom right hand side, there has been an accumulation of ink that is preventing a part from sliding from front to back. Inspect the bottom right hand side where the black and color cartridges normally sit. You will find a flat sliding piece directly beneath the position where the cartridges normally sit, that will not slide forward to the front of the printer and back towards the back of the printer easily because of the ink that has accumulated and is causing a drag. I used q-tip swabs and some alcohol and cleaned out the rails that the piece slides in. Use a flashlight to inspect. After cleaning it appears that it is printing normally again. Repeat the process as needed. Bob in NC
Jan 27, 2009 | HP PSC 2355 All-In-One InkJet Printer
Carrige Jam
carriage assembly defective..uneconomical to have repaired. Sorry
Jan 26, 2009 | HP PSC 2355 All-In-One InkJet Printer
Carrige and paper jam at the same time
The paper jamming is the result of the carriage problem. The paper is starting to feed and then carriage problem -- so paper jams. Look in the optical cavity and see where the carriage is stopping. You can take off the platen glass ( about 3-6 screws) and see if you can remove or fix the hang up.
Dec 30, 2008 | Office Equipment & Supplies
Paper jam from printer an envelope. I got out the envelope except for a small piece about 2x2 and I can't find it. Now my printer will not work at all and it says carraige jam. I tried putting a piece of...
More than likely, there's paper stuck in there somewhere. It's causing something not to move right, and then the carriage is getting **** on whatever part isn't moving right.
Turn the printer off, and then lay it out on a table. Take whatever panels you can off, or open them. Go through the paper path like a fine-pick-comb and find that piece of paper.
Hope this helpe :>
Jul 26, 2008 | HP Photosmart 3310 Printer
Carriage jam
This can be many things, but inspect the paper path for anything stuck. remove the cartridges with printer off and see if you can manually move the carriage you may need to force it a little but not allot, sometimes it may jump a gear causing this error.
move the carriage away from home position and turn on, the printer should reset the carriage position.
hope this helps
Jan 07, 2008 | Office Equipment & Supplies
27 people viewed this question
jasbo
jasbo
